A DE2-115 Propeller demo board project - now programmable with the Propplug — Parallax Forums
pik33pik33 Posts: 2,414
edited 2014-08-20 02:45 in Propeller 1
Edit - 2014.08.20: Version 0.02 is ready. Now, as I have a PropPlug, this is PropPlug programmable.
There are 3 files uploaded:
- a Quartus project
- a Propeller program (wav and sid player). This has to be compiled by BST
- binary files: pof and sof to program the DE2-115 and bin file to program the Propeller
Please test if this works.
The Propeller works @ 130 MHz.
Let it start in its own topic.
What I have now is:
- a DE2-115 :)
- a modified Propeller code working up to 140 MHz, with dirb, outb and inb enabled as independent ports, which can be programmed via DE2-115 RS232 port. After I receive a propplug (thanks again) I will rewrite this to make the system programmable via Propplug too.
- vga output working, SD card working (at <120 MHz), PS2 input working. My Propplay 0.16 starts, displays the picture on the monitor, connects to the SD card and I think it can play if only I can connect P10,P11 to the amplifier.
- some - self made or reworked from Terasic sources - modules intended to work with nios2/qsys in different stage of code completion:
-- vga frame buffer, 800x600x24 using SRAM. Slow. :( Used this as a presentation machine at the university :)
-- vga text mode frame buffer, 1440x900, using Atari ST 8x16 font. A pasm code (Nostalgia VGA driver) was used as the source for rewritting in verilog.
-- sdhc (yes, sdhc only) controller which can init the card and read/write a sector into the buffer. It is sdhc only because it hasn't a code which detects older sd cards and address them in byte adressing mode. I haven't any card <4GB to test it.
-- sound chip controller
-- keyboard controller
-- sdram driver
- some Terasic code which can be easily adopted:
-- mouse controller - needs an Y-type PS2 cable
-- IRDA controller
What I want to have:
- a DE2-115 Propeller demo board, configurable with SWx, so we can (1) use a demoboard compatible programs with it (2) after switching some SW use extended possibilities of DE2-115 Propeller to have more fun.
What I am working now at is:
- to make a sound chip controller to work with the Propeller, so I can replace a sound output driver with this and hear the sound - done
What I want to do when I can hear the sound:
- connect a verilog sdhc controller to the Propeller to allow it run @140 MHz
- make a DE2-115 Propeller self bootable. Possible solutions are:
--- add an eeprom connected to GPIO
--- write an eeprom simulator which can use DE2-115 flash memory or will simply boot from something preloaded into fpga
--- modify the boot code so the Propeller will load its code from flash/sd card/something else
I don't know at this time which solution will be better.
The first complete project I want to put here will be a version with working sound and runnable Propplay so it can play SIDs and WAVs from SD.
  • pik33pik33 Posts: 2,414
    edited 2014-08-16 06:12
    First procedure which plays the sound from sd. with the fpga sound controller. Yes, it is that simple now but Spin is too slow :( Buffer underrun, pasm needed
    i:=fat.FATEngineStart(_SD_DO, _SD_CLK, _SD_DI, _SD_CS, _SD_WP, _SD_CD, -1, -1, -1)
    i:=fat.mountpartition(0)
    l:=fat.openfile(string("002.wav"),"R")
    repeat
      if inb[0]==1
        l:=fat.readdata(@buf,1024)
        repeat i from 0 to 127
          dirb:=i
          outb:=buf[i]
          dirb[8]:=1
      if inb[1]==1
        repeat i from 128 to 255
          dirb:=i
          outb:=buf[i]
          dirb[8]:=1
    until l<>1024
    fat.closefile
    edited 2014-08-16 07:33
    Were you aware that Ale has written a number of SIDCOG programs that simulate some of the old Commodore sound chips.
    edited 2014-08-16 07:53
    I have a player ready.
    http://forums.parallax.com/showthread.php/140767-A-new-topic-for-vga-(not-only)-sid-player?p=1113690&viewfull=1#post1113690
    This player contains a sidcog as an object and plays sids and wavs. It is made for the Propeller demo board. The keyboard, sd and vga is working now with a de2-115. All what was left to run it fully is to write a new sound driver and replace my existing ncowav with this Then we will have a sid/wav player running on de2-115. The sound hardware is working now, it only needs a procedure in pasm, spin is simply too slow to feed the samples @ 44100 Hz
    If you want to try this player with a real Propeller demo board, compile it with bst or remove a demo method from the vga driver, or it doesn't fit in 32k.
    edited 2014-08-16 08:57
    Nice job! I was not aware of what you have done with audio.
    edited 2014-08-16 09:09
    Looks great!
    edited 2014-08-17 03:48
    Wav play working. To do before 0.01 release: make a SID play.
    edited 2014-08-17 06:40
    And this is what the working sound driver for wav playing looks like. Using extended portb to communicate with 256x32 sample buffer.
