Any brainiacs willing to better comment P1V code for us mere mortals? — Parallax Forums
markmark Posts: 253
edited 2014-09-09 23:41 in Propeller 1
:innocent:
So I tried prepping myself a bit before checking out the P1V code by reading some verilog tutorials. I'd be lying if I said I understood it all and was ready to go, but I figured I could at least start peeking at the code and do a bit of research when something wasn't clear. It didn't take more than a couple of lines into cog.v to be completely lost by nothing more than many of the names used for "constants" (inputs/outputs/parameters). Of course, I also don't know what things like 'ena' (enable?) and 'ena_bus', etc. etc. are supposed to be for. Maybe it's just my noobishness, but to me it doesn't appear to be for the faint of heart. If this code makes sense to anyone, I sincerely hope they would be willing to comment the code better (no rush! Just would appreciate if someone would undertake it!). Any takers?
-Mark
    edited 2014-08-22 18:37
    I'm far from a brainiac but I am taking notes any making an annotated better commented copy. As usual, I'm in no hurry...
  • markmark Posts: 253
    edited 2014-08-22 18:50
    mindrobots wrote: »
    Great! I hope you'll share your progress every now and then :)
    edited 2014-08-22 19:13
    I will try an post some pieces to the puzzle here over the w/e. I am only new to Verilog so there may be some errors but on the whole it will be useful.
    edited 2014-08-22 19:37
    Cool! Looking forward to it!
    edited 2014-08-22 20:19
    Here is a start. The Verilog files go together like this map. I am unsure of the higher levels of the FPGA files at present.
     P8X32A_Emulation
                                                         top.???
                                             dig.v                              ???
                                 cog.v                             hub.v
               cog_alu.v  cog_ctr.v  cog_vid.v  cog_ram.v         hub_mem.v
    Perhaps someone with an understanding of Quartus/FPGA can update the drawing?
    edited 2014-08-22 20:47
    Cluso99 wrote: »
     P8X32A_Emulation
                                                         top.???
                                             dig.v                              ???
                                 cog.v                             hub.v
    I tried a few times to post the drawing file (spin) but the forum refuses! I will try again later.
    This is what I gathered as well. I'm guessing any top file would be FPGA specific. I don't currently have one, I was just browsing the code with Scriptum.
  • pik33pik33 Posts: 2,415
    edited 2014-08-22 22:26
    This top.??? is top.tdf, another ??? is tim.tdf which generates some clocks.
    edited 2014-08-22 23:08
    Comments Chip made
    Re: Hub "API"
    Here are the ones that needed some more explanation.
    ena_bus -- high on every other clock, makes the hub run half the speed of the cogs
    r -- high when cog is loading program, turns on ROM descrambling
    s -- selects byte/word/long
    c -- carry
    bus_ack -- acknowledge back to cog that hub request completed
    cog_ena -- 8 lines, each cog gets one, enables the cog if high
    ptr_w -- write PAR during COGINIT
    ptr_d -- data for writing PAR during COGINIT
    cfg -- control bits set by CLKSET
    http://forums.parallax.com/showthread.php/157051-Hub-quot-API-quot
    edited 2014-08-22 23:31
    Here is the file cog.v with updated explanations...
    Note: The forum has not expanded tab stops correctly. I view the source file with Notepad++.
    // cog
    Copyright 2014 Parallax Inc.
    This file is part of the hardware description for the Propeller 1 Design.
    The Propeller 1 Design is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by the
    Free Software Foundation, either version 3 of the License, or (at your option)
    any later version.
    The Propeller 1 Design is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY
    or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
    more details.
    You should have received a copy of the GNU General Public License along with
