Multiple expression evaluation problems
adcOutput is currently ~ 1784 . Am I missing something obvious? The PWM is not consistent, it goes into the else loop (< 100) at the bottom consistently, and then every once in a while will sporadically go into one of the temperature pwm if statements.
I believe my problem is the way I'm evaluating the conditions, I just don't know how to fix it. Any advice on properly comparing 2 numbers in the same if statement would be appreciated.
repeat
onTime := 35555560
offTime := 711111
outa[c_pwmOutputPin] := 1
waitcnt(onTime + cnt)
outa[c_pwmOutputPin] := 0
waitcnt(offTime + cnt)
if (adcOutput > 100)
if (adcOutput > 2048)
'onTime := f.fmul(c_20CelsiusOn, pwmOutputHertzToClkCycles)
'onTime := f.fround(onTime)
'offTime := f.fmul(c_20CelsiusOff, pwmOutputHertzToClkCycles)
'offTime := f.fround(offTime)
onTime := 35555560
offTime := 711111
term.dec(adcOutput)
term.Tx(13)
term.str(string("20C On"))
term.tx(13)
term.str(string("20C off"))
term.tx(13)
elseif (adcOutput <= 2048) AND (adcOutput > 1802)
'onTime := f.fmul(c_25CelsiusOn, pwmOutputHertzToClkCycles)
'offTime := f.fmul(c_25CelsiusOff, pwmOutputHertzToClkCycles)
onTime := 35555560
offTime := 711111
term.dec(adcOutput)
term.Tx(13)
term.str(string("25C On"))
term.tx(13)
term.str(string("25C Off"))
term.tx(13)
elseif (adcOutput <= 1802) AND (adcOutput > 1556)
'onTime := f.fmul(c_30CelsiusOn, pwmOutputHertzToClkCycles)
'offTime := f.fmul(c_30CelsiusOff, pwmOutputHertzToClkCycles)
onTime := 33777777
offTime := 1777777
term.dec(adcOutput)
term.Tx(13)
term.str(string("30C On"))
term.tx(13)
term.str(string("30C Off"))
term.tx(13)
elseif (adcOutput <= 1556) AND (adcOutput > 1401)
'onTime := f.fmul(c_33CelsiusOn, pwmOutputHertzToClkCycles)
'offTime := f.fmul(c_33CelsiusOff, pwmOutputHertzToClkCycles)
onTime := 32355555
offTime := 3199999
term.dec(adcOutput)
term.Tx(13)
term.str(string("33C On"))
term.tx(13)
term.str(string("33C Off"))
term.tx(13)
elseif (adcOutput <= 1401) AND (adcOutput > 1253)
'onTime := f.fmul(c_35CelsiusOn, pwmOutputHertzToClkCycles)
'offTime := f.fmul(c_35CelsiusOff, pwmOutputHertzToClkCycles)
onTime := 31644444
offTime := 3911111
term.dec(adcOutput)
term.Tx(13)
term.str(string("35C On"))
term.tx(13)
term.str(string("35C Off"))
term.tx(13)
elseif (adcOutput <= 1253) AND (adcOutput > 1114)
'onTime := f.fmul(c_40CelsiusOn, pwmOutputHertzToClkCycles)
'offTime := f.fmul(c_40CelsiusOff, pwmOutputHertzToClkCycles)
onTime := 29866666
offTime := 5688888
term.dec(adcOutput)
term.Tx(13)
term.str(string("40C On"))
term.tx(13)
term.str(string("40C Off"))
term.tx(13)
elseif (adcOutput <= 1114) AND (adcOutput > 999)
'onTime := f.fmul(c_45CelsiusOn, pwmOutputHertzToClkCycles)
'offTime := f.fmul(c_45CelsiusOff, pwmOutputHertzToClkCycles)
onTime := 28444444
offTime := 7111111
term.dec(adcOutput)
term.Tx(13)
term.str(string("45C On"))
term.tx(13)
term.str(string("45C Off"))
term.tx(13)
else
term.str(string("Less than 100"))
term.tx(13)
term.dec(adcOutput)
term.tx(13)
