Help, SimpleIDE no longer recognizing my board — Parallax Forums
GirlpartsGirlparts Posts: 2
edited 2014-10-01 13:10 in Propeller 1
I can't seem to get it to recognize the board. No idea what happened or how I fix it.
SimpleIDE Version 0.9.64
C:/Users/XXX/Documents/SimpleIDE/Learn/Simple Libraries/
C:/Users/XXXX/Documents/SimpleIDE/ Updated on: 2014-08-10
propeller-elf-gcc.exe -v GCC 4.6.1 (propellergcc_v1_0_0_2408)
propeller-elf-gcc.exe -I . -L . -I C:/Users/XXX/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools -L C:/Users/XXX/Documents/SimpleIDE/Learn/Simple Libraries/Utility/libsimpletools/cmm/ -I C:/Users/XXXDocuments/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext -L C:/Users/XXX/Documents/SimpleIDE/Learn/Simple Libraries/TextDevices/libsimpletext/cmm/ -I C:/Users/XXX/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c -L C:/Users/XXXXX/Documents/SimpleIDE/Learn/Simple Libraries/Protocol/libsimplei2c/cmm/ -o cmm/Test define notes.elf -Os -mcmm -m32bit-doubles -fno-exceptions -std=c99 Test define notes.c -lm -lsimpletools -lsimpletext -lsimplei2c -lm -lsimpletools -lsimpletext -lm -lsimpletools -lm
propeller-load -s cmm/Test define notes.elf
propeller-elf-objdump -h cmm/Test define notes.elf
Done. Build Succeeded!
propeller-load.exe -Dreset=dtr -I C:/Program Files (x86)/SimpleIDE/bin/../propeller-gcc/propeller-load/ -b ACTIVITYBOARD cmm/Test define notes.elf -r -p COM3error: no propeller chip on port 'COM3'
    edited 2014-09-26 15:41
    Welcome to the forums!
    Are you selecting to correct COM Port in the upper right hand drop down box? This has bitten me before.
  • GirlpartsGirlparts Posts: 2
    edited 2014-09-28 06:16
    Nope the box says COM 3. My fear is that chip is dead. I work a lot overseas and decided to take my activitybot with me to give me something to do at night. I put it in my luggage. The electronic bag that it was in either came undone or the board was removed by customs. I am not sure if it went through xray etc.
  • RaymanRayman Posts: 15,390
    edited 2014-09-29 12:36
    I've taken propellers through airport x-ray many times and have never had a problem...
    I'd try a different computer and/or Propeller Tool and see if you can get it talking...
    edited 2014-09-29 13:08
    Instead of using SimpleIDE, try the Propeller Tool to see if it can locate and connect to your board. That way, you'll know whether it's a hardware or software problem.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-09-29 19:54
    I have this problem ALOT with my Netbook. Have you tried a different USB cable or maybe just holding the cable in firmly?
  • ValeTValeT Posts: 308
    edited 2014-09-30 05:42
    I get this a lot as well, but usually it is because I am not using the correct USB port. Have you tried all of the USB ports on your computer?
  • abecedarianabecedarian Posts: 312
    You've verified the board is showing as COM3 port in Device Manager, and not some other port?
    My computer, right now, has 3 COM ports connected / active, none of which are Prop's, and they all show in SimpleIDE's drop down box, top right.