    the Propeller 1 Design.  If not, see <[URL]http://www.gnu.org/licenses/[/URL]>.
    // RR20140823 Comments by Cluso99
                      ADD
    instruction        mnem oper R  C  Z   +- C  D  S
    000000 ZC0ICCCC DDDDDDDDD SSSSSSSSS  WRBYTE D,S  _______   __________
    000000 ZC1ICCCC DDDDDDDDD SSSSSSSSS  RDBYTE D,S  B______   __________
    000001 ZC0ICCCC DDDDDDDDD SSSSSSSSS  WRWORD D,S  _______   __________
    000001 ZC1ICCCC DDDDDDDDD SSSSSSSSS  RDWORD D,S  B______   __________
    000010 ZC0ICCCC DDDDDDDDD SSSSSSSSS  WRLONG D,S  _______   __________
    000010 ZC1ICCCC DDDDDDDDD SSSSSSSSS  RDLONG D,S  B______   __________
    000011 ZCRICCCC DDDDDDDDD SSSSSSSSS  SYSOP D,S  B__B___   __________
    000100 ZCRICCCC DDDDDDDDD SSSSSSSSS * <MUL> D,S  M__M__Z   __________
    000101 ZCRICCCC DDDDDDDDD SSSSSSSSS * <MULS> D,S  M__M__Z   __________
    000110 ZCRICCCC DDDDDDDDD SSSSSSSSS * <ENC> D,S  E_____Z   __________
    000111 ZCRICCCC DDDDDDDDD SSSSSSSSS * <ONES> D,S  E_____Z   __________
    001000 ZCRICCCC DDDDDDDDD SSSSSSSSS  ROR  D,S  R__R__Z   __________
    001001 ZCRICCCC DDDDDDDDD SSSSSSSSS  ROL  D,S  R__R__Z   __________
    001010 ZCRICCCC DDDDDDDDD SSSSSSSSS  SHR  D,S  R__R__Z   __________
    001011 ZCRICCCC DDDDDDDDD SSSSSSSSS  SHL  D,S  R__R__Z   __________
    001100 ZCRICCCC DDDDDDDDD SSSSSSSSS  RCR  D,S  R__R__Z   __________
    001101 ZCRICCCC DDDDDDDDD SSSSSSSSS  RCL  D,S  R__R__Z   __________
    001110 ZCRICCCC DDDDDDDDD SSSSSSSSS  SAR  D,S  R__R__Z   __________
    001111 ZCRICCCC DDDDDDDDD SSSSSSSSS  REV  D,S  R__R__Z   __________
    010000 ZCRICCCC DDDDDDDDD SSSSSSSSS  MINS D,S  L__As_Z   1__0__1__1
    010001 ZCRICCCC DDDDDDDDD SSSSSSSSS  MAXS D,S  L__As_Z   1__0__1__1
    010010 ZCRICCCC DDDDDDDDD SSSSSSSSS  MIN  D,S  L__Au_Z   1__0__1__1
    010011 ZCRICCCC DDDDDDDDD SSSSSSSSS  MAX  D,S  L__Au_Z   1__0__1__1
    010100 ZCRICCCC DDDDDDDDD SSSSSSSSS  MOVS D,S  L______   __________
    010101 ZCRICCCC DDDDDDDDD SSSSSSSSS  MOVD D,S  L______   __________
    010110 ZCRICCCC DDDDDDDDD SSSSSSSSS  MOVI D,S  L______   __________
    010111 ZCRICCCC DDDDDDDDD SSSSSSSSS  JMPRET D,S  L______   __________
    011000 ZCRICCCC DDDDDDDDD SSSSSSSSS  AND  D,S  L__L__Z   __________
    011001 ZCRICCCC DDDDDDDDD SSSSSSSSS  ANDN D,S  L__L__Z   __________
    011010 ZCRICCCC DDDDDDDDD SSSSSSSSS  OR  D,S  L__L__Z   __________
    011011 ZCRICCCC DDDDDDDDD SSSSSSSSS  XOR  D,S  L__L__Z   __________
    011100 ZCRICCCC DDDDDDDDD SSSSSSSSS  MUXC D,S  L__L__Z   __________
    011101 ZCRICCCC DDDDDDDDD SSSSSSSSS  MUXNC D,S  L__L__Z   __________
    011110 ZCRICCCC DDDDDDDDD SSSSSSSSS  MUXZ D,S  L__L__Z   __________
    011111 ZCRICCCC DDDDDDDDD SSSSSSSSS  MUXNZ D,S  L__L__Z   __________
    100000 ZCRICCCC DDDDDDDDD SSSSSSSSS  ADD  D,S  A__Au_Z   0__0__1__1
    100001 ZCRICCCC DDDDDDDDD SSSSSSSSS  SUB  D,S  A__Au_Z   1__0__1__1
    100010 ZCRICCCC DDDDDDDDD SSSSSSSSS  ADDABS D,S  A__Au_Z   M__0__1__1
    100011 ZCRICCCC DDDDDDDDD SSSSSSSSS  SUBABS D,S  A__Au_Z   Mn_0__1__1
    100100 ZCRICCCC DDDDDDDDD SSSSSSSSS  SUMC D,S  A__Ao_Z   C__0__1__1
    100101 ZCRICCCC DDDDDDDDD SSSSSSSSS  SUMNC D,S  A__Ao_Z   Cn_0__1__1
    100110 ZCRICCCC DDDDDDDDD SSSSSSSSS  SUMZ D,S  A__Ao_Z   Z__0__1__1
    100111 ZCRICCCC DDDDDDDDD SSSSSSSSS  SUMNZ D,S  A__Ao_Z   Zn_0__1__1
    101000 ZCRICCCC DDDDDDDDD SSSSSSSSS  MOV  D,S  A__Am_Z   0__0__0__1
    101001 ZCRICCCC DDDDDDDDD SSSSSSSSS  NEG  D,S  A__Am_Z   1__0__0__1
    101010 ZCRICCCC DDDDDDDDD SSSSSSSSS  ABS  D,S  A__Am_Z   M__0__0__1
    101011 ZCRICCCC DDDDDDDDD SSSSSSSSS  ABSNEG D,S  A__Am_Z   Mn_0__0__1
    101100 ZCRICCCC DDDDDDDDD SSSSSSSSS  NEGC D,S  A__Am_Z   C__0__0__1
    101101 ZCRICCCC DDDDDDDDD SSSSSSSSS  NEGNC D,S  A__Am_Z   Cn_0__0__1
    101110 ZCRICCCC DDDDDDDDD SSSSSSSSS  NEGZ D,S  A__Am_Z   Z__0__0__1
    101111 ZCRICCCC DDDDDDDDD SSSSSSSSS  NEGNZ D,S  A__Am_Z   Zn_0__0__1
    110000 ZCRICCCC DDDDDDDDD SSSSSSSSS  CMPS D,S  A__As_Z   1__0__1__1
    110001 ZCRICCCC DDDDDDDDD SSSSSSSSS  CMPSX D,S  A__As_Z&  1__C__1__1
    110010 ZCRICCCC DDDDDDDDD SSSSSSSSS  ADDX D,S  A__Au_Z&  0__C__1__1
