why does the BS2p40 not work?
Hello,
I have used the BS2 IC in past projects and it has turned out to be reliable and easy to use, i recently purchased THREE BS2p40 (@ $90 bucks a pop) for an application requiring more IO pins. unfortunately, i can not get any of them to be identified in the basic stamp editor software. I am using the professional development board pn# 28138 and expect these things to work. is this a design flaw in the chip? is there a work around? it seems like parallax is awfully quiet on this subject. has any one experienced this issue?
To help troubleshoot the issue it would help to answer some questions:
- Are you running the latest BASIC Stamp editor/tools?
- What type of system are you running and what OS version?
- Does your system have a real serial port or are you using a USB/Serial adapter?
- What kid of carrier board do you have holding the BS2p40 module? Is it on a breadboard?
- What are you powering the module with? Any pictures of your setup?
It can certainly be frustrating when things don't work but I'm sure that if you post some details on what you have and walk through each step it shouldn't be too hard to correct the issue.
Robert
Does a BS2 properly identify on the same board? Are you observing the Pin 1 orientation? (Just checking). What power supply are you using? BS2P40 draw a little more power.
Quiet on a subject that has not come up before?
EDIT Everyone types faster than me!
the PDB does indeed work with the BS2 IC, i have 3 BS2p40, and 3 BS2p24 that DO NOT work on the PDB. we have tried different serial to USB converters, and to no avail. in the editor software i do get an echo status of "yes" and a loopback status of "yes" but it does not identify the chip. i have removed and installed the chip multiple times for the BS2, the BS2 works EVERY time.
also, this issue HAS come up before, i did a bit of research on the web and many people have seen this issue.
2. windows 7 64 bit
3.no "real" serial port. i have used multiple serial-to-USB adapters
4. using the Professional Development Board parallax pn# 28138
5. 12vdc 600mA wall wart supply to the carrier board
thanks
i have gotten a hold of two people that have taken my information and said they will call back.... they have not.
i have described my issue and they said they have never heard of this before.
Do you have a :
http://www.parallax.com/product/28030
USB-Serial Converter?
It may be an issue with the faster Processors. Parallax products always work with the FTDI products.
moxa serial-to-USB converter, See my last post. Only FTDI are guaranteed to work.
Could you give a link? Maybe it has a resolution buried in there.
OK Josh. Just trying to help.
There are a few different chipsets used to convert the USB to a serial port. Common ones are FTDI, Silicon labs, and Prolifix. I tend to use adapters based on the FTDI chipset and have the best luck with those. When you plug one of these adapters into your computer it will show up as a COM port and act like the old built-in COM ports. The new COM port that would be higher than any of the #s you had before. If that isnt happening then it isnt being recognized by your computer. Either the driver isnt installed, there is an issue with the USB port on your system, or the cable is defective. I think some newer systems come with both USB 2.0 and USB 3.0 ports and I as I recall the USB 3.0 ports were supposed to have a blue connector. If it is in the USB 3.0 port then I would try plugging into a USB 2.0 port.
I believe it is the 'lsusb' command. You have several command line options that will provide extra details.
The environment is windows 7 64 bit. He is not using FTDI. The Parallax PDB expects FDTI for the higher clocked processors.
i was using a 12vdc wall wart that supplied 600mA. this evidently was not enough. in disbelief i was reluctant to try another one considering the avg power draw was at ~100mA for the whole system ie DEV board and BS2p40.
we wired the thing directly to a bench supply and blew open the current limit to 6I @12vdc......hesitant at first...
....but this this worked.
just a heads up if anyone uses a wall wart to power up.
thanks again everyone. i nearly soiled myself since i built an elaborate PCB to accommodate this chip.
"Nearly"? Really?
Pretty quick with the "POS" and the insinuations.
You must be a joy to work with. First - Panic!
Rick,
The BS2 Professional Development Board never had a USB Port for programming. It did have a Max232E available at an auxiliary port.
Glad you got it worked out