A DE2-115 Propeller demo board project - now programmable with the Propplug
pik33
Edit - 2014.08.20: Version 0.02 is ready. Now, as I have a PropPlug, this is PropPlug programmable.
There are 3 files uploaded:
- a Quartus project
- a Propeller program (wav and sid player). This has to be compiled by BST
- binary files: pof and sof to program the DE2-115 and bin file to program the Propeller
Please test if this works.
The Propeller works @ 130 MHz.
Let it start in its own topic.
What I have now is:
- a DE2-115
- a modified Propeller code working up to 140 MHz, with dirb, outb and inb enabled as independent ports, which can be programmed via DE2-115 RS232 port. After I receive a propplug (thanks again) I will rewrite this to make the system programmable via Propplug too.
- vga output working, SD card working (at <120 MHz), PS2 input working. My Propplay 0.16 starts, displays the picture on the monitor, connects to the SD card and I think it can play if only I can connect P10,P11 to the amplifier.
- some - self made or reworked from Terasic sources - modules intended to work with nios2/qsys in different stage of code completion:
-- vga frame buffer, 800x600x24 using SRAM. Slow.
Used this as a presentation machine at the university
-- vga text mode frame buffer, 1440x900, using Atari ST 8x16 font. A pasm code (Nostalgia VGA driver) was used as the source for rewritting in verilog.
-- sdhc (yes, sdhc only) controller which can init the card and read/write a sector into the buffer. It is sdhc only because it hasn't a code which detects older sd cards and address them in byte adressing mode. I haven't any card <4GB to test it.
-- sound chip controller
-- keyboard controller
-- sdram driver
- some Terasic code which can be easily adopted:
-- mouse controller - needs an Y-type PS2 cable
-- IRDA controller
What I want to have:
- a DE2-115 Propeller demo board, configurable with SWx, so we can (1) use a demoboard compatible programs with it (2) after switching some SW use extended possibilities of DE2-115 Propeller to have more fun.
What I am working now at is:
- to make a sound chip controller to work with the Propeller, so I can replace a sound output driver with this and hear the sound - done
What I want to do when I can hear the sound:
- connect a verilog sdhc controller to the Propeller to allow it run @140 MHz
- make a DE2-115 Propeller self bootable. Possible solutions are:
--- add an eeprom connected to GPIO
--- write an eeprom simulator which can use DE2-115 flash memory or will simply boot from something preloaded into fpga
--- modify the boot code so the Propeller will load its code from flash/sd card/something else
I don't know at this time which solution will be better.
The first complete project I want to put here will be a version with working sound and runnable Propplay so it can play SIDs and WAVs from SD.
- a Quartus project
What I have now is:
- a DE2-115
-- sdram driver
-- IRDA controller
i:=fat.FATEngineStart(_SD_DO, _SD_CLK, _SD_DI, _SD_CS, _SD_WP, _SD_CD, -1, -1, -1) i:=fat.mountpartition(0) l:=fat.openfile(string("002.wav"),"R") repeat if inb[0]==1 l:=fat.readdata(@buf,1024) repeat i from 0 to 127 dirb:=i outb:=buf[i] dirb[8]:=1 if inb[1]==1 repeat i from 128 to 255 dirb:=i outb:=buf[i] dirb[8]:=1 until l<>1024 fat.closefilehttp://forums.parallax.com/showthread.php/140767-A-new-topic-for-vga-(not-only)-sid-player?p=1113690&viewfull=1#post1113690
This player contains a sidcog as an object and plays sids and wavs. It is made for the Propeller demo board. The keyboard, sd and vga is working now with a de2-115. All what was left to run it fully is to write a new sound driver and replace my existing ncowav with this Then we will have a sid/wav player running on de2-115. The sound hardware is working now, it only needs a procedure in pasm, spin is simply too slow to feed the samples @ 44100 Hz
If you want to try this player with a real Propeller demo board, compile it with bst or remove a demo method from the vga driver, or it doesn't fit in 32k.
