RN-42 Bluetooth mldule and Java
I am going to try to get the RN-42 - I still got to get the RN-42 Bluetooth module
, but it's coming - to talk to my Windows PC over Bluetooth. I will be using one of Java's many Bluetooth libraries to communicate to the ActivityBoard using the built in Bluetooth module in my computer, but am new to this and would like some help.
Since this is my first time going to be using the RN-42 module, does anyone have any tips or pointers? I am new to using Java with Bluetooth as well, so if someone could give me a link to a great Java Bluetooth tutorial they have found in the past, that would be much appreciated!
Check out the forum at propellar powered, I think Jeff has done some stuff with Bluetooth.
Jim
If you are a 64 bit Windows user and you get libRxTx working I'd love to know what you did.
thanks. I will check it out and see what I can find out.
Martin_H,
I think I have miscommunicated my message. I would like to have the ActivityBoard as a standalone device and have Java use my computer's built in Bluetooth module. I would like to use Java to force pair with the ActivityBoard and send some simple characters such as 'A', 'B', etc.
Have either of you completed a project dealing with Bluetooth?
Yes I have. I used an eBay Bluetooth module with my BS2 and paired it with my PC's Bluetooth adapter. When I did that the Bluetooth module appeared as a COM port on my PC. I then opened the COM port with my PC program to read/wrote data to it. On the BS2 side I used two pins with the SERIN and SEROUT commands. The actual program was a remote control which used single letter commands to start/stop the drive wheels.
The pairing of a Bluetooth module and the PC is handled by the underlying OS, not Java. How that module is presented to the rest of the OS depends upon the capabilities of the Bluetooth device paired. Most of these Bluetooth modules used with microcontrollers are designed to appear as serial ports. That's why I mentioned libRxTx, Java, and a potential gotcha on 64 bit Windows.
Oh, ok. I see what you are saying.
Do you think then that it would be better to try to write C code to do this then?
I would not run into any problems because C supports this, right?
There would be no problems in C because that can call the host OS directly and use the Windows API's directly. Although you might have better luck getting Java to work than me.
BTW Here's a debugging tip. It will be a pain to debug your PC program and your Activity Board client at the same time. So do them separately. Use the Parallax serial terminal to open the COM port and send commands directly to the Activity Board. Once you get that working completely write the PC program which sends those commands. That way you can debug each part of the system in isolation.
Thanks for the tip! I will work on this tomorrow, and keep you all posted.
I am going to have to learn C++ then........Does anyone have any good tutorials/example programs I can learn from
/* * Native Windows GUI for Arduino EEPROM programmer * * Initial author mario, C# port by Martin Heermance. While Mario didn't * state a specific license, his text makes clear he was writing OSS, so * I'm making if official by using the MIT license. * * The MIT License (MIT) * Copyright (c) 2014 Mario and Martin Heermance * * Permission is hereby granted, free of charge, to any person obtaining a copy * of this software and associated documentation files (the "Software"), to deal * in the Software without restriction, including without limitation the rights * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell * copies of the Software, and to permit persons to whom the Software is * furnished to do so, subject to the following conditions: * The above copyright notice and this permission notice shall be included in * all copies or substantial portions of the Software. * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN * THE SOFTWARE. */ using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Threading; using System.Threading.Tasks; using System.IO.Ports; namespace JBurn { public class MySerial { // Set of serial port properties kept as data members private SerialPort _serialPort = new SerialPort(); private int _dataBits = 8; private Handshake _handshake = Handshake.None; private Parity _parity = Parity.None; private StopBits _stopBits = StopBits.One; /// <summary> /// This class is an argument block used to marshall context from the callback thread to the UI. /// </summary> public class AsyncContext { // Set of properties used to marshall anyc context back to the caller. public byte[] Data { get; set; } public int Offset { get; set; } public int Count { get; set; } public char Terminator { get; set; } public String ResponseText { get; set; } public List<byte> ResponseRaw { get; set; } public int ResponseSize { get; set; } public OnDataRecievedDelegate CallerCallback { get; set; } } // I hate doing this, but the serial API doesn't allow a way to marshall this. // So I have to use this to marshall across thread. It should work because // a serial port is inherently FIFO and we manage writes by turning off buttons. AsyncContext _context; /// <summary> /// Holds data received until we get a terminator. /// </summary> private string tString = string.Empty; /// <summary> /// static which allows the consumer to populate a dropdown with a list of serial ports. /// </summary> /// <returns>a string array of serial port names</returns> public static string[] getAvailableSerialPorts() { return System.IO.Ports.SerialPort.GetPortNames(); } /// <summary> /// A constructor with nothing special about it, but it captures the UI thread /// callback context since this object is constructed by the UI thread. /// </summary> public MySerial() { syncContext = System.Windows.Threading.DispatcherSynchronizationContext.Current; } /// <summary> /// Connects to the named port at the desired baud rate. /// </summary> /// <param name="portName">the serial port name (e.g. COM4)</param> /// <param name="speed">the baud rate</param> public void connect(String portName, int speed) { _serialPort.BaudRate = speed; _serialPort.DataBits = _dataBits; _serialPort.Handshake = _handshake; _serialPort.Parity = _parity; _serialPort.PortName = portName; _serialPort.StopBits = _stopBits; _serialPort.DataReceived += new SerialDataReceivedEventHandler(_serialPort_DataReceived); _serialPort.Open(); } /// <summary> /// closes the serial port /// </summary> public void disconnect() { if (_serialPort != null) { _serialPort.Close(); // close the port } } /// <summary> /// useful state accessor /// </summary> /// <returns>true if connected</returns> public bool isConnected() { return (_serialPort != null) && _serialPort.IsOpen; } /// <summary> /// Drops any leftover data in order to get a clean read from the port. /// </summary> public void DiscardInBuffer() { tString = string.Empty; _serialPort.DiscardInBuffer(); } /// <summary> /// Write accepts text and callsback when a response is received. This is useful /// for one shot writing of small blocks of text data. /// </summary> /// <param name="text">the data to send to the serial port</param> /// <param name="terminator">the character which signifies the end of the response</param> /// <param name="callback">called when a line of response is recieved</param> public void Write(String text, char terminator, OnDataRecievedDelegate callback) { byte[] data = Encoding.ASCII.GetBytes(text); Write(data, 0, data.Length, terminator, 0, callback); } /// <summary> /// Write accepts text and callsback when a response is received. It differs from the /// above in that there's no terminator to the response. It is fixed length. /// </summary> /// <param name="text">the data to send to the serial port</param> /// <param name="responseSize">the number of bytes in the response</param> /// <param name="callback">called when a line of response is recieved</param> public void Write(String text, int responseSize, OnDataRecievedDelegate callback) { byte[] data = Encoding.ASCII.GetBytes(text); Write(data, 0, data.Length, '\0', responseSize, callback); } /// <summary> /// Write accepts data and calls back when a response is received. This is useful for /// writing a large block in chuncks. The user can specify an ofset and count and write /// ranges of the data. /// </summary> /// <param name="data">the data to send to the serial port</param> /// <param name="offset">the offset within the buffer to start writing from</param> /// <param name="count">the number of bytes to write</param> /// <param name="terminator">the character which signifies the end of the response.</param> /// <param name="responseSize">the expected size of the response in bytes if there's no terminator.