    Sound driver for DE2-115 sound chip with the hardware controlled buffer
    v.0.01 - 20140817
    inb [1..0] - lower/upper half of the buffer is empty
    dirb[7..0] - buffer address
    dirb[8] - write strobe
    outb[31..0] - sample data
    VAR
      long cog
      long buf[512]
      long bufnum
    pub getbuf
    return @buf
    pub getbufnum
    return @bufnum
    PUB start
    longfill(@buf,0,512)
    bufptr:=@buf
    stop
    cog:=1+cognew(@init, @bufnum)
    return cog
    PUB stop
    if cog>0
      cogstop(cog-1)
    cog := 0
    DAT
                            org     0                         'initialization
    init
                            mov     bufptr2,par
    loop                    mov     a1,inb
                            and     a1,#1
                            cmp     a1,#1           wz
                  if_nz     jmp     #loop                   ' lower half of the buffer is empty
                            mov     a2,#0
    p101                    mov     ptr,bufptr               ' compute pointer to sample
                            add     ptr,bufcnt
                            rdlong  lsample,ptr
                            add     bufcnt,#4
                            and     bufcnt,bufmask
                            wrlong  bufcnt,bufptr2           ' write actual sample number for main program
                            mov     dirb,a2
                            mov     outb,lsample
                            or      dirb,#256
                            add     a2,#1
                            cmp     a2,#128         wz
                  if_nz     jmp     #p101
    p102                    mov     a1,inb
                            and     a1,#2
                            cmp     a1,#2           wz
                  if_nz     jmp     #p102                    ' upper half of the buffer is empty
                            mov     a2,#0
    p103                    mov     ptr,bufptr               ' compute pointer to sample
                            add     ptr,bufcnt
                            rdlong  lsample,ptr
                            add     bufcnt,#4
                            and     bufcnt,bufmask
                            mov     a1,a2
                            add     a1,#128
                            mov     dirb,a1
                            mov     outb,lsample
                            or      dirb,#256
                            add     a2,#1
                            cmp     a2,#128         wz
                  if_nz     jmp     #p103
                            jmp     #loop
    bufmask                 long    00_0000_0000_0000_0000_0111_1111_1111
    bufptr                  long    0
    bufptr2                 long    0
    bufcnt                  long    0
    lsample                 res 1
    ptr                     res 1
    a1                      res 1
    a2                      res 1
                            fit     496
    //                                                  TERMS OF USE: MIT License
    // Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation
    // files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy,
    // modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the
    // Software is furnished to do so, subject to the following conditions:
    // The above copyright notice and this permission notice shall be included in all copies or substantial portions of the
    // Software.
    // THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE
    // WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
    // COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE,
    // ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    edited 2014-08-17 08:43
    0.01 works, so, as promised, I uploaded the project. As is now, without any cleaning. The files are attached to the first post.The bigger file is the Quartus project. The smaller is SID/WAV player.
    edited 2014-08-17 09:51
    Added some lowpass filtering to sidcog driver to reduce aliasing. Not sure if this helped. True 32->44.1 kHz resampling procedure is needed, but not now :)
    Edit: seems to be better without this filter...
    FPGA sound driver for sidcog v0.02-20140817
    Change from 0.01: some low pass filtering added
    Piotr Kardasz, pik33@o2.pl
    MIT license, see bottom
    VAR
    '  long bufnum
      long cog
      long bufnum
    pub getbufnum
    return @bufnum
    PUB start (addr)
    bufptr:=addr
    stop
    return cog
    PUB stop
    if cog>0
      cogstop(cog-1)
    cog := 0
    DAT
    init                    mov     bufptr2,par
                            mov     a2,#128
    p102                    mov     a1,inb                 ' wait for upper buffer empty
                            and     a1,#2
                            cmp     a1,#2           wz
                  if_nz     jmp     #p102                  '
    p11                     mov     a1, inb                'wait for 0 on inb[2] - synchro
                            and     a1, #4
                            cmp     a1,#0           wz
                  if_nz     jmp     #p11
    p1                      mov     a1, inb                'wait for 1 on inb[2] - synchro
                            and     a1, #4
                            cmp     a1,#4           wz
                  if_nz     jmp     #p1
                            rdlong  lsample,bufptr
                            sar     lsample,#17
                            mov     rsample,lsample
                            add     lsample,filter
                            mov     filter,rsample
                            sar     filter,#1
                            mov     rsample, lsample
                            shl     rsample,#1
                            add     lsample, rsample
                            shl     rsample,#1
                            sar     lsample,#3
                            mov     rsample,lsample
                            shl     rsample, #16
                            add     lsample,rsample
                            mov     dirb,a2
                            mov     outb,lsample
                            or      dirb,#256
                            add     a2,#1
                            and     a2,#255
                            jmp     #p11
    bufptr                  long    0
    bufptr2                 long    0
    lsample                 res 1
    rsample                 res 1
    filter                  res 1
    a1                      res 1
    a2 res 1
                            fit     496
    // Software.
    edited 2014-08-18 03:33
    It seems I need some more rest.
    What I published yesterday was one of earlyr version of the project. It cannot run with attached player. Maybe it cannot run at all.
    I will find and upload the proper quartus project as soon as I return home.
    Changes:
    - programmable via proplug instead rs232. The propplug has to be attached at the same pins as in the original Propeller DE2--115 design.
    - the Propeller run @ 130 MHz
    - the player now plays all files from the directory without any assistance
    - patched some bugs in the player
    I attached a bin archive with precompiled files.
    I hope there was proper and working version uploaded (i will test this now). Please try if this works. The files are attached to the first post.
