Where is the Propeller Manual?
David Betz
I know I'm probably just looking in the wrong place but I spent some time just now trying unsuccessfully to find the Propeller Manual on the Parallax web site. I couldn't find either the downloadable copy or a print copy I could purchase. Where is the Propeller Manual hiding?
David
David
edit: Chris posted while I was grabbing the screenshot,
Why are the Propeller and the docs so hard to find on the web site? Seems I'm not the only one who has found that to be so.
FTFY
It is a shame that all this good stuff is lost and or so hard to find - Anything Propeller should just jump right off the website at you and be easy to find in multiple ways.
Heater,
I just clicked on Microcontrollers / Propeller / Chips. Then click on any of the available packages for the Propeller chip. Under Downloads & Documentation is a link to the datasheet, manual, etc. This is where I would expect to find it. Is there another place you think we should have it available? It can be found using the search window as well.
That page already has a link to the Propeller data sheet but maybe a link to the manual would be helpful too?
David
FYI, and ICAOC (in case anyone cares), the two following links reference the same v1.2 Propeller manual - the one minus the tutorial:
http://www.parallax.com/downloads/p8x32a-propeller-manual
http://www.parallax.com/downloads/propeller-manual
Where would the v1.01 manual be found?
Not on the Parallax site:
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Propeller%20Manual%20v1.01&safe=off
Should be in the Sticky, (it may be but I haven't checked.
http://www.farnell.com/datasheets/82523.pdf
I will notify Marketing of your suggestion right now. Your point is valid. :thumb:
They still point to the old Parallaxsemiconductor site.
Dave,
If I may be so bold...why would you want the older version? As I recall there were issues that were solved in the newer version and leaving the older one online might lead to someone finding it and assuming it is current, causing some tech calls and hard feelings.
The Chapter three was priceless when I was first learning the Prop. I guess there should be a caveat when directing someone to the old manual.
You may certainly be bold with me, Sir.
Why the older version? - for the missing content (aka "Chapter 3"), of course.
I suspect the "powers that be" assumed the Learn material would take its place.
Nothing can help us Mac and Linux users!
Parallax could create such a document.... this is the bootleg version as I believe it doesn't have the right copyright boilerplate.
IMHO, management has been asleep at the wheel about providing this to protect their revenue source. It is a bit sad.
Attachment PDF removed as a copyrighted version was provided by Publison of the same.
It should return in the newest version of the manual.
George,
Isn't that what I posted in # 23?
I included a copyright.
I believe because it was included in the Help menu of the Propeller Tool.
Paul
Glad to see that the contents of the "missing" chapter were published here for now.
That chapter was moved from the "printed" manual to the on-line help (both Propeller Tool and on the web at one time, I believe) because we wanted to update it and were gradually moving away from bulk printed matter because of maintenance hassles it causes. Soon after, we got heavily involved in multi-platform efforts and haven't revisited this yet... but we will now! ;-)
We'll take care of these loose ends in the next few weeks and it will be more visible and available. Sorry for the confusion.