    110011 ZCRICCCC DDDDDDDDD SSSSSSSSS  SUBX D,S  A__Au_Z&  1__C__1__1
    110100 ZCRICCCC DDDDDDDDD SSSSSSSSS  ADDS D,S  A__Ao_Z   0__0__1__1
    110101 ZCRICCCC DDDDDDDDD SSSSSSSSS  SUBS D,S  A__Ao_Z   1__0__1__1
    110110 ZCRICCCC DDDDDDDDD SSSSSSSSS  ADDSX D,S  A__Ao_Z&  0__C__1__1
    110111 ZCRICCCC DDDDDDDDD SSSSSSSSS  SUBSX D,S  A__Ao_Z&  1__C__1__1
    111000 ZCRICCCC DDDDDDDDD SSSSSSSSS  CMPSUB D,S  A__Ac_Z   1__0__1__1
    111001 ZCRICCCC DDDDDDDDD SSSSSSSSS  DJNZ D,S  A__Au_Z   1__1__1__0
    111010 ZCRICCCC DDDDDDDDD SSSSSSSSS  TJNZ D,S  A__Au_Z   1__0__1__0
    111011 ZCRICCCC DDDDDDDDD SSSSSSSSS  TJZ  D,S  A__Au_Z   1__0__1__0
    111100 ZCRICCCC DDDDDDDDD SSSSSSSSS  WAITPEQ D,S  _______   __________
    111101 ZCRICCCC DDDDDDDDD SSSSSSSSS  WAITPNE D,S  _______   __________
    111110 ZCRICCCC DDDDDDDDD SSSSSSSSS  WAITCNT D,S  A__Au_Z   0__0__1__1
    111111 ZCRICCCC DDDDDDDDD SSSSSSSSS  WAITVID D,S  _______   __________
    * future instructions
    ZCR  effects
    000  nz, nc, nr
    001  nz, nc, r
    010  nz, c,  nr
    011  nz, c,  r
    100  z,  nc, nr
    101  z,  nc, r
    110  z,  c,  nr
    111  z,  c,  r
    CCCC condition   (easier-to-read list)
    0000 never    1111 always   (default)
    0001 nc  &  nz   1100 if_c       if_b
    0010 nc  &  z   0011 if_nc       if_ae
    0011 nc     1010 if_z       if_e
    0100  c  &  nz   0101 if_nz       if_ne
    0101 nz     1000 if_c_and_z  if_z_and_c
    0110  c  <> z   0100 if_c_and_nz  if_nz_and_c
    0111 nc  |  nz   0010 if_nc_and_z  if_z_and_nc
    1000  c  &  z   0001 if_nc_and_nz if_nz_and_nc if_a
    1001  c  =  z   1110 if_c_or_z  if_z_or_c  if_be
    1010  z     1101 if_c_or_nz  if_nz_or_c
    1011 nc  |  z   1011 if_nc_or_z  if_z_or_nc
    1100  c     0111 if_nc_or_nz  if_nz_or_nc
    1101  c  |  nz   1001 if_c_eq_z  if_z_eq_c
    1110  c  |  z   0110 if_c_ne_z  if_z_ne_c
    1111 always    0000 never
    I SSSSSSSSS source operand
    0 SSSSSSSSS register
    1 #SSSSSSSSS immediate, zero-extended
     DDDDDDDDD destination operand
     DDDDDDDDD register
    `include "cog_ram.v"
    `include "cog_alu.v"
    `include "cog_ctr.v"
    `include "cog_vid.v"
    module    cog
    input    nres,   // reset
    input    clk_pll,  // clocks
    input    clk_cog,
    input    ena_bus,
    input    ptr_w,   // pointers
    input  [27:0] ptr_d,
    input    ena,   // control
    input    bus_sel,  // bus
    output    bus_r,
    output    bus_e,
    output    bus_w,
    output   [1:0] bus_s,
    output  [15:0] bus_a,
    output  [31:0] bus_d,
    input  [31:0] bus_q,
    input    bus_c,
    input    bus_ack,
    input  [31:0] cnt,   // counter
    input   [7:0] pll_in,   // pll's
    output    pll_out,
    input  [31:0] pin_in,   // pins
    output  [31:0] pin_out,
    output  [31:0] pin_dir
    // The following are used for location of the bits in an instruction...
    parameter oh  = 31;   // \ iiiiii (instruction bits) location - bits[31:26]
    parameter ol  = 26;   // /
    parameter wz  = 25;   // WZ bit location
    parameter wc  = 24;   //  WC bit location
    parameter wr  = 23;   //  NR bit location
    parameter im  = 22;   //  I  bit location
    parameter ch  = 21;   // \ cccc (conditional execution bits) location [21:18]
    parameter cl  = 18;   // /
    parameter dh  = 17;   // \ ddddddddd (destination bits) location [17:9]
    parameter dl  = 9;   // /
    parameter sh  = 8;   // \ sssssssss (source bits) location [8:0]
    parameter sl  = 0;   // /
    // pointers
    reg [27:0] ptr;
    always @(posedge clk_cog or negedge nres)
    if (!nres)
     ptr <= 28'b00000000000000_11111000000000;  // used to force a cog start/boot
    else if (ena_bus && ptr_w)
     ptr <= ptr_d;         // when running
    // load/run
    reg run;
    always @(posedge clk_cog or negedge ena)
    if (!ena)
     run <= 1'b0;         // when cog is idle, run=0
    else if (m[3] && (&px))
     run <= 1'b1;         // when cog is running, run=1
    // state
    // When running, the cog can be in 5 states, represented by m[4:0]
    // These relate to the 6 clocks of an instruction. Due to overlapping instructions, the instructions effectively use 4 clocks.
