Small Prop Board with VGA, PS2 and uSD
Has anybody designed and built a Prop board that contains only VGA, PS1 PS2 and uSD connectors? I'm looking for the smallest board that's available. It could be powered from USB, or it could have a connector for a wall-wart.
http://www.parallax.com/product/40003
http://www.parallax.com/product/32209
My "PatchBox" from a while back had 2xPS2, uSD, and either VGA or 2xRCA phono for AV. Small enough to fit in the sleeve of a matchbox (at 2"x1.35")
http://forums.parallax.com/showthread.php/108226-Introducing-PatchBox.TV-Propeller-in-a-Matchbox
It evolved somewhat into the Und3rb3lly board that's in my avatar / on the Smorgasboard PCB. I added C3 style memories on the reverse side, that can be individually populated. You can have 2 uSDs if desired.
There's also a 'cut version' that you select 2 cards to match up - so you choose color or greyscale vga, or tv, or whatever, via plugs or soldered through hole resistors.
http://forums.parallax.com/showthread.php/129292-quot-Und3rb3lly-quot-Upgrading-the-Propeller-Proto-Board-to-C3-style-memory
- I would also recommend the Quickstart and Quickstart Human Interface Board combo, but even as small as they are, there is a lot of wasted real estate.
- Next would be the combo of:
- VGA/PS/2 Breakout board
- uSD breakout board
- Small Propeller Board:
- Propeller Mini or
- M44D40+ Module or
- EEZeeProp Board or
- Depending on how many you need, you could always build this on a piece of protoboard using breakout boards.
- Bot-Thoughts has a very small form factor VGA breakout board for $7.
- You can make your own VGA breakout easily with the right type of DB15 connector. See this thread.
- I have seen people cut up and use half of a VGA extension cable to avoid the use of a breakout board. This one would do.
- Use panel mount cables for the PS/2 to negate the need for a breakout board. See these cables at Adafruit for $3.95.
- Sparkfun has PS/2 (AKA mini din 6) breakouts pretty cheap.
- Molex has a line of uSD connectors that are very small and have been used by a few here on the forums. I made this penny sized uSD breakout with one a while back just for fun.
- The breakout board method could get expensive fairly quickly though.
If you could provide any more details as to quantity, max PCB size, etc, I may have a few more ideas.I do have various boards (of course) but you wouldn't just have an introvert system would you? Wouldn't it have to connect or communicate with something else? Also I don't use physical PS/2 connectors as I prefer to forgo the gender-bender that comes with the PS/2 compatible USB keyboards and just have the keyboard plug into a USB socket as PS/2. The other thing is that some boards I have don't even bother with the bulky VGA connector as I have found it easier just to have an adapter plug, on some units I have an RJ45, on others pins headers, etc. But I do have boards (+case) with PS/2, RJ45 VGA, USB, RS232, RS422/485, SD, and optional Lantronix Xport in less than 3"sq, either bulk DC or USB powered. Pick a flavour.
The board I'm thinking of would be an "introvert" most of the time, but there are times when it would need to connect to the outside world. It would need to have either a serial port or a connector that would allow for expansion. So I think my ideal board would be something like a QuickStart, but with the touchpads replaced by VGA, PS2 and uSD connectors. It seems like there's enough room on the board to do this, especially given the fact that the C3 board has all of this and more.
So the main board would have USB, VGA, PS2 and uSD, and be powered from the USB. A daughter card could have another PS2, audio I/O, RTC and a WizNet chip. This way the main board would provide the basic functionality at the lowest cost. The current cost of the QuickStart plus the Human Interface board is $70. Even with the RadioShack price for the QuickStart the cost is still $43. I would hope that the card I'm proposing could be built for less than that.
https://www.tindie.com/products/Propellerpowered/propellerpowered-pocket-mini-computer/