</param> /// <param name="callback">called when a line of response is recieved</param> public void Write(Byte[] data, int offset, int count, char terminator, int responseSize, OnDataRecievedDelegate callback) { // If the user expects a response, then save all the context parameters. if (callback != null) { _context = new AsyncContext(); _context.Data = data; _context.Offset = offset; _context.Count = count; _context.Terminator = terminator; _context.ResponseText = null; _context.ResponseRaw = new List<byte>(); _context.ResponseSize = responseSize; _context.CallerCallback = callback; } _serialPort.Write(data, offset, count); } // Everything below this is gritty Windows async callback stuff. // Basically I/O is non-blocking and calls back on a worker thread // But it's up to the programmer to marshall the data back to the caller. /// <summary> /// This holds the UI context to enable post message back to the UI thread /// </summary> private static SynchronizationContext syncContext; private static SynchronizationContext Sync { get { return syncContext; } } /// <summary> /// Consumers implement this delegate to be called when their response is available. /// Their initial arguments are reflected back to them to allow them to callback with /// the next block. This allows chaining a sequence of calls to together to write /// large payloads. /// </summary> public delegate void OnDataRecievedDelegate(AsyncContext context); /// <summary> /// I could use a lambda function to handle this thread break, but I find the /// syntax a bear to get correct. /// </summary> /// <param name="postPayload">the caller's callback method and response</param> private static void SimpleDelegateMethod(object postPayload) { System.Diagnostics.Debug.Assert(postPayload is AsyncContext); AsyncContext context = (AsyncContext)postPayload; context.CallerCallback(context); } /// <summary> /// Called in response to the data write. /// </summary> /// <param name="sender"></param> /// <param name="e"></param> private void _serialPort_DataReceived(object sender, SerialDataReceivedEventArgs e) { // Initialize a buffer to hold the received data byte[] buffer = new byte[_serialPort.BytesToRead]; // There is no accurate method for checking how many bytes are read // unless you check the return from the Read method int bytesRead = _serialPort.Read(buffer, 0, buffer.Length); // if the user passed a terminator, then convert to a string. if (_context.Terminator != '\0') { // Assume the data we are received is ASCII data. tString += Encoding.ASCII.GetString(buffer, 0, bytesRead); if (tString.IndexOf(_context.Terminator) > -1) { // Split the string at the terminator. string[] fields = tString.Split(_context.Terminator); // The payload is before the terminator. _context.ResponseText = fields[0]; // The rest of the string is after the terminator. tString = fields[1]; // If desired Post the message back to this object to break to the UI thread. if (_context.CallerCallback != null) { Sync.Post(SimpleDelegateMethod, _context); } } } else { _context.ResponseRaw.AddRange(buffer); if (_context.ResponseRaw.Count >= _context.ResponseSize) { Sync.Post(SimpleDelegateMethod, _context); } } } } }Mr. Lawerence, I have tried to get that to work, but I am having a lot of trouble controlling the settings for the USB Rx_P30 pin. I have attached a piece of example code that I have been using in NetBeans 8.0. I can receive stuff from my ActivityBoard, but when I send stuff, it comes out as rectangles and circles. Do you know how to fix this? I suspect it is the settings that I am using on the ActivityBoard, but I don't know how to change that.
mindrobots, thanks for the link with the library. As you can see I am currently working with the other one, but I looked at the code.
Here is my Java code:
import java.io.IOException; import java.io.InputStream; import java.io.OutputStream; import gnu.io.*; /** * * @author Vale */ public class SerialApplication { public void connect( String portName ) throws Exception { System.out.println( "IN CONNECT" ); CommPortIdentifier portIdentifier = CommPortIdentifier.getPortIdentifier( portName ); if( portIdentifier.isCurrentlyOwned() ) { System.out.println( "Error: Port is currently in use" ); } else { int timeout = 2000; CommPort commPort = portIdentifier.open( this.getClass().getName(), timeout ); if( commPort instanceof SerialPort ) { System.out.println( "IN ANOTHER PART OF CONNECT" ); SerialPort serialPort = ( SerialPort )commPort; serialPort.setSerialPortParams( 115200, SerialPort.DATABITS_8, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE ); InputStream in = serialPort.getInputStream(); OutputStream out = serialPort.getOutputStream(); ( new Thread( new SerialReader( in ) ) ).start(); ( new Thread( new SerialWriter( out ) ) ).start(); } else { System.out.println( "Error: Only serial ports are handled by this example." ); } } } public static class SerialReader implements Runnable { InputStream in; public SerialReader( InputStream in ) { System.out.println( "IN SERIALREADER" ); this.in = in; } public void