    // I d S D e R      <---- first instruction
    //          I d S D e R    <---- next instruction
    // where    I = instruction fetch     (executes previous instruction)
    //   d = decode instruction     (write previous instructions Result)
    //   S = fetch source (unless immediate)
    //   D = fetch destination
    //   e = execute instruction    (fetch next instruction)
    //   R = write result     (decode next instruction)
    // below m[0] = S
    //   m[1] = D
    //   m[2] = I
    //   m[3] = R
    //   m[4] = wait (if a wait state needs to be inserted due to a WAITxxx instruction (or wait for hub slot???)
    reg [4:0] m;
    if (!ena)
     m <= 5'b0;
    else
     m <= { (m[2] || m[4]) &&  waiti,    // m[4] = wait
         (m[2] || m[4]) && !waiti,    // m[3] = write d
       m[1],         // m[2] = read next instruction
       m[0],         // m[1] = read d
         !m[4] && !m[2] && !m[1] && !m[0] };  // m[0] = read s
    // process
    reg [8:0] p;          // PC program counter
    reg c;            // C (carry) flag
    reg z;            // Z (zero) flag
    if (!ena)
     p <= 1'b0;          // cog not running, so PC=0
    else if (m[3] && !(cond && jump_cancel))
     p <= px + 1'b1;         // PC = px + 1 (increment PC)
    if (!ena)
     c <= 1'b0;          // cog not running, so C=0
    else if (m[3] && cond && i[wc])
     c <= alu_co;         // update C flag
    if (!ena)
     z <= 1'b0;          // cog not running, so Z=0
    else if (m[3] && cond && i[wz])
     z <= alu_zo;         // update Z flag
    // addressable registers
    //  addr read write
    //  000-1EF RAM  RAM
    //  1F0  PAR  RAM
    //  1F1  CNT  RAM
    //  1F2  INA  RAM
    //  1F3  INB * RAM
    //  1F4  RAM  RAM+OUTA
    //  1F5  RAM  RAM+OUTB *
    //  1F6  RAM  RAM+DIRA
    //  1F7  RAM  RAM+DIRB *
    //  1F8  RAM  RAM+CTRA
    //  1F9  RAM  RAM+CTRB
    //  1FA  RAM  RAM+FRQA
    //  1FB  RAM  RAM+FRQB
    //  1FC  PHSA RAM+PHSA
    //  1FD  PHSB RAM+PHSB
    //  1FE  RAM  RAM+VCFG
    //  1FF  RAM  RAM+VSCL
    // * future 64-pin version
    // Set wio if: state m[3] & conditions met & WR(write result) & D = $1Fx (destination is special register)
    wire wio   = m[3] && cond && i[wr] && (&i[dh:dl+4]);
    // Set one of the following if wio, according to D[3:0] (D is $1Fx, so set according to x)
    wire setouta  = wio && i[dl+3:dl] == 4'h4;
    wire setdira  = wio && i[dl+3:dl] == 4'h6;
    wire setctra  = wio && i[dl+3:dl] == 4'h8;
    wire setctrb  = wio && i[dl+3:dl] == 4'h9;
    wire setfrqa  = wio && i[dl+3:dl] == 4'hA;
    wire setfrqb  = wio && i[dl+3:dl] == 4'hB;
    wire setphsa  = wio && i[dl+3:dl] == 4'hC;
    wire setphsb  = wio && i[dl+3:dl] == 4'hD;
    wire setvid   = wio && i[dl+3:dl] == 4'hE;
    wire setscl   = wio && i[dl+3:dl] == 4'hF;
    // register ram
    // ram will be enabled for: m[0], m[1], m[2] , m[3] if condition met and write result
    wire ram_ena  = m[0] || m[1] || m[2] || m[3] && cond && i[wr];
    wire ram_w   = m[3] && alu_wr;   // ram write if: m[3] and ALU write result
    wire [8:0] ram_a = m[2] ? px    // set the ram address to:  PC if state m[2] (instruction fetch)
         : m[0] ? i[sh:sl]   //       Source address if state m[0]
           : i[dh:dl];   //       otherwise destination address
    wire [31:0] ram_q;        // set the result of a ram read
    // instantiate the cog ram by calling the module cog_ram in cog_ram.v
                // sets the parameters in cog_ram
    cog_ram cog_ram_  ( .clk (clk_cog),   // clock
         .ena (ram_ena),   // ram enable
         .w  (ram_w),   // ram write
         .a  (ram_a),   // ram address
         .d  (alu_r),   // ram value to be written (32 bits) ie ALU Result
         .q  (ram_q) );   // ram value read
    // outa/dira
    The OUTA and DIRA registers are AND'ed together and then OR'ed with all other Cogs' values and then to the physical OUTA pins.
    reg [31:0] outa;        // OUTA register
    reg [31:0] dira;        // DIRA register
    always @(posedge clk_cog)
    if (setouta)
     outa <= alu_r;        // if "setouta" was set above, copy the contents of the ALU Result to OUTA register
    if (setdira)
     dira <= alu_r;        // if "setdira" was set above, copy the contents of the ALU Result to DIRA register
    // ctra/ctrb
    // The following are for the counters A and B.
