Chromecast Root Method
There's a new Chromecast root method that's going to be released in a few weeks (http://forum.xda-developers.com/hardware-hacking/chromecast/root-chromecast-root-method-8-17-2014-t2850801), and the devs state that the root method is compatible only with the Teensy board, but they will release the source code. As a result, the root method will be portable to other boards. Would anybody be willing to port it to the P8X32A?
There are MUCH better things to use Parallax products for.
That being said I'd watch out for the 3.3v -> 5v difference between the Propeller and Teensy. You may or may not have to use some form of voltage conversion. After that, it's mostly a matter of figuring out the method that they post before Google comes up with a blocking patch.
Rooting is getting around the dumb user safeguards and getting the "root" access on Linux based devices.
I hope so. Otherwise I broke the law when I hacked, er, rooted my RasPi!!!!!
