DATA I/O 60A help
Hello all,
I know this is posting not for a parallax product, but I know there are some amazing people here that give great advice.
I acquired a DATA I/O 60A from a swap meet. I powered it up, and the display said "SYSTEM OK", but the buttons did not work. Since I do not want vintage electronics to be forgotten I decided to try to fix it. I had to put it to the side because of some family troubles.
Finally, I could get back to it and see if I could figure out what is wrong. I powered it back up, and now the display says "SYSTEM EPROM ERR". After checking the maintenance manual it is saying it detected the wrong revision level of installed software, and that I should contact a DATA I/O service center. But there is none.
I used the prop to read the 4 EPROMs and since I don't know exactly what I am looking at, I looked for things that looked wrong. I am seeing a lot of locations that have $00 in them. So I am assuming the data is corrupt.
Google did not pull up anything that could offer help. That brings me to the forums.
~~~> Does anyone have any advice, or help?
I don't want to keep it around not working, because that would just give me the push I need to use it for parts. And I don't want to do that. Heck, I would give it away if someone would promise that it would not be lost or destroyed, but that person would have to pay for shipping.
TC
** EDIT **
Forgot to add EPROM data I pulled
324-0065-007 C.txt
324-0065-006 C.txt
324-0065-004 C.txt
324-0065-008 C.txt
TC
** EDIT **
324-0065-007 C.txt
324-0065-006 C.txt
324-0065-004 C.txt
324-0065-008 C.txt
The only way to be sure is to compare the eproms to known good ones or a backup file.
burning takes time...
And when you erase an EPROM, all cells are set to '1'. So it's common to set unused Bytes to FF to save the effort of burning anything into those locations.
I wondered how it was able to tell if the EPROM was bad.
That is the main problem. As of yet, I have not found anything or anyone that would have the EPROM data so I could compare what I have.
Would there be a way to tell if a location is "faded" without having anything to compare it to? (I am thinking not)
OR... you might get lucky with a blast of canned air (upside down) ... be sure and save the data that you are able to read in. Once you have a valid EEPROM image, you can sometimes re-vive the EEPROM with a re-program. Depending on the age however it might be better to replace the old EEPROM with a newer one.
If I use the prop, where it constantly reads the EPROM, and compares each location with the last read, would the data stabilize? or would it fluctuate?
It depends on whether the problem is an intermittent or solid one, but it's worth a try. The difficult part is determining which read is correct, particularly if you get several different results and more than one eprom is bad.
I completely agree with you, to me this thing looks awesome. That is why I can't have it sitting around non-functional
That is what I am afraid of. I sent an email to the person that has the operational manual, and the service manual on his website. I hope he can offer a way to either copy his EPROMs, or get the data so I can compare with what I have.
I can burn some new Eproms with the data in the text's. You just have to tell me the number on the EPROMs. (16K, 32K) ?
What is in the text, is what I pulled from the EPROMs. I don't know if the data is corrupt or not.
The part number on the EPROMs is " AM27128ADC".
I thought you got the text files from an archive site, so I don't know if they will work. We can try.
Next to fire up the old (1996) programmer computer to see if IT still work.
The filenames I posted are the labels that are on each EPROM. I tried Google, but I did not have any luck. But I also don't know all the tricks to make Google only search for what I want.
Would anyone have any suggestions on a good equivalent EPROM, that would not force me to eat ramen noodle soup for the next 6 months? I have seen EPROMs with a price tag of over $100USD
TC
http://www.ebay.com/itm/AM27128ADC-VINTAGE-IC-COLLECTIBLE-AMD-EPROM-27128-/390117298784
Maybe you can make a deal for a quantity purchase.
When I searched Google, all I got were hack-sites that just offered dead ends. I never thought of eBay. I messaged the seller to see if they would offer a guarantee that the EPROMs would functionally work. I am just waiting for a responce, and a responce from the person that has the data I need.
TC
Not a bad price. I bet he would ship 4 for 5.95.
I'm guessing that would be nadda, blank ?
I've got four 27128's that I can program for you, but do you know if the .txt files that you posted are good?
I hardly use eBay's search, since they ruined "improved" it several years ago.
Futurlec also sells similar eproms if you don't mind a potentially long wait for them to ship.
http://futurlec.com/ICEPROM.shtml
You are likely just dealing with bad contacts. Cleaning connectors and maybe replacing the ROM sockets would be in order.
I dont know if the files are good or not. But if you want to I would be willing to try and see if that fixes the problem.
I will have to check/try that out. I did not think of that. Thanks
I found this thread looking for manuals for my 60a. I just used it
to read some pals so it is working. my roms are labeled,
324-0065-078
324-0065-079
324-0065-080
324-0065-081
date is 1989. if it would help I can read these out in a few days.
Bruce
That would be great!! Thank you so much. And welcome to the forums, everyone on here is just like family.
Welcome to the forum, and thanks for the help!
If you could get the code in Motorola S format, I can blow some EPROM's for TC.
it as a 27512. A closer look shows me its a 27513 page mode eprom. Are
all of yours 27128 eproms? I appear to have 3 27513 and one I am not sure.
I'll look into it this evening, I just got off work and need a nap.
Bruce
There phone # is: (802)334-6088