    wire [32:0] phsa;          // current PHSA value
    wire [31:0] ctra_pin_out;        // CTRA output
    wire plla;
    cog_ctr cog_ctra  ( .clk_cog (clk_cog),    // system clock
         .clk_pll (clk_pll),    // PLL clock
         .ena  (ena),     // counter enabled
         .setctr  (setctra),    // setctra signal (ie write to CTRA)
         .setfrq  (setfrqa),    // setfrqa signal (ie write to FRQA)
         .setphs  (setphsa),    // setphsa signal (ie write to PHSA)
         .data  (alu_r),    // data (32 bits) input
         .pin_in  (pin_in),    //
         .phs  (phsa),     // PHSA output value
         .pin_out (ctra_pin_out),   //
         .pll  (plla) );    // PLLA output register/value
    wire [32:0] phsb;
    wire [31:0] ctrb_pin_out;
    wire pllb;
    cog_ctr cog_ctrb  ( .clk_cog (clk_cog),
         .clk_pll (clk_pll),
         .ena  (ena),
         .setctr  (setctrb),
         .setfrq  (setfrqb),
         .setphs  (setphsb),
         .data  (alu_r),
         .pin_in  (pin_in),
         .phs  (phsb),
         .pin_out (ctrb_pin_out),
         .pll  (pllb) );
    assign pll_out  = plla;
    // vid
    // The following are for the Video:
    wire vidack;           // video ack (signals end of WAITVID ???)
    wire [31:0] vid_pin_out;        // video output signals on appropriate pins
    // Instantiate the video from cog_vid.v
    cog_vid cog_vid_  ( .clk_cog (clk_cog),    // system clock
         .clk_vid (plla),     // PLLA clock input
         .ena  (ena),     // video enable
         .setvid  (setvid),    // setvid signal (ie write to VCFG)
         .setscl  (setscl),    // setscl signal (ie write to VSCL)
         .pixel  (s),     // Source (32 bits) value
         .color  (d),     // Destination (32 bits) value
         .aural  (pll_in),    // ???
         .carrier (pllb),     // ???
         .ack  (vidack),    // WAITVID complete????
         .pin_out (vid_pin_out) );  // video output on pins
    // instruction
    // decode the instruction value...
    reg [31:0] ix;           // stores next instruction fetched
    if (m[3])
     ix <= ram_q;          // if m[3] then store the ram read results for the next instruction fetched
    wire [31:0] i  = run ? ix :       // if cog running, save next instruction fetched
           {14'b000010_001_0_0001, p, 9'b000000000};  // else set "boot" instruction to "IF_A RDLONG PC,0"
    // source
    // decode the source value...
    reg [31:0] sy;           // temp holding register for ram read of source address
    reg [31:0] s;           // final source value
    if (m[1])
     sy <= ram_q;          // state m[1]: save the source value read from ram in m[0]
    wire [31:0] sx  = i[im]     ? {23'b0, i[sh:sl]}    // if I then        sx= immediate source value of instruction
         : i[sh:sl] == 9'h1F0 ? {16'b0, ptr[27:14], 2'b0}  // elseif PAR then  sx= PAR value
         : i[sh:sl] == 9'h1F1 ? cnt       // elseif CNT then  sx= CNT value
         : i[sh:sl] == 9'h1F2 ? pin_in      // elseif INA then  sx= pin_in
         : i[sh:sl] == 9'h1FC ? phsa[31:0]     // elseif PHSA then sx= PHSA value
         : i[sh:sl] == 9'h1FD ? phsb[31:0]     // elseif PHSB then sx= PHSB value
               : sy;       // else             sx= sy (ram source value read)
    if (m[2])
     s <= sx;           // state m[2] copy sx value to s
    // destination
    // decode the destination (input) value...
    reg [31:0] d;           // final destination (input) value
    if (m[2])
     d <= ram_q;           // state m[2]: save the destination (input) value read from ram in m[1]
    // condition
    // decode the condition code...
    wire [3:0] condx = i[ch:cl];       // extract the cccc bits [21:18] from the instruction
    wire cond   = condx[{c, z}] && !cancel;   // ??? and not cancel (ie need to set the condition flags???)
    // jump/next
    // decode the next PC (program counter) value...
    reg cancel;            // set if jump is cancelled
    wire dz    = ~|d[31:1];      // calculate the Z flag setting
    wire [1:0] jumpx = i[oh:ol] == 6'b010111  ? {1'b1, 1'b0}    // if     retjmp jumpx= 10
         : i[oh:ol] == 6'b111001  ? {1'b1, dz && d[0]}  // elseif djnz   jumpx= 1x (x= zero and result=0)
         : i[oh:ol] == 6'b111010  ? {1'b1, dz && !d[0]}  // elseif tjnz  jumpx= 1x (x= zero and result!=0)
         : i[oh:ol] == 6'b111011  ? {1'b1, !(dz && !d[0])} // elseif tjz    jumpx= 1x (x=!(zero and result=0))
                : {1'b0, 1'b0};    // else  no jump jumpx= 00
    wire jump   = jumpx[1];       // 1= jump instruction
    wire jump_cancel = jumpx[0];       // 1= cancel the jump
    wire [8:0] px  = cond && jump ? sx[8:0] : p;  // if condition met and not cancelled, PC=sx[8:0] (ie jump) else PC=p (ie PC+1)
    if (!ena)
     cancel <= 1'b0;          // if cog not enabled then cancel=0
    else if (m[3])
     cancel <= cond && jump_cancel || &px;    // else if m[3] cancel = (condition met and not cancelled) OR &px (&px does what???)
    // bus interface
    // decode bus...
