Newbie posting question
I know there is a way to post code fragments in a post but I can't seem to locate how to make this happen. Could someone point me in the right direction?
Thanks. Mike B.
Thanks. Mike B.
Fragment
[ /code ]
But remove the spaces before and after brackets yields
OK T_Chap, thanks. Looks simple enough even for me...!!
Another method is to select the code and then use the "#" button in the advanced editor to auto-insert the code tags.
This is what I love about Parallax forums, help is never far away from some of the brightest folks around. Thanks for that clue, that looks even easier !!
Mike B.
You're very welcome.
Out of a box of 60W bulbs, I'm a 38W around here.
This thread explains more about code tags:
http://forums.parallax.com/showthread.php/129690-How-to-post-program-code-in-the-forum.
Many of my posts are the consequence of a too often used dimmer switch
-MattG
there is a button in the advanced post thingy ( can't think of the right word ) that will add code tags for you.
Don't know if that helps at all, but it's all the wisdom I got
post 5
