Parallax Quadrature Encoder question
Using the Parallax quadrature encoder (http://www.parallax.com/product/29321), on a single encoder, do both A and B need to be powered in order to read one of the inputs? For example, if you have Red, Black and White wired and powered but do not have the other side Red, Black, White wired will you get any data?
Why not just hook it up an try it? Can't do any harm.
I'd be very surprised if you couldn't get data from a single channel.
- Ken Gracey
You do not need to connect both sets of power pins - they are redundant. The only real reason why they're configured that way is because we supply the 3-wire jumper cables, so it's convenient to get the signals and power to and from a three pin header on a Board of Educationor Prop Activity Board(as examples).
We'll get a schematic up there pronto
Thanks!
-MattG