{{ Sound driver for DE2-115 sound chip with the hardware controlled buffer v.0.01 - 20140817 inb [1..0] - lower/upper half of the buffer is empty dirb[7..0] - buffer address dirb[8] - write strobe outb[31..0] - sample data }} VAR long cog long buf[512] long bufnum pub getbuf return @buf pub getbufnum return @bufnum PUB start longfill(@buf,0,512) bufptr:=@buf stop cog:=1+cognew(@init, @bufnum) return cog PUB stop if cog>0 cogstop(cog-1) cog := 0 DAT org 0 'initialization init mov bufptr2,par loop mov a1,inb and a1,#1 cmp a1,#1 wz if_nz jmp #loop ' lower half of the buffer is empty mov a2,#0 p101 mov ptr,bufptr ' compute pointer to sample add ptr,bufcnt rdlong lsample,ptr add bufcnt,#4 and bufcnt,bufmask wrlong bufcnt,bufptr2 ' write actual sample number for main program mov dirb,a2 mov outb,lsample or dirb,#256 add a2,#1 cmp a2,#128 wz if_nz jmp #p101 p102 mov a1,inb and a1,#2 cmp a1,#2 wz if_nz jmp #p102 ' upper half of the buffer is empty mov a2,#0 p103 mov ptr,bufptr ' compute pointer to sample add ptr,bufcnt rdlong lsample,ptr add bufcnt,#4 and bufcnt,bufmask wrlong bufcnt,bufptr2 ' write actual sample number for main program mov a1,a2 add a1,#128 mov dirb,a1 mov outb,lsample or dirb,#256 add a2,#1 cmp a2,#128 wz if_nz jmp #p103 jmp #loop bufmask long 00_0000_0000_0000_0000_0111_1111_1111 bufptr long 0 bufptr2 long 0 bufcnt long 0 lsample res 1 ptr res 1 a1 res 1 a2 res 1 fit 496 {{ /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // TERMS OF USE: MIT License /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation // files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, // modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the // Software is furnished to do so, subject to the following conditions: // // The above copyright notice and this permission notice shall be included in all copies or substantial portions of the // Software. // // THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE // WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR // COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, // ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. ///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////Edit: seems to be better without this filter...
{{ FPGA sound driver for sidcog v0.02-20140817 Change from 0.01: some low pass filtering added Piotr Kardasz, pik33@o2.pl MIT license, see bottom }} VAR ' long bufnum long cog long bufnum pub getbufnum return @bufnum PUB start (addr) bufptr:=addr stop cog:=1+cognew(@init, @bufnum) return cog PUB stop if cog>0 cogstop(cog-1) cog := 0 DAT org 0 'initialization init mov bufptr2,par mov a2,#128 p102 mov a1,inb ' wait for upper buffer empty and a1,#2 cmp a1,#2 wz if_nz jmp #p102 ' p11 mov a1, inb 'wait for 0 on inb[2] - synchro and a1, #4 cmp a1,#0 wz if_nz jmp #p11 p1 mov a1, inb 'wait for 1 on inb[2] - synchro and a1, #4 cmp a1,#4 wz if_nz jmp #p1 rdlong lsample,bufptr sar lsample,#17 mov rsample,lsample add lsample,filter mov filter,rsample sar filter,#1 mov rsample, lsample shl rsample,#1 add lsample, rsample shl rsample,#1 add lsample, rsample sar lsample,#3 mov rsample,lsample shl rsample, #16 add lsample,rsample mov dirb,a2 mov outb,lsample or dirb,#256 add a2,#1 and a2,#255 jmp #p11 bufptr long 0 bufptr2 long 0 lsample res 1 rsample res 1 filter res 1 a1 res 1 a2 res 1 fit 496 {{ /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // TERMS OF USE: MIT License /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// // Permission is hereby granted, free of charge, to any person obtaining a copy of this software and associated documentation // files (the "Software"), to deal in the Software without restriction, including without limitation the rights to use, copy, // modify, merge, publish, distribute, sublicense, and/or sell copies of the Software, and to permit persons to whom the // Software is furnished to do so, subject to the following conditions: // // The above copyright notice and this permission notice shall be included in all copies or substantial portions of the // Software. // // THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE // WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR // COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, // ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. /////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// }}What I published yesterday was one of earlyr version of the project. It cannot run with attached player. Maybe it cannot run at all.
I will find and upload the proper quartus project as soon as I return home.
Changes:
- programmable via proplug instead rs232. The propplug has to be attached at the same pins as in the original Propeller DE2--115 design.
- the Propeller run @ 130 MHz
- the player now plays all files from the directory without any assistance
- patched some bugs in the player
I attached a bin archive with precompiled files.
I hope there was proper and working version uploaded (i will test this now). Please try if this works. The files are attached to the first post.
