Newbie posting question — Parallax Forums
w4fejw4fej Posts: 264
edited 2014-09-21 08:32 in General Discussion
I know there is a way to post code fragments in a post but I can't seem to locate how to make this happen. Could someone point me in the right direction?
Thanks. Mike B.
  • T ChapT Chap Posts: 4,260
    edited 2014-09-20 05:58
    Just use brackets [ ] at the top and bottom of your code and put code at the top and /code at the bottom inside the brackets.
    your code here
    edited 2014-09-20 06:01
    [ code ]
    Fragment
    [ /code ]
    But remove the spaces before and after brackets yields
    Fragment
  • w4fejw4fej Posts: 264
    edited 2014-09-20 06:02
    T Chap wrote: »
    your code here
    OK T_Chap, thanks. Looks simple enough even for me...!!
    edited 2014-09-20 08:05
    w4fej wrote: »
    Another method is to select the code and then use the "#" button in the advanced editor to auto-insert the code tags.
    642 x 103 - 15K
    edited 2014-09-20 08:09
    davejames wrote: »
    This is what I love about Parallax forums, help is never far away from some of the brightest folks around. Thanks for that clue, that looks even easier !!
    Mike B.
    edited 2014-09-20 08:15
    w4fej wrote: »
    This is what I love about Parallax forums, help is never far away from some of the brightest folks around. Thanks for that clue, that looks even easier !!.
    You're very welcome.
    Out of a box of 60W bulbs, I'm a 38W around here. :smile:
    This thread explains more about code tags:
    http://forums.parallax.com/showthread.php/129690-How-to-post-program-code-in-the-forum.
    edited 2014-09-20 10:38
    Yeah, but that's power consumption - your equivalent output is over a hundred :thumb:
    Many of my posts are the consequence of a too often used dimmer switch :tongue:
    -MattG
  • doggiedocdoggiedoc Posts: 2,250
    edited 2014-09-20 10:49
    Speaking of tags: did you know you can use the [noparse][noparse] tag to type things like
    [/noparse] without the added spaces?
  • ValeTValeT Posts: 308
    edited 2014-09-20 13:20
    Just an FYI,
    there is a button in the advanced post thingy ( can't think of the right word ) that will add code tags for you.
    Don't know if that helps at all, but it's all the wisdom I got :)
    edited 2014-09-21 06:56
    ValeT wrote: »
    post 5 :smile:
  • RDL2004RDL2004 Posts: 2,554
    I didn't know about the "no parse" tag, Excellent tip.
