Propeller Servo Controller Code — Parallax Forums
ajwardajward Posts: 1,130
edited 2014-08-24 12:14 in General Discussion
Hey All...
I have a question concerning the code that resides in the Prop Servo Controller. If I understand correctly, the enabled servos are initialized (centered) in this section of code:
''Initialize Loop ------------------------------------------------------------------
     repeat temp from 0 to 15   '' Initialize ALL servos to center position that are Enabled on Startup
       If ((Enabled & |<temp)>>temp) == 0               '' Check if servo is enabled on startup
          PW := 750                                     '' Set default Servo Width value
          If LoadDetect == 1                            '' Check if pre-defined Servo position has been selected
             PW_highbyte := EEPROM.RandomRead(ServoCh0+(temp<<1)+0)             '' Load pre-defined HIGH BYTE
             PW_lowbyte  := EEPROM.RandomRead(ServoCh0+(temp<<1)+1)             '' Load pre-defined LOW BYTE
             if PW < 250 or PW > 1250                   '' Check if pre-defined Servo position is within valid range
                PW := 750                               '' ...If not default to center position
          Servo.Set(temp,PW<<1)                         '' Initialize servo position
The initialization works, but for my application (my biped Wally) it happens just too quickly.
https://www.youtube.com/watch?v=gXV6dJJyQ4o
It is certainly impressive to see a "pile" of servos and metal parts snap to attention, but it ofter results in Wally falling over which lessens the impressiveness. :-)
I'd like to slow down the process, but I'm not sure how to slowly bring the hip and knee servos to the center position (~750) from different starting positions. The goal would be to have him in a squatting position and slowly stand erect.
Any guidance would be greatly appreciated!
Amanda
    edited 2014-08-24 09:20
    Amanda,
    I would try to use the Start Up Mode to set the servos to the idle position (flat):
    EDD – Startup Servo Mode Syntax: “!SCEDD” <mode> <CR>
    Reply: “DL” <mode>
    This command sets whether the PSCU centers all servo channels on startup (mode 0) or uses custom
    startup positions stored in EEPROM (mode 1). In mode 1 you can set a custom startup position for each
    servo channel using the default position command below. To set the Startup Servo Mode, the following
    must be sent to the PSCU: “!SCEDD” followed by a byte value of 0 for default (center) or 1 for custom
    and finally a carriage return ($0D). The following code can be used to set the startup servo mode to 1
    using a BASIC Stamp 2.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    Sdat PIN 15 ' Serial Data I/O Pin
    Baud CON 396 ' Constant For 2400 Baud
    buff VAR Byte(3) ' Temporary Variable (Array)
    SetPort:
     DEBUG "Setting Startup Servo Mode...", CR
     SEROUT Sdat, Baud+$8000, ["!SCPSS", 1, CR]
     SERIN Sdat, Baud,500, SetPort, [STR buff\3]
     DEBUG "Startup Mode: ", buff(0), buff(1), DEC1 buff(2), CR
     DEBUG "Please reset PSCU or cycle power now."
     STOP
    Note: The PSCU must be reset after this command is sent or power must be cycled to activate the
    change.
    Then use the Position Command in you main program :
    Position Command – Set Position of a Servo Channel Syntax: “!SC” <channel> <ramp speed> <lowbyte> <highbyte> <CR>
    Reply: None
    To move a servo to a location you must write a position command to the PSCU. Each position command
    is comprised of the preamble, the channel, the ramp speed, lowbyte/highbyte of the pulse width in 2 µs
    increments and a carriage return ($0D). The preamble is “!SC”. The channel is a byte value from 0 – 15
    (16 – 31 if this is the second unit in a network). The ramp speed is a byte value from 0 – 63 that
    controls the speed the servo moves to its new position.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ch VAR Byte
    pw VAR Word
    ra VAR Byte
    Sdat CON 15
    baud CON 396
    ra = 7
    ch = 11
    DO
     pw = 1100
     SEROUT Sdat, Baud+$8000,["!SC", ch, ra, pw.LOWBYTE, pw.HIGHBYTE, CR]
     PAUSE 1000
     pw = 300
     PAUSE 1000
    LOOP
    to set the centering using the ramp speed function, with 63 being the slowest ramping.
    Maybe Beau will chime in as he is the servo guru.
    Jim
  • bte2bte2 Posts: 154
    edited 2014-08-24 11:04
    Can't be done because there is no MCU feedback of the servo's position. The servo will snap to center as fast as possible as soon as it gets the pulses.
    The only way I can see doing it is to ensure that the servos are already close to center when you turn on the power.
    edited 2014-08-24 11:58
    +1. Possibly try to always power down the bot (and power up) in a stable home configuration, be it standing, sitting, or lying down
    edited 2014-08-24 12:09
    bte2 wrote: »
    If you pre-program the firmware with the !SCEDD command for the servos involved, That servo position would be saved into the upper EEPROM. On the next startup, the servos would not move, ( if programmed to the resting pulse, say 1000 for "lay down".
    Then the servo.ramp command could be issued from the top object, (or BS2) to bring those servos up with the "delay"
    bte2 wrote: »
    There are provisions in the servo.spin code for saving starting positions in the upper EEPROM. They don'y have to be center.
