Help, SimpleIDE no longer recognizing my board
I can't seem to get it to recognize the board. No idea what happened or how I fix it.
SimpleIDE Version 0.9.64
C:/Users/XXX/Documents/SimpleIDE/Learn/Simple Libraries/
C:/Users/XXXX/Documents/SimpleIDE/ Updated on: 2014-08-10
propeller-elf-gcc.exe -v GCC 4.6.1 (propellergcc_v1_0_0_2408)
propeller-elf-gcc.exe -I . -L . -I C:/Users/XXX/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L C:/Users/XXX/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I C:/Users/XXXDocuments/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L C:/Users/XXX/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/cmm/ -I C:/Users/XXX/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L C:/Users/XXXXX/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -o cmm/Test define notes.elf -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 Test define notes.c -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm
propeller-load -s cmm/Test define notes.elf
propeller-elf-objdump -h cmm/Test define notes.elf
Done. Build Succeeded!
propeller-load.exe -Dreset=dtr -I C:/Program Files (x86)/SimpleIDE/bin/../propeller-gcc/propeller-load/ -b ACTIVITYBOARD cmm/Test define notes.elf -r -p COM3error: no propeller chip on port 'COM3'
Are you selecting to correct COM Port in the upper right hand drop down box? This has bitten me before.
I'd try a different computer and/or Propeller Tool and see if you can get it talking...
My computer, right now, has 3 COM ports connected / active, none of which are Prop's, and they all show in SimpleIDE's drop down box, top right.