                       // if not bus_sel set zero(s), else...
    assign bus_r  = !bus_sel ? 1'b0 : run;            // ... = run flag
    assign bus_e  = !bus_sel ? 1'b0 : i[oh:ol+2] == 4'b0000__ && m[4];     // ... = hubop AND m[4] (hubop= RD/WR or SYSOP)
    assign bus_w  = !bus_sel ? 1'b0 : !i[wr];           // ... = write (ie not NR)
    assign bus_s  = !bus_sel ? 2'b0 : i[ol+1:ol];          // ... = i[1:0] bits
    assign bus_a  = !bus_sel ? 16'b0 : run ? s[15:0] : {ptr[13:0] + {5'b0, p}, s[1:0]}; // ... if run = hub addr s[15:0] else "boot???"
    assign bus_d  = !bus_sel ? 32'b0 : d;            // ... =d[31:0]
    // alu interface
    // decode in cog_alu.v ...
    wire alu_wr;         // alu write
    wire [31:0] alu_r;        // alu result
    wire alu_co;         // alu carry flag
    wire alu_zo;         // alu zero flag
    // instantiate cog_alu using cog_alu.v
    cog_alu cog_alu_  ( .i  (i[oh:ol]),   // instruction op code i[31:26]
         .s  (s),    // source value
         .d  (d),    // destination value
         .p  (p),    // PC (program counter)
         .run (run),    // run flag
         .ci  (c),    // input C flag
         .zi  (z),    // input Z flag
         .bus_q (bus_q),   // input ???
         .bus_c (bus_c),   // input ???
         .wr  (alu_wr),   // output write result
         .r  (alu_r),   // output result value
         .co  (alu_co),   // output C flag
         .zo  (alu_zo) );   // output Z flag
    // pin/count match
    // WAITPEQ/WAITPNE/WAITCNT...
    reg match;          // set if WAITPEQ/WAITPNE/WAITCNT condition met
    // decoding instructions WAITPEQ 111100 / WAITPNE 111101 / WAITCNT 111110 ...
     match <= m[4] && (i[ol+1:ol] == 2'b01 ^ (i[ol+1] ? cnt : pin_in & s) == d);
    // match <= m[4] &&        // state m[4] AND ...
    //          ( i[ol+1:ol] == 2'b01     // if (instr[1:0]==01) then 1 else 0 (ie if instr=xxxx01= WAITPNE then 1 else 0)
    //   ^          // XOR
    //   (i[ol+1] ? cnt : pin_in & s)    // if instr[1]=1 then CNT else (pin_in AND source mask)
    //   == d);        // == destination value  (ie is CNT met or PINS same)
    // ie   if m[4] AND...
    //     if      WAITCNT then if  CNT                    == destination value (ie count matched)
    //      else if WAITPEQ then if  (pin_in & source mask) == destination value (ie pins & mask matched)
    //      else if WAITPNE then if !(pin_in & source mask) == destination value (ie pins & mask not matched)
    // wait
    wire waitx   = i[oh:ol+2] == 4'b0000__ ? !bus_ack  // if     instr=0000xx then waitx= !bus_ack
         : i[oh:ol+1] == 5'b11110_ ? !match  // elseif instr=11110x then waitx= !match
         : i[oh:ol+0] == 6'b111110 ? !match  // elseif instr=11111x then waitx= !match
         : i[oh:ol+0] == 6'b111111 ? !vidack  // elseif instr=111111 then waitx= !vidack
                : 1'b0;   // else                     waitx= 0
    wire waiti   = cond && waitx;       // set if condition met AND waitx
    // pins
    // set output pins...
    //                    (OUTA |    CTRA      |    CTRB      |   VIDEO    ) & DIRA
    assign pin_out  = (outa | ctra_pin_out | ctrb_pin_out | vid_pin_out) & dira;
    assign pin_dir  = dira;          // DIRA
    endmodule
    edited 2014-08-23 03:35
    Here is the file cog_alu.v with my comments...
    // cog_alu
    any later version.
    more details.
    module    cog_alu
    input   [5:0] i,    // instruction opcode iiiiii
    input  [31:0] s,    // source value
    input  [31:0] d,    // destination value
    input   [8:0] p,    // PC (program counter)
    input    run,   // run flag
    input    ci,    // C flag input
    input    zi,    // Z flag input
    input  [31:0] bus_q,   //
    input    bus_c,   //
    output    wr,    // write result flag
    output  [31:0] r,    // result
    output    co,    // C flag
    output    zo    // Z flag
    // rotation instructions  001nnn - rev/sar/rc/rcr/shl/shr/rol/ror
    wire [31:0] dr  = { d[0],  d[1],  d[2],  d[3],  d[4],  d[5],  d[6],  d[7],
          d[8],  d[9],  d[10], d[11], d[12], d[13], d[14], d[15],
          d[16], d[17], d[18], d[19], d[20], d[21], d[22], d[23],
          d[24], d[25], d[26], d[27], d[28], d[29], d[30], d[31] }; // REV
    // precalculate interim rev/sar/rc/rcr/shl/shr/rol/ror results
    wire [7:0][30:0] ri = { 31'b0,    // rev
          {31{d[31]}},  // sar
          {31{ci}},   // rcl
          {31{ci}},   // rcr
          31'b0,    // shl
          31'b0,    // shr
          dr[30:0],   // rol
          d[30:0] };   // ror
    wire [62:0] rot  = {ri[i[2:0]], i[0] ? dr : d} >> s[4:0];
    wire [31:0] rotr = { rot[0],  rot[1],  rot[2],  rot[3],  rot[4],  rot[5],  rot[6],  rot[7],
          rot[8],  rot[9],  rot[10], rot[11], rot[12], rot[13], rot[14], rot[15],
