Hub "API" — Parallax Forums
Hub "API"
David BetzDavid Betz Posts: 14,530
edited 2014-08-21 19:38 in Propeller 1
I'm having a bit of a hard time figuring out some of the inputs and outputs of some of the P1 modules, in particular the hub. Some I can probably guess but others I'm not sure of. What do these parameters do?
clk_cog -- obviously just the system clock
ena_bus -- enable the hub? If this is zero does this essentially disable hub activity for that clock?
nres -- the reset line
r -- bus request?
e -- ??
w -- write vs. read?
s -- state? What do the values mean?
a -- address
d -- input data
q -- output data
c -- ?
bus_ack -- operation succeeded? Under what cases could it fail?
cog_ena -- COG enable? How does this work?
ptr_w -- ???
ptr_d -- ??
cfg -- ??
I'll admit that I could probably figure out some of these on my own but there are some that I can't. Can anyone tell me what these signals really mean and how they are used?
Thanks!
David (Verilog and hardware newbie)
    edited 2014-08-21 19:32
    Here are the ones that needed some more explanation.
    ena_bus -- high on every other clock, makes the hub run half the speed of the cogs
    r -- high when cog is loading program, turns on ROM descrambling
    s -- selects byte/word/long
    c -- carry
    bus_ack -- acknowledge back to cog that hub request completed
    cog_ena -- 8 lines, each cog gets one, enables the cog if high
    ptr_w -- write PAR during COGINIT
    ptr_d -- data for writing PAR during COGINIT
    cfg -- control bits set by CLKSET
    Thanks Chip! Reading this code is fun!
