Habor Freight reputation - Page 2 — Parallax Forums
2»
    edited 2014-08-16 19:09
    Genetix wrote: »
    I hope you used a 20% coupon.
    There wasn't one this week :frown: - but it was on sale for $100 off.
    edited 2014-08-16 19:15
    Ttailspin wrote: »
    You may want to grab a 417...
    Yeah - I've seen a number of reviews mentioning using other tips.
    Not ever having used a sprayer before, I was a bit overwhelmed at the care required of the mechanics. Every page in the manual was sternly warning that the warranty is void should the unit not be cleaned after every use. And then the priming and the flushing. I understand the need, just wasn't aware. I figure the time for priming and flushing is going to add at least an hour on to the time allocated for painting.
    I learned some things today...
    edited 2014-08-16 20:09
    Not ever having used a sprayer before,...
    Oh dear.. :innocent:
    Mask everything! Especially your face! no joke, it is a very fine mist cloud you will be working and breathing in.
    Try to get one of the charcoal canister respirators, and avoid the paper nuisance dust types. Very important. :nerd:
    Mask everything! Anything within 30' that you don't want painted, Mask it!. Wind is NOT your paint spraying friend. :)
    Oh ya, by the way, if you don't want to get over-spray on anything, Mask it!...
    Once you learn the steps, you will cut the prime and clean up time in half, they make it sound harder than it is. :)
    And don't forget to mask and cover anything you don't want painted... Thought I would mention that just in case you haven't heard it before..
    -Tommy
  • W9GFOW9GFO Posts: 4,010
    edited 2014-08-16 21:00
    davejames wrote: »
    Yes, there is, and you will be hard pressed to find any regular item over $100 at HF that is not "on sale". I'd bet that they never sell that for $299.
    20% off coupon
    edited 2014-08-16 21:03
    A sprayer doesn't do the whole job. You still need to brush the paint in afterwards to make sure it fills in all the minute cracks and crevices. At least that's how the guy who painted my house did it.
    edited 2014-08-16 22:58
    Ttailspin wrote: »
    ...were you saying something about masking?
    I'll be constructing a paint booth for the kitchen doors out of PVC piping and sheet plastic. That should cut down on the wind-swept spray. As for the kitchen cabinets themselves, lots of paper, plastic and tape will be used.
    edited 2014-08-16 23:00
    All surfaces have been prepped with sanding sealer, sanded smooth, and "tacked-clothed" to remove any dusty bits.
    Hoping the sprayed coat goes on nice and level.
    W9GFO wrote: »
    Yes, there is...
    ...oh well.
  • NWCCTVNWCCTV Posts: 3,629
    edited 2014-08-16 23:28
    And did you make sure to get your "Free" item???
    edited 2014-08-17 01:01
    I've only painted two houses with airless sprayers but neither required brushing afterward.
  • AGCBAGCB Posts: 344
    edited 2014-08-17 05:39
    I have many things from Harbor Freight. Stop every time I go to the city.
    3 rules I use:
    1. if you're trying to make a living with it, buy only the best
    2. if you try to use it at maximum capacity, it probably won't last long or do what you want
    3. buyer beware and do some research beforehand
    Aaron
    edited 2014-08-17 06:01
    W9GFO wrote: »
    20% off coupon
    Be careful to read the Fine Print
    970 x 118 - 38K
    edited 2014-08-17 10:32
    That doesn't stop my wife from dropping half a dozen coupons on the counter and giving the poor cashier "the look", The cashier usually buckles and scans at least two of the coupons.
    It is my wife's hobby to collect as much free stuff from Harbor Freight as possible. Hey, who am I to argue?
    edited 2014-08-17 10:43
    daveJames, are you spraying Lacquer? or Latex?
    Either way, be sure to practice going into and out of a corner, whether it's the transition from cabinet to ceiling, or cabinet to wall,
    those are the hardest spots to avoid sagging and running paints, Try to start away from the corner, and spray into it, If you start in the corner,
    The spray nozzle is standing still, and that will guarantee an overly heavy coat...
    edited 2014-08-17 11:03
    We just used it. It says "cannot be used with sale items" but we use it all the time with things that are "on sale". What they mean is you cannot use the 20% off coupon if you are already using a sale coupon.
    edited 2014-08-17 11:22
    W9GFO wrote: »
    What I was mainly pointing out was things excluded like compressors, generators, etc
  • GenetixGenetix Posts: 1,777
    edited 2014-08-17 23:11
    I guess thanks to Ron, Erco will need to shell out for a Craftsman or a Husky.
    edited 2014-08-18 22:13
    Ttailspin wrote: »
    Latex, semi-gloss.
    I'll be "practicing" on the cabinet shelves first, then move on to the doors we just purchased, then on to the cabinets in the kitchen.
    Thanks for the tips, TT.
    edited 2014-08-18 22:29
    Glad to help, Just remember to keep the tip moving any time you pull the trigger, and you will master it in no time. :thumb:
    For Latex paint, there is a product I like to use, called 'Flotrol', it is a Latex paint conditioner and will help the flow, and smooths the paint from the sprayer.
    And helps to keep the paint from drying before it hits the surface too. If you get a chance to try spraying with, and without Flotrol, you will notice a big difference.
    -Tommy
    edited 2014-08-18 23:20
    Ttailspin wrote: »
    ...'Flotrol', it is a Latex paint conditioner
    Roger that. I'd seen a number of reviews of the sprayer where this product was mentioned.
    I'll find a store and git sum.
    edited 2014-09-04 14:42
    ...so, an update.
    After attempting to use said sprayer, I've opted to just roll the paint. :blank:
    My hat's off to those that know how to use these things.
    edited 2014-09-04 16:13
    Oh dear... :)
    Hey Dave, I am only 2 1/2 hours from San Jose, I am not especially busy right now, If you would like some help/lessons with the thing, It's what I do.
    My wife and I could come up for a day trip, and we could show you how to use the Paint Sprayer,
    I think I already know what your doing wrong, Because I have seen this movie before... :)
    That's a legit offer bro, no charge, I like to help, and it would be fun for my wife too. Send me a PM, I have all next week free for sure, and I can Shuffle things around anyway.
    -Tommy
    edited 2014-09-05 06:55
    One thing anyone that has need for should look at is the red tool cabinets. They are really really good for the money. I have a couple now out my garage in the machine shop. Can't say enough good about them. You get great rolling drawers and padding, heavy gauge metal, and solid construction for what it would cost to buy complete junk at Lowes or Home Depot. I managed to get a couple back when they were not excluded from the 20% coupons. Even without though they are an excellent value.
    edited 2014-09-05 08:46
    Ttailspin wrote: »
    Send me a PM
    PM sent.
    edited 2014-09-05 09:46
    Tommy: bring Dave and his paint sprayer down to LA. You can practice on my house. That's a legit offer, zero charge to either of you. I just like to help! :)
    edited 2014-09-05 18:57
    Hrmmm, lemme think about it, lets see, A short tour of Silicon Valley and a return trip thru Carmel... Or..
    A tour of Bellflower with a return trip thru Compton...hmmm.
    That's a tough one...:)