          rot[16], rot[17], rot[18], rot[19], rot[20], rot[21], rot[22], rot[23],
          rot[24], rot[25], rot[26], rot[27], rot[28], rot[29], rot[30], rot[31] };
    wire [31:0] rot_r = ~&i[2:1] && i[0] ? rotr : rot[31:0];  // result if rotate type instruction
    wire rot_c   = ~&i[2:1] && i[0] ? dr[0] : d[0];   // C result if rotate type instruction
    // logic instructions 01nnnn - mins/maxs/min/max/movs/movd/movi/jmpret/and/andn/or/xor/muxc/muxnc/muxz/muxnz
    wire [1:0] log_s = i[2] ? {(i[1] ? zi : ci) ^ i[0], 1'b0} // muxc/muxnc/muxz/muxnz
             : {i[1], ~^i[1:0]};     // and/andn/or/xor
    wire [3:0][31:0] log_x = { d ^  s,        // 11 = xor
           d |  s,        // 10 = or  mux 1
           d &  s,        // 01 = and
           d & ~s };       // 00 = andn mux 0
    wire [3:0][31:0] mov_x = { d[31:9], p,       // jmpret
           s[8:0], d[22:0],     // movi
           d[31:18], s[8:0], d[8:0],   // movd
           d[31:9], s[8:0] };     // movs
    wire [31:0] log_r = i[3] ? log_x[log_s]      // and/andn/or/xor/muxc/muxnc/muxz/muxnz
         : i[2] ? mov_x[i[1:0]]      // movs/movd/movi/jmpret
             : s;         // mins/maxs/min/max
    wire log_c   = ^log_r;         // c is parity of result
    // add/sub instructions  1nnnnn
    wire [3:0] ads  = {zi, ci, s[31], 1'b0};
    wire add_sub  = i[5:4] == 2'b10 ? ads[i[2:1]] ^ i[0] // 10nnnn add/sub/addabs/subabs/sumc/sumnc/sumz/sumnz/mov/neg/abs/absneg/negc/negnc/negz/negnz
         : i[5:0] == 6'b110010 ||     // 110010 addx
           i[5:0] == 6'b110100 ||     // 110100 adds
           i[5:0] == 6'b110110 ||     // 110110 addsx
           i[5:2] == 4'b1111       // 1111nn waitcnt
              ? 1'b0     // 0 if above instructions
              : 1'b1;     // 1 if other subs
    wire add_ci   = i[5:3] == 3'b110 && (i[2:0] == 3'b001 || i[1]) && ci ||  // cmpsx/addx/subx/addsx/subsx
           i[4:3] == 2'b11 && i[1:0] == 2'b01;       // djnz
    wire [31:0] add_d = i[4:3] == 2'b01 ? 32'b0 : d;    // x01xxx mov/neg/abs/absneg/negc/negnc/negz/negnz
    wire [31:0] add_s = i[4:0] == 5'b11001 || i[4:1] == 4'b1101 ? 32'hFFFFFFFF  // djnz/tjnz/tjz (x11001 or x1101n)
         : add_sub         ? ~s    // subs
                    : s;    // adds
    wire [34:0] add_x = {1'b0, add_d[31], 1'b1, add_d[30:0], 1'b1} +
           {1'b0, add_s[31], 1'b0, add_s[30:0], add_ci ^ add_sub};  // interim result
    wire [31:0] add_r = {add_x[33], add_x[31:1]};          // final result
    wire add_co   = add_x[34];             // interim C results
    wire add_cm   = !add_x[32];             // interim C results
    wire add_cs   = add_co ^ add_d[31] ^ add_s[31];        // interim C results
                      // calculate final C out
    wire add_c   = i[5:0] == 6'b111000  ? add_co    // cmpsub
         : i[5:3] == 3'b101   ? s[31]     // source msb
         : i[5] && i[3:2] == 2'b01 ? add_co ^ add_cm  // overflow
         : i[4:1] == 4'b1000   ? add_cs    // signed
                : add_co ^ add_sub;  // unsigned
    // write-cancel instructions
    // Calculate if Write Result will occur
    assign wr   = i[5:2] == 4'b0100  ? i[0] ^ (i[1] ? !add_co : add_cs)  // mins/maxs/min/max
         : i[5:0] == 6'b111000 ? add_co        // cmpsub
               : 1'b1;         // others
    // r, c, z results
    // Calculate Final Result
    assign r   = i[5]     ? add_r
         : i[4]     ? log_r
         : i[3]     ? rot_r
         : run || ~&p[8:4]  ? bus_q
               : 32'b0; // write 0's to last 16 registers during load;
    // Calculate Final C flag output
    assign co   = i[5:3] == 3'b000  ? bus_c
         : i[5:3] == 3'b001  ? rot_c
         : i[5:3] == 3'b011  ? log_c
               : add_c;
    // Calculate Final Z flag output
    assign zo   = ~|r && (zi || !(i[5:3] == 3'b110 && (i[2:0] == 3'b001 || i[1])));  // addx/subx/cmpx/addsx/subsx/cmpsx logically AND the old z
    endmodule
    edited 2014-08-23 19:29
    Thanks Bob. I had skipped over that thread. That info is helpful.
    @Cluso
    This is great stuff! Very helpful. Thanks for sharing!
  • thoththoth Posts: 75
    edited 2014-08-23 21:49
    I open up a Register Transfer Level view (RTL). That shows a block diagram of the circuit. Right clicking on most objects displays a menu in which I can locate the object in the source verilog file. Double clicking on a module will open it up. The back arrow at the upper left allows moving back up the hierarchy. It's easy to duplicate tabs and keep a bunch of views open at different levels.
    I think it would be fabulous if Chip would take half an hour and create a glossary for those two letter identifiers he loves so much - shades of Basic! I like the terseness from a visual POV but it's an effort to figure out his naming conventions.
