NES Connector Update
Hey there,
Just wanted to provide OBC and Co. with an update on the request to get the NES PCB connectors. We're picking them up in China today and we'll have them at Parallax on Tuesday. Below Aristides is opening the box and I've taken a closeup photo of the connectors. Aristides is very hot as you can see - it's 98F here and 70% humidity. I think these connectors will sell at $1.95 each. This isn't cheap, but it's reasonable for a prototype or several. If you need a bucket of them we can make a better deal.
Over and out!
Over and out!
Ken, what does it feel like to get out of a shower, and by the time you get dressed you need another shower? [noparse]:)[/noparse]
Thanks for the update Ken! There are several of us looking forward to getting our hands on those.
OBC
New to the Propeller?
Getting started with a Propeller Protoboard?
Check out: Introduction to the Proboard & Propeller Cookbook 1.4
Got an SD card connected? - PropDOS
Concentrate on understanding the problem, not applying the tool
They probably won't, but I will
I noticed the same thing though, they do look like large pins.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
After spending some time in Southern China, you’ll find Florida’s weather very dry and pleasant.
The key to endure the weather over here is to find some shade and hopefully a room with AC. Entering in a lethargic mode could help keep the body temperature low.
Ken volunteer to make a demonstration for you as you can see in the picture below.
Aristides Alvarez
Education Manager
THANK YOU! You guys are the best!
NES Controller Socket - On the Online Store! (Click Here)
Post Edited (trodoss) : 9/26/2008 3:44:13 AM GMT
www.parallax.com/dl/docs/prod/prop/Hydra-Ch6All-v1.0.pdf
[noparse][[/noparse]Edit] The following is also useful (linked to the item description)
http://www.parallax.com/Portals/0/Downloads/docs/prod/compshop/450-32360%20Pin%20Out.jpg
Post Edited (trodoss) : 9/26/2008 3:36:16 AM GMT
Maybe it's time to play with the SX too.. [noparse]:)[/noparse]
THANKS KEN!!!!!!!!
OBC
No!
Brian
Ouch! Ok.. I'll order some transistors or something instead.. [noparse]:)[/noparse]
@parts-man: Do keep us apprised on your breadboard for this connector.
OBC
It is kind of like SIP sockets, and single row headers. Can't get enough of those [noparse];)[/noparse] Just pad you order with something like that.
The NES controller is such a great 3.3v human input device and with the Propeller! It is fairly easy to implement and is "retro chic." Too bad that so many of the NES controllers get made into things like belt buckles, etc. Hey, maybe there is a project... Propeller-powered belt buckle that doubles for a game system [noparse];)[/noparse]
I used this to interface to a hydra expansion board but note its a right angle socket and I believe hydra needs the straight.
hackaday.com/2008/09/30/a-parallax-nes-controller-connector/#comments
Thanks again Ken!
OBC
The Adapter has a socket to plug into a SpinStudio, or there is a 6 pin connector that can be plugged into a solderless breadboard in the same manner as the SD card adapter that many of you are familiar with.
Brian
Well done Brian!
OBC
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
That's where you might be mistaken..
It's true, Parallax tends to be a bit more into Propeller machines that either roll, walk, or fly, but Propeller gaming/writing community still exists and is working on interesting projects and tools behind the scenes.
The Hydra can still be purchased from Xgamestation.com.
Propellerpowered's PEB board supports the more common Wii nunchuck controller as well as VGA and TV out for Propeller games.
Also, we are getting ready to launch our new Micromite Companion product (we're filling pre-orders this week) which will allow easy access to Propeller sprites and tiles.
Most of the materials that are relevant to Propeller gaming can be found on our forums, including all the important developments that were posted on the old Parallax Hydra forums.
Edit: I forgot another important Propeller gaming project that is in development right now.. The Lamestation.
Jeff
Seems we're out of stock. We custom made this part and kept it in stock for a long time because the minimum order was around 10,000 units.
I can check with our friends in China, though. How many do you need?
