Multiple expression evaluation problems
adcOutput is currently ~ 1784 . Am I missing something obvious? The PWM is not consistent, it goes into the else loop (< 100) at the bottom consistently, and then every once in a while will sporadically go into one of the temperature pwm if statements.
I believe my problem is the way I'm evaluating the conditions, I just don't know how to fix it. Any advice on properly comparing 2 numbers in the same if statement would be appreciated.
repeat { onTime := 35555560 offTime := 711111 outa[c_pwmOutputPin] := 1 waitcnt(onTime + cnt) outa[c_pwmOutputPin] := 0 waitcnt(offTime + cnt) } if (adcOutput > 100) if (adcOutput > 2048) 'onTime := f.fmul(c_20CelsiusOn, pwmOutputHertzToClkCycles) 'onTime := f.fround(onTime) 'offTime := f.fmul(c_20CelsiusOff, pwmOutputHertzToClkCycles) 'offTime := f.fround(offTime) onTime := 35555560 offTime := 711111 term.dec(adcOutput) term.Tx(13) outa[c_pwmOutputPin] := 1 term.str(string("20C On")) term.tx(13) waitcnt(onTime + cnt) outa[c_pwmOutputPin] := 0 term.str(string("20C off")) term.tx(13) waitcnt(offTime + cnt) elseif (adcOutput <= 2048) AND (adcOutput > 1802) 'onTime := f.fmul(c_25CelsiusOn, pwmOutputHertzToClkCycles) 'onTime := f.fround(onTime) 'offTime := f.fmul(c_25CelsiusOff, pwmOutputHertzToClkCycles) 'offTime := f.fround(offTime) onTime := 35555560 offTime := 711111 term.dec(adcOutput) term.Tx(13) outa[c_pwmOutputPin] := 1 term.str(string("25C On")) term.tx(13) waitcnt(onTime + cnt) outa[c_pwmOutputPin] := 0 term.str(string("25C Off")) term.tx(13) waitcnt(offTime + cnt) elseif (adcOutput <= 1802) AND (adcOutput > 1556) 'onTime := f.fmul(c_30CelsiusOn, pwmOutputHertzToClkCycles) 'onTime := f.fround(onTime) 'offTime := f.fmul(c_30CelsiusOff, pwmOutputHertzToClkCycles) 'offTime := f.fround(offTime) onTime := 33777777 offTime := 1777777 term.dec(adcOutput) term.Tx(13) outa[c_pwmOutputPin] := 1 term.str(string("30C On")) term.tx(13) waitcnt(onTime + cnt) outa[c_pwmOutputPin] := 0 term.str(string("30C Off")) term.tx(13) waitcnt(offTime + cnt) elseif (adcOutput <= 1556) AND (adcOutput > 1401) 'onTime := f.fmul(c_33CelsiusOn, pwmOutputHertzToClkCycles) 'onTime := f.fround(onTime) 'offTime := f.fmul(c_33CelsiusOff, pwmOutputHertzToClkCycles) 'offTime := f.fround(offTime) onTime := 32355555 offTime := 3199999 term.dec(adcOutput) term.Tx(13) outa[c_pwmOutputPin] := 1 term.str(string("33C On")) term.tx(13) waitcnt(onTime + cnt) outa[c_pwmOutputPin] := 0 term.str(string("33C Off")) term.tx(13) waitcnt(offTime + cnt) elseif (adcOutput <= 1401) AND (adcOutput > 1253) 'onTime := f.fmul(c_35CelsiusOn, pwmOutputHertzToClkCycles) 'onTime := f.fround(onTime) 'offTime := f.fmul(c_35CelsiusOff, pwmOutputHertzToClkCycles) 'offTime := f.fround(offTime) onTime := 31644444 offTime := 3911111 term.dec(adcOutput) term.Tx(13) outa[c_pwmOutputPin] := 1 term.str(string("35C On")) term.tx(13) waitcnt(onTime + cnt) outa[c_pwmOutputPin] := 0 term.str(string("35C Off")) term.tx(13) waitcnt(offTime + cnt) elseif (adcOutput <= 1253) AND (adcOutput > 1114) 'onTime := f.fmul(c_40CelsiusOn, pwmOutputHertzToClkCycles) 'onTime := f.fround(onTime) 'offTime := f.fmul(c_40CelsiusOff, pwmOutputHertzToClkCycles) 'offTime := f.fround(offTime) onTime := 29866666 offTime := 5688888 term.dec(adcOutput) term.Tx(13) outa[c_pwmOutputPin] := 1 term.str(string("40C On")) term.tx(13) waitcnt(onTime + cnt) outa[c_pwmOutputPin] := 0 term.str(string("40C Off")) term.tx(13) waitcnt(offTime + cnt) elseif (adcOutput <= 1114) AND (adcOutput > 999) 'onTime := f.fmul(c_45CelsiusOn, pwmOutputHertzToClkCycles) 'onTime := f.fround(onTime) 'offTime := f.fmul(c_45CelsiusOff, pwmOutputHertzToClkCycles) 'offTime := f.fround(offTime) onTime := 28444444 offTime := 7111111 term.dec(adcOutput) term.Tx(13) outa[c_pwmOutputPin] := 1 term.str(string("45C On")) term.tx(13) waitcnt(onTime + cnt) outa[c_pwmOutputPin] := 0 term.str(string("45C Off")) term.tx(13) waitcnt(offTime + cnt) else term.str(string("Less than 100")) term.tx(13) term.dec(adcOutput) term.tx(13)