  • rjo__rjo__ Posts: 2,114
    edited 2014-08-24 07:33
    Very nice.
    edited 2014-09-02 19:22
    Here is a timing diagram...
    Warning: There is an error in the states for the timing diagram. Please see the next post.
    P8X32A FPGA - How it works
    This is my current understanding. No responsibility taken for errors, omissions, or misunderstanding.
    RR20140903 by Cluso99 (Ray)
    STATES:
     states:  m[0] = S
              m[1] = D
              m[2] = I
              m[4] = *wait (if wait state needs to be inserted due to a WAITxxx instruction (or wait for hub slot???)
              m[3] = R
    These states relate to the 6 clocks of an instruction.
    Due to overlapping instructions, each instruction effectively uses 4 clocks.
          I d S D e R                                             <---- previous instruction
              I d S D e R                                         <---- current instruction
     where    I = fetch  Instruction               and    executes previous instruction
              d = decode instruction               and    write Result of previous instruction
              S = fetch  Source (unless immediate)
              D = fetch  Destination
              e = execute instruction              and    fetch next instruction
              R = write  Result                    and    decode next instruction
    Timing Diagram:
      &#9474; &#9516;    &#9492;&#61627;&#9488;  m[1]: Latch D
      &#9474; &#9474;      &#9474;      Executing instruction
      e I    &#9484;&#9472;&#9496;      ...
      &#9474; &#9474;    &#9474;        Reading I (next instruction)
      &#9474; &#9474;    &#9492;&#61627;&#9488;  m[2]: Latch I
      &#9474; &#9474;      &#9474;      Writing R (result)
      R d    &#9484;&#9472;&#9496;      ...
      &#9474; &#9474;    &#9474;        Decoding (next instruction)
      &#9474; &#9474;    &#9492;&#61627;&#9488;  m[4]: WAIT  (optional wait states inserted here)
      &#9474; &#9474;      &#9474;      Wait for condition
      &#9474; w    &#9484;&#9472;&#9496;      ...
      &#9474; &#9474;    &#9474;        ...
      &#9524; &#9474;    &#9492;&#61627;&#9488;  m[3]: Latch R (write result to Cog RAM)
        &#9474;      &#9474;      Reading S
        S    &#9484;&#9472;&#9496;      ...
        &#9474;    &#9474;        ...
        &#9474;    &#9492;&#61627;&#9488;  m[0]: Latch S
        &#9474;      &#9474;      Reading D
        D    &#9484;&#9472;&#9496;      ...
        &#9474;    &#9474;        ...
    edited 2014-09-06 04:18
    This is also incorrect. see next post...
    Just realised that my timing diagram above was incorrect.
    I am hoping that I have the m[4] state correct..... where the cog waits for an access slot to the hub.
    Postedit: I suspect that the wait state(s), if present, come between m[2] and m[3]. Still checking.
    Timing Diagram:
      &#9532; &#9516;    &#9492;&#61627;&#9488;----------------------------------------------------
      &#9474; &#9474;      &#9474;  m[2]:  Reading I (next instruction)
      e I    &#9484;&#9472;&#9496;         Executing instruction
      &#9474; &#9474;    &#9474;           Latch I
      &#9532; &#9532;    &#9492;&#61627;&#9488;----------------------------------------------------
      &#9474; &#9474;      &#9474;  m[3]:  Writing R (result)
      R d    &#9484;&#9472;&#9496;         Decoding (next instruction)
      &#9474; &#9474;    &#9474;           Latch R (write result to Cog RAM)
      &#9524; &#9532;    &#9492;&#61627;&#9488;====================================================
        &#9474;      &#9474;  m[4]:  Reading/Writing if Hub Access ???
       (w)   &#9484;&#9472;&#9496;(option) WAIT for Condition (optional wait states)
        &#9474;    &#9474;           Latch Hub/Cog (read/write if hub access)???
        &#9474;      &#9474;  m[0]:  Reading S
        &#9474;    &#9474;           Latch S
        &#9474;      &#9474;  m[1]:  Reading D
        &#9474;    &#9474;           Latch D
    edited 2014-09-06 16:25
    Updated: m[4] wait state is between m[2] and m[3]...
    RR20140907 fixup by Cluso99
    STATES:
     states:  m[0] = S
              m[1] = D
              m[2] = I
              m[3] = R
              m[4] = *wait / hub slot (if wait state needs to be inserted due to a WAITxxx instruction or wait for hub slot)
    Timing Diagram:
     &#9532;  &#9516;     &#9492;&#61627;&#9488;-------&#9531;--------------------------------------------
     &#9474;  &#9474;     &#9474;         &#9484;&#9472;Latch I
     &#9532;  &#9532;     &#9492;&#61627;&#9488;=======&#9531;============================================
     &#9474;  &#9474;       &#9474;  m[4]:  Reading/Writing if Hub Access ???
    (w)(w)    &#9484;&#9472;&#9496;(option) WAIT for Condition (optional wait states)
     &#9474;  &#9474;     &#9474;         &#9484;&#9472;Latch Hub/Cog (read/write if hub access)???
     &#9474;  &#9474;     &#9474;         &#9484;&#9472;Latch R (write result to Cog RAM)
     &#9524;  &#9532;     &#9492;&#61627;&#9488;-------&#9531;--------------------------------------------
        &#9474;     &#9474;         &#9484;&#9472;Latch S
        &#9474;     &#9474;         &#9484;&#9472;Latch D
    Thanks for the updates, Cluso.