run() { System.out.println( "IN ANOTHER PART OF SERIALREADER" ); byte[] buffer = new byte[ 1024 ]; int len = -1; try { while( ( len = this.in.read( buffer ) ) != -1 ) { System.out.print( new String( buffer, 0, len ) ); } } catch( IOException e ) { e.printStackTrace(); } } } public static class SerialWriter implements Runnable { OutputStream out; public SerialWriter( OutputStream out ) { this.out = out; try { out.write( 10 ); } catch ( Exception ex ) { } } public void run() { System.out.println( "IN ANOTHER PART OF SERIALWRITER" ); try { System.out.println( "IN WRITE METHOD " ); //this.out.write( 5 ); //this.out.flush(); while( true ) { System.out.println( "SENDING" ); this.out.write( 10 ); this.out.flush(); Thread.sleep( 1000 ); } } catch( Exception e ) { e.printStackTrace(); } } } public static void main( String[] args ) { try { ( new SerialApplication() ).connect( "COM3" ); } catch( Exception e ) { e.printStackTrace(); } } }Here is my SimpleIDE code:
#include "simpletools.h" // Include simpletools #include "FdSerial.h" int main() // main function { int button = 0; print( "MESSAGE SENT FROM ACTIVITYBOARD" ); while(1) // Endless loop { button = 0; button = input(30); // P3 input -> button variable print( input(30) ); print("button = %d\n", 0); // Display button state pause(1000); // Wait 0.1 second before repeat print("button = %d\n", 1); if ( button == 5 ) { exit( 0 ); } if ( button == 10 ) { print( "MESSAGE RECIEVED!" ); high( 8 ); low( 9 ); } if ( button == 0 ) { print( "BUTTON IS NOT REGISTERING" ); } } } /*#include <stdio.h> #include "propeller.h" #include "fdSerial.h" //ATTEMPTING TO USE FdSerial.h library; doesn't work :( /* Turn off default serial port driver just for this demo so we can see output on P30 */ /*_Driver *_driverlist[] = { NULL };*/ /* * putchar must be defined for printf to work */ /*int send(char ch) { if(ch == '\n') FdSerial_tx('\r'); FdSerial_tx(ch); return ch; } /* * Using main without args for embedded use. * defining FDS_DISABLE_OUTS saves ~500 bytes * FdSerial_bin FdSerial_dec FdSerial_hex FdSerial_str etc... * are not necessary because we have printf. */ /*int main(void) { int ii = 0; int hex = 0x1deadbee; FdSerial_start(31,30,0,115200); FdSerial_str("\nHello World!\n"); FdSerial_hex(hex,8); for(ii = 0; ii <= 1000; ii++) { FdSerial_tx(' '); FdSerial_dec(ii); if(ii % 10 == 0) { FdSerial_tx('\r'); FdSerial_tx('\n'); } } while(1) { ii = FdSerial_rxcheck(); if(ii >= 0) FdSerial_tx(ii); } return 0; } */Some of the statements are debug statements. Just an FYI
a) I need to get the RN-42 Bluetooth module
b) I have done some research on how to use the RN-42, and it seems that it appears as a serial port on the computer.
Does help clear things up?
That's how I do my wireless serial protocol development as well. Basically get the serial protocol working, then make it wireless. That way you only debug one thing at a time.
Do you have any ideas on how to edit the protocols on the ActivityBoard?
First you need to work on one end at a time and get them working without errors and then combine them.
For testing you can make a loop back tester. RS-232 Loopback: Connect the TXD pin to the RXD pin
Then on the PC you can use a serial terminal program such as Putty for testing. Once you get that end working without errors you can start on the other end.
http://www.ni.com/white-paper/3450/en/
On you PC go to the device drivers >> serial Ports and check the serial port properties(ensure the baud rate is set high enough)
Also, in your PC code I didn't see any flow control. . I always add it even if it's not used.(just a good habit so you don't forget when it's needed)
try { serialPort.setFlowControlMode( // SerialPort.FLOWCONTROL_NONE);
For the activity board side >> I use SPIN and Asm for the Propeller so I'm not setup to test the C code . Jazzed can help you out if he pop's by.
An interactive language (e.g. Forth) simplifies this process because the built in read eval print loop (REPL) is the protocol your PC side program will invoke when the protocol is complete.
I am testing your theories and will post my results within the next day. BTW, the FlowControl statement didn't do anything when I added that into my code. I also changed the port Baud rates, but that didn't do anything.
Attached are pictures of my current results when I run the Java code in NetBeans and when I use Putty. Neither of them have changed.
Currently, when I run the program, I get random numbers back. I can't figure out why this is happening. Does anyone have any idea?
Would someone mind debugging my program and testing it? I have attached my current code below.
