Where is the Propeller Manual? — Parallax Forums
David BetzDavid Betz Posts: 14,530
edited 2014-08-29 23:25 in Propeller 1
I know I'm probably just looking in the wrong place but I spent some time just now trying unsuccessfully to find the Propeller Manual on the Parallax web site. I couldn't find either the downloadable copy or a print copy I could purchase. Where is the Propeller Manual hiding?
David
    edited 2014-08-26 16:41
    Search box: propeller manual, then follow 3rd (for me) entry
    edited 2014-08-26 16:42
    It also comes with the propeller tool download.
    edited 2014-08-26 16:47
    kuroneko wrote: »
    Thanks! I tried searching somewhere along the way but I must have been in a subpage that searched differently than the main page because I didn't find it. I guess from the page I found it isn't available anymore in print. That's too bad. Also, I was surprised that I couldn't find it under either "Books" or "Downloads". Now that I know it isn't available in print form that explains why it isn't under "Books" but it seems like it should be under "Downloads".
    edited 2014-08-26 17:07
    Also if you have the Propeller Tool installed and you click on the Help Menu, Propeller Manual is available which brings up the copy of the PDF already installed on your PC. :thumb:
    edited 2014-08-26 17:11
    I always found it easiest to find it here:
    edit: Chris posted while I was grabbing the screenshot, :smile:
    507 x 440 - 103K
    edited 2014-08-27 01:43
    The Propeller Tool does not run here.
    Why are the Propeller and the docs so hard to find on the web site? Seems I'm not the only one who has found that to be so.
    edited 2014-08-27 03:08
    Thanks Chris but I don't use the Propeller Tool since I do all of my work on a Macintosh using PropGCC. Anyway, thanks to some suggestions here, I found it along with the Propeller data sheet so I'm all set for now. You might want to consider adding it to the downloads section.
  • PaulPaul Posts: 263
    edited 2014-08-27 06:55
    Heater. wrote: »
    Why I]is anything[/I so hard to find on the web site? Seems I'm not the only one who has found that to be so.
    FTFY
    edited 2014-08-27 07:06
    Here's the v1.01 of the Propeller Manual that has the since deleted Chapter 3 Tutorial.
    It is a shame that all this good stuff is lost and or so hard to find - Anything Propeller should just jump right off the website at you and be easy to find in multiple ways.
    edited 2014-08-27 08:23
    Heater. wrote: »
    The Propeller Tool does not run here. Why are the Propeller and the docs so hard to find on the web site? Seems I'm not the only one who has found that to be so.
    Heater,
    I just clicked on Microcontrollers / Propeller / Chips. Then click on any of the available packages for the Propeller chip. Under Downloads & Documentation is a link to the datasheet, manual, etc. This is where I would expect to find it. Is there another place you think we should have it available? It can be found using the search window as well.
    edited 2014-08-27 08:39
    Heater,
    I guess I expected to find it somewhere other than in the store. Maybe put a link to it here as well? http://www.parallax.com/microcontrollers/propeller
    That page already has a link to the Propeller data sheet but maybe a link to the manual would be helpful too?
    David
    edited 2014-08-27 09:01
    FYI, and ICAOC (in case anyone cares), the two following links reference the same v1.2 Propeller manual - the one minus the tutorial:
    http://www.parallax.com/downloads/p8x32a-propeller-manual
    http://www.parallax.com/downloads/propeller-manual
    Where would the v1.01 manual be found?
    edited 2014-08-27 09:09
    davejames wrote: »
    Not on the Parallax site:
    https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=Propeller%20Manual%20v1.01&safe=off
    Should be in the Sticky, (it may be but I haven't checked.
    http://www.farnell.com/datasheets/82523.pdf
    edited 2014-08-27 09:16
    David Betz wrote: »
    David
    I will notify Marketing of your suggestion right now. Your point is valid. :thumb:
    edited 2014-08-27 09:19
    Maybe no one else brought this up, (I thought I brought this up before), but the links in the sticky are no good.
    They still point to the old Parallaxsemiconductor site.
    1024 x 601 - 81K
    davejames wrote: »
    Dave,
    If I may be so bold...why would you want the older version? As I recall there were issues that were solved in the newer version and leaving the older one online might lead to someone finding it and assuming it is current, causing some tech calls and hard feelings. :innocent:
    edited 2014-08-27 09:26
    Dave,
    The Chapter three was priceless when I was first learning the Prop. I guess there should be a caveat when directing someone to the old manual.
    edited 2014-08-27 09:29
    Publison wrote: »
    Maybe someone could extract that chapter and make it available separately?
    edited 2014-08-27 09:53
    You may certainly be bold with me, Sir. :smile:
    Why the older version? - for the missing content (aka "Chapter 3"), of course.
    edited 2014-08-27 09:54
    David Betz wrote: »
    I suspect the "powers that be" assumed the Learn material would take its place.
    edited 2014-08-27 09:59
    To be fair to Parallax, the content of the tutorials where transferred to the Propeller help menu, but that does not help the Mac/Linux users.
    edited 2014-08-27 10:16
    Chapter Three attached with Copyright Info.
    edited 2014-08-27 10:17
    Publison wrote: »
    Nothing can help us Mac and Linux users! :innocent:
    edited 2014-08-27 10:41
    How about an excerpt of the Tutorial Chapter from V.1.01 of the Propeller Manual in pdf form?
    Parallax could create such a document.... this is the bootleg version as I believe it doesn't have the right copyright boilerplate.
    IMHO, management has been asleep at the wheel about providing this to protect their revenue source. It is a bit sad.
    Attachment PDF removed as a copyrighted version was provided by Publison of the same.
    600 x 403 - 64K
  • pik33pik33 Posts: 2,417
    edited 2014-08-27 11:36
    Why was this chapter deleted?
    It should return in the newest version of the manual.
    edited 2014-08-27 11:51
    George,
    Isn't that what I posted in # 23?
    I included a copyright.
    edited 2014-08-27 11:53
    pik33 wrote: »
    I believe because it was included in the Help menu of the Propeller Tool.
  • doggiedocdoggiedoc Posts: 2,255
    edited 2014-08-27 11:59
    Sounds a bit harsh George. I think Parallax goes out of it's way to provide for its customers. As for "to protect their revenue source" comment. I think you are wrong. But even so, they have every right to do so.
    Paul
    edited 2014-08-27 12:00
    So whose idea was that? They are in need of a public flogging. In the nicest possible way of course.
  • Jeff MartinJeff Martin Posts: 762
    edited 2014-08-29 12:35
    Hi Everyone,
    Glad to see that the contents of the "missing" chapter were published here for now.
    That chapter was moved from the "printed" manual to the on-line help (both Propeller Tool and on the web at one time, I believe) because we wanted to update it and were gradually moving away from bulk printed matter because of maintenance hassles it causes. Soon after, we got heavily involved in multi-platform efforts and haven't revisited this yet... but we will now! ;-)
    We'll take care of these loose ends in the next few weeks and it will be more visible and available. Sorry for the confusion.
