Propeller Servo Controller Code
ajward
Hey All...
I have a question concerning the code that resides in the Prop Servo Controller. If I understand correctly, the enabled servos are initialized (centered) in this section of code:
The initialization works, but for my application (my biped Wally) it happens just too quickly.
https://www.youtube.com/watch?v=gXV6dJJyQ4o
It is certainly impressive to see a "pile" of servos and metal parts snap to attention, but it ofter results in Wally falling over which lessens the impressiveness. :-)
I'd like to slow down the process, but I'm not sure how to slowly bring the hip and knee servos to the center position (~750) from different starting positions. The goal would be to have him in a squatting position and slowly stand erect.
Any guidance would be greatly appreciated!
Amanda
''Initialize Loop ------------------------------------------------------------------
repeat temp from 0 to 15 '' Initialize ALL servos to center position that are Enabled on Startup
If ((Enabled & |<temp)>>temp) == 0 '' Check if servo is enabled on startup
PW := 750 '' Set default Servo Width value
If LoadDetect == 1 '' Check if pre-defined Servo position has been selected
PW_highbyte := EEPROM.RandomRead(ServoCh0+(temp<<1)+0) '' Load pre-defined HIGH BYTE
PW_lowbyte := EEPROM.RandomRead(ServoCh0+(temp<<1)+1) '' Load pre-defined LOW BYTE
if PW < 250 or PW > 1250 '' Check if pre-defined Servo position is within valid range
PW := 750 '' ...If not default to center position
Servo.Set(temp,PW<<1) '' Initialize servo position
Amanda
I would try to use the Start Up Mode to set the servos to the idle position (flat):
EDD Startup Servo Mode Syntax: !SCEDD <mode> <CR> Reply: DL <mode> This command sets whether the PSCU centers all servo channels on startup (mode 0) or uses custom startup positions stored in EEPROM (mode 1). In mode 1 you can set a custom startup position for each servo channel using the default position command below. To set the Startup Servo Mode, the following must be sent to the PSCU: !SCEDD followed by a byte value of 0 for default (center) or 1 for custom and finally a carriage return ($0D). The following code can be used to set the startup servo mode to 1 using a BASIC Stamp 2. ' {$STAMP BS2} ' {$PBASIC 2.5} Sdat PIN 15 ' Serial Data I/O Pin Baud CON 396 ' Constant For 2400 Baud buff VAR Byte(3) ' Temporary Variable (Array) SetPort: DEBUG "Setting Startup Servo Mode...", CR SEROUT Sdat, Baud+$8000, ["!SCPSS", 1, CR] SERIN Sdat, Baud,500, SetPort, [STR buff\3] DEBUG "Startup Mode: ", buff(0), buff(1), DEC1 buff(2), CR DEBUG "Please reset PSCU or cycle power now." STOP Note: The PSCU must be reset after this command is sent or power must be cycled to activate the change.Then use the Position Command in you main program :
Position Command Set Position of a Servo Channel Syntax: !SC <channel> <ramp speed> <lowbyte> <highbyte> <CR> Reply: None To move a servo to a location you must write a position command to the PSCU. Each position command is comprised of the preamble, the channel, the ramp speed, lowbyte/highbyte of the pulse width in 2 µs increments and a carriage return ($0D). The preamble is !SC. The channel is a byte value from 0 15 (16 31 if this is the second unit in a network). The ramp speed is a byte value from 0 63 that controls the speed the servo moves to its new position. ' {$STAMP BS2} ' {$PBASIC 2.5} ch VAR Byte pw VAR Word ra VAR Byte Sdat CON 15 baud CON 396 ra = 7 ch = 11 DO pw = 1100 SEROUT Sdat, Baud+$8000,["!SC", ch, ra, pw.LOWBYTE, pw.HIGHBYTE, CR] PAUSE 1000 pw = 300 SEROUT Sdat, Baud+$8000,["!SC", ch, ra, pw.LOWBYTE, pw.HIGHBYTE, CR] PAUSE 1000 LOOPto set the centering using the ramp speed function, with 63 being the slowest ramping.
Maybe Beau will chime in as he is the servo guru.
Jim
The only way I can see doing it is to ensure that the servos are already close to center when you turn on the power.
If you pre-program the firmware with the !SCEDD command for the servos involved, That servo position would be saved into the upper EEPROM. On the next startup, the servos would not move, ( if programmed to the resting pulse, say 1000 for "lay down".
Then the servo.ramp command could be issued from the top object, (or BS2) to bring those servos up with the "delay"
There are provisions in the servo.spin code for saving starting positions in the upper EEPROM. They don'y have to be center.