package serialapplication; //setting package program belongs to import java.io.IOException; //importing libraries import java.io.InputStream; import java.io.OutputStream; import gnu.io.*; /** * * @author Vale */ public class SerialApplication { private String inputvalue = ""; //variable that WILL hold data that comes in from activityboard public String getIncomingMessage() { //returning the info that the activityboard has sent return inputvalue; } public void connect( String portName ) throws Exception { //method to connect to the activityboard System.out.println( "Connecting...." ); CommPortIdentifier portIdentifier = CommPortIdentifier.getPortIdentifier( portName ); //getting actual port name if( portIdentifier.isCurrentlyOwned() ) { //if some other process is using the port System.out.println( "Error: Port is currently in use" ); //cancel connecting and exit programs System.exit( 0 ); } else { //if port is not in use int timeout = 2000; CommPort commPort = portIdentifier.open( this.getClass().getName(), timeout ); //open the port if( commPort instanceof SerialPort ) { //if commPort is successfully opened System.out.println( "Connected!" ); SerialPort serialPort = ( SerialPort )commPort; serialPort.setSerialPortParams( 115200, SerialPort.DATABITS_8, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE ); //setting port parameters try { //setting flow control serialPort.setFlowControlMode( SerialPort.FLOWCONTROL_NONE ); } catch( Exception ex ) { } InputStream in = serialPort.getInputStream(); //creating input and output streams for info coming in and leaving through port OutputStream out = serialPort.getOutputStream(); ( new Thread( new SerialReader( in ) ) ).start(); //creating new thread to read in info from activityboard ( new Thread( new SerialWriter( out ) ) ).start(); //creating new thread to write out info to activityboard } else { //commPort was not successfully opened System.out.println( "Error: Only serial ports are handled by this example." ); } } } public static class SerialReader implements Runnable { InputStream in; //creating inputstream public SerialReader( InputStream in ) { //constructor this.in = in; } public void run() { int len = -1; //setting input to -1 try { while( true ) { len = this.in.read(); //reading in info from activityboard if ( len > 0 ) { //while info came in over serial port if ( len != 95 ) { //if character inputed doesn't equal _ ( which means new line ) System.out.print( returnstringvalue( len ) ); } else { //if inputed is _ System.out.println(); } //System.out.println( len ); } } } catch( IOException e ) { e.printStackTrace(); } } } public static class SerialWriter implements Runnable { OutputStream out; //creating outputstream public SerialWriter( OutputStream out ) { //contructor this.out = out; } public void run() { try { byte[] values = new byte[1024]; values[0] = 'C'; while( true ) { this.out.write( values[0] ); //currently, only writing 10 to the ActivityBoard //Thread.sleep( 1000 ); } } catch( Exception e ) { e.printStackTrace(); } } } public static char returnstringvalue( int len ) { char[] ASCIIStringValue = { ' ', '!', '"', '#', '$', '%', '&', '-', '-', '-', '*', '+', '-', '-', '.', '/', '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', ':', ';', '<', '=', '>', '?', '@', 'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z', '[', '-', ']', '^', '_', '-', 'a', 'b', 'c', 'd', 'e', 'f', 'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't', 'u', 'v', 'w', 'x', 'y', 'z', '{', '|' }; char value = '|'; for ( int i = 0; i <= 92; i++ ) { if ( i + 32 == len ) { value = ASCIIStringValue[i]; } } return value; } public static void main( String[] args ) { try { ( new SerialApplication() ).connect( "COM3" ); } catch( Exception e ) { e.printStackTrace(); } } }#include "simpletools.h" //Importing/Including libraries #include "fdserial.h" fdserial *comp1; //Creating serial port variable int main() //Main method declaration { comp1 = fdserial_open(31, 30, 0, 115200); //pause(5000); //Pausing for 5 seconds //dprint(comp1, "_Hi_Talking to you from the activityboard!"); //Sending data over the serial port to the computer //pause(1000); //Pausing for another second //dprint(comp1, "_How is it going?"); //Sending data over the serial port to the computer char c[1000]; //dprint( comp1, fdserial_rxChar( comp1 ) ); for ( int i = 0; i < 1000; i++ ) { c[i] = fdserial_rxChar( comp1 ); pause( 100 ); if ( c[i] == "16" ) { exit( 0 ); dprint( comp1, "_INFO RECIEVED" ); } dprint( comp1, c[i] ); } }if ( c[i] == "16" ) { exit( 0 ); dprint( comp1, "_INFO RECIEVED" ); }c is a char array and you are comparing a single character to the string "16". That will never be true. I'm also not sure about the definition of dprint, but you need to ensure it's expecting a character because that's what you are giving it.
Thanks, but it didn't fix the problem. Do you think anything could be wrong on the Java side of the code?
The sort of problems are way to difficult to debug if you try to do everything at once.
The problem that I am specifically dealing with is using the ActivityBoard to read in info from the Java program. Everything else works. I was having a problem with squares and circles, but since I got rid of the buffer variable, the Java program can read stuff in fine. I suspect the problem stems from the serial protocols the propeller is using, but I don't fully understand how the propeller communicates with the serial ports on the computer so I am having trouble narrowing down the problem.
Right now, when I communicate to the ActivityBoard and have it echo back whatever info it is receiving, I get random numbers. I know it is not a problem with the Java program, so it must be with the ActivityBoard. Since I also know that the ActivityBoard can send info without issue, I can assume that the problem occurs when the ActivityBoard is reading information from the serial connection.
