NES Connector Update — Parallax Forums
Ken GraceyKen Gracey Posts: 7,416
edited 2014-08-27 06:23 in Propeller 1
Hey there,
Just wanted to provide OBC and Co. with an update on the request to get the NES PCB connectors. We're picking them up in China today and we'll have them at Parallax on Tuesday. Below Aristides is opening the box and I've taken a closeup photo of the connectors. Aristides is very hot as you can see - it's 98F here and 70% humidity. I think these connectors will sell at $1.95 each. This isn't cheap, but it's reasonable for a prototype or several. If you need a bucket of them we can make a better deal.
Over and out!
    edited 2008-09-18 14:10
    Temps like that are the reason I don't live in Florida anymore. [noparse]:)[/noparse]
    Ken, what does it feel like to get out of a shower, and by the time you get dressed you need another shower? [noparse]:)[/noparse]
    Thanks for the update Ken! There are several of us looking forward to getting our hands on those.
    OBC
    New to the Propeller?
    Getting started with a Propeller Protoboard?
    Check out: Introduction to the Proboard & Propeller Cookbook 1.4
    Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
    Got an SD card connected? - PropDOS
  • Nick McClickNick McClick Posts: 1,003
    edited 2008-09-18 17:31
    What's the spacing / diameter on the pin headers? They look a little thick for a standard perf board, are you going to mount them on a breakout board?
    Concentrate on understanding the problem, not applying the tool
  • parts-man73parts-man73 Posts: 830
    edited 2008-09-18 17:39
    Nick McClick said...
    I noticed the same thing though, they do look like large pins.
    Brian
    uController.com - home of SpinStudio - the modular Development system for the Propeller
    PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
    SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
  • Aristides AlvarezAristides Alvarez Posts: 488
    edited 2008-09-20 09:50
    Hi OBC,
    After spending some time in Southern China, you’ll find Florida’s weather very dry and pleasant.
    The key to endure the weather over here is to find some shade and hopefully a room with AC. Entering in a lethargic mode could help keep the body temperature low.
    Ken volunteer to make a demonstration for you as you can see in the picture below.
    Aristides Alvarez
    Education Manager
    640 x 480 - 94K
  • trodosstrodoss Posts: 577
    edited 2008-09-26 03:10
    @Ken, Aristides, and everyone else at Parallax:
    THANK YOU! You guys are the best!
    NES Controller Socket - On the Online Store! (Click Here)
    Post Edited (trodoss) : 9/26/2008 3:44:13 AM GMT
    edited 2008-09-26 03:25
    The following is a good resource on the NES Controller -- Chapter 6 sample from the "Game Programming for the Propeller Powered HYDRA"
    www.parallax.com/dl/docs/prod/prop/Hydra-Ch6All-v1.0.pdf
    [noparse][[/noparse]Edit] The following is also useful (linked to the item description)
    http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/450-32360%20Pin%20Out.jpg
    Post Edited (trodoss) : 9/26/2008 3:36:16 AM GMT
    edited 2008-09-26 13:10
    Been trying to figure out what to put with my NES connectors order that will bring it to $10. [noparse]:)[/noparse]
    Maybe it's time to play with the SX too.. [noparse]:)[/noparse]
    THANKS KEN!!!!!!!!
    OBC
    edited 2008-09-26 13:35
    OBC said...
    No! nono.gif We don't want you distracted, you have a book to work on!
    Brian
    edited 2008-09-26 14:03
    </me reaches for an SX board>SLAP!
    Ouch! Ok.. I'll order some transistors or something instead.. [noparse]:)[/noparse]
    @parts-man: Do keep us apprised on your breadboard for this connector.
    OBC
    edited 2008-09-26 15:34
    @OBC -- Maybe you want to do a project with an SX28 communicating with the Propeller?
    It is kind of like SIP sockets, and single row headers. Can't get enough of those [noparse];)[/noparse] Just pad you order with something like that.
    The NES controller is such a great 3.3v human input device and with the Propeller! It is fairly easy to implement and is "retro chic." Too bad that so many of the NES controllers get made into things like belt buckles, etc. Hey, maybe there is a project... Propeller-powered belt buckle that doubles for a game system [noparse];)[/noparse]
  • ChuckGChuckG Posts: 13
    edited 2008-09-28 21:26
    A little off topic, but does anyone have a part # or source for the Hydra expansion port connector?
  • TimmooreTimmoore Posts: 1,031
    edited 2008-09-28 21:45
    Chuck, this is the vertical one but given this you should be able to find it. http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=S3300-ND
    I used this to interface to a hydra expansion board but note its a right angle socket and I believe hydra needs the straight.
    edited 2008-10-02 02:13
    and Ken single handily brings the NES controller back into fashion...
    hackaday.com/2008/09/30/a-parallax-nes-controller-connector/#comments
    Thanks again Ken!
    OBC
    edited 2008-12-28 17:01
    I thought I'd mention. I finished an adapter circuit board for these connectors a little while ago. I now realize I never formally announced it. They are now available on uController.com
    The Adapter has a socket to plug into a SpinStudio, or there is a 6 pin connector that can be plugged into a solderless breadboard in the same manner as the SD card adapter that many of you are familiar with.
    Brian
    998 x 701 - 251K
    edited 2008-12-28 17:28
    I can vouch for this being a "must have" item for the Propeller.
    Well done Brian!
    OBC
    Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
  • bbneobbneo Posts: 1
    edited 2014-08-24 09:00
    Sorry to dig out this old thread but it there a possibility to get these NES Controller sockets again?
  • VIRANDVIRAND Posts: 656
    edited 2014-08-26 16:46
    I've TOO been wondering if there's still a significant game writing/playing community for the propeller. I have not lived up to my own expectations in the past few years and it seems to me that most of the platform hardware necessary to play old propeller games is not being sold anymore... I can't find any more Hydras, Demoboards, etc. :(
    edited 2014-08-26 20:55
    VIRAND wrote: »
    That's where you might be mistaken.. :)
    It's true, Parallax tends to be a bit more into Propeller machines that either roll, walk, or fly, but Propeller gaming/writing community still exists and is working on interesting projects and tools behind the scenes.
    The Hydra can still be purchased from Xgamestation.com.
    Propellerpowered's PEB board supports the more common Wii nunchuck controller as well as VGA and TV out for Propeller games.
    Also, we are getting ready to launch our new Micromite Companion product (we're filling pre-orders this week) which will allow easy access to Propeller sprites and tiles.
    Most of the materials that are relevant to Propeller gaming can be found on our forums, including all the important developments that were posted on the old Parallax Hydra forums.
    Edit: I forgot another important Propeller gaming project that is in development right now.. The Lamestation.
    Jeff
  • blittledblittled Posts: 681
    edited 2014-08-27 05:02
    XgameStation is still active but seems out of date. Andre LaMothe launched a new website ic0nstrrux http://www.ic0nstrux.com/ which also sells the Hydra
  • Ken GraceyKen Gracey Posts: 7,416
    bbneo wrote: »
    Seems we're out of stock. We custom made this part and kept it in stock for a long time because the minimum order was around 10,000 units.
    I can check with our friends in China, though. How many do you need?