If I could figure out how the ActivityBoard communicates with the SimpleIDE terminal, maybe I could figure out what is causing the problem, and hopefully come up with a solution. But if I could do this, I wouldn't need any help
In one place in the code you call dprint with a null terminated string:
But later you call it with a single character:
Unless dprint is overloaded to take both data types that's not going to work. Given its name, my guess is that dprint expects a null terminated string and the dprint of c is going to print random junk until it bumps into a null.
I think in the second example you need a format specifier. I'm not sure if it will work, but try:
Tom
Sorry for the big delay! My school just started, so it is hard finding time to work on everything.
I have been trying to make some progress, but I can't figure out my problem
I have tried a loop tester with connecting the Rx an Tx pins directly together over an FTDI chip, and it works fine.
Has anyone successfully communicated with the ActivityBoard over USB from a program other than the Parallax supported IDEs in Java ( well....at this point, I guess I am willing to go for any language
You can "communicate" with the Activity Board over USB with serial data. You can do that with any programming language. I've done it in Java, Python and I routinely just send commands over TTY to the Activity Board to test my basic code.
What operating system are you using? If you are on Linux try running "miniterm.py /dev/ttyUSB0 115200", and see if you can send/recieve data to the Activity Board. If that works, you probably are just having trouble with your string conversion.
Here is some test code I wrote a while back just to prove that I could talk over serial to an Activity Board from a Raspberry Pi:
It uses jSSC: https://code.google.com/p/java-simple-serial-connector/
package jssc_test; import jssc.SerialPort; import jssc.SerialPortEvent; import jssc.SerialPortEventListener; import jssc.SerialPortException; public class Test1 { static SerialPort serialPort; public static void main(String[] args) { if (args.length != 1) { System.out.println("You must include the COM port!"); System.out.println("Like this:"); System.out.println("Test1 COM4"); System.out.println("Test1 /dev/ttyUSB0"); System.out.println("Test1 /dev/ttyAMA0"); System.out.println("etc."); System.exit(1); } serialPort = new SerialPort(args[0]); try { System.out.print("Opening " + args[0] + " at"); serialPort.openPort(); System.out.print(" 115200, 8, 1, 0 and "); serialPort.setParams(115200, 8, 1, 0); //Preparing a mask. In a mask, we need to specify the types of events that we want to track. //Well, for example, we need to know what came some data, thus in the mask must have the //following value: MASK_RXCHAR. If we, for example, still need to know about changes in states //of lines CTS and DSR, the mask has to look like this: SerialPort.MASK_RXCHAR + SerialPort.MASK_CTS + SerialPort.MASK_DSR int mask = SerialPort.MASK_RXCHAR; //Set the prepared mask serialPort.setEventsMask(mask); //Add an interface through which we will receive information about events System.out.println("waiting for data . . ."); serialPort.addEventListener(new SerialPortReader()); //serialPort.writeString("HelloWorld"); } catch (SerialPortException ex) { System.out.println("Serial Port Opening Exception: " + ex); } } static class SerialPortReader implements SerialPortEventListener { public void serialEvent(SerialPortEvent event) { //Object type SerialPortEvent carries information about which event occurred and a value. //For example, if the data came a method event.getEventValue() returns us the number of bytes in the input buffer. /* For debugging, this should always be 1 unless we are * waiting for more than one byte, otherwise it just junks up the output :) */ //System.out.println("Bytes: " + event.getEventType()); if(event.isRXCHAR()){ /* See original code, * it waited for a certain number of bytes, * but if I want the characters, why do that? */ //if(event.getEventValue() == 10){ try { String data= serialPort.readString(); //System.out.println("Data: " + data); // For debugging System.out.print(data); } catch (SerialPortException ex) { System.out.println("Serial Port Reading Exception: " + ex); } //} } //If the CTS line status has changed, then the method event.getEventValue() returns 1 if the line is ON and 0 if it is OFF. else if(event.isCTS()){ if(event.getEventValue() == 1){ System.out.println("CTS - ON"); } else { System.out.println("CTS - OFF"); } } else if(event.isDSR()){ if(event.getEventValue() == 1){ System.out.println("DSR - ON"); } else { System.out.println("DSR - OFF"); } } } } }It has been a few months since I threw that together, mostly from examples, so I don't remember all of the details.
I can communicate to the computer from the ActivityBoard fine, it is just when I attempt to send data to the ActivityBoard from my computer that my communication breaks down
Do you see what issue I am having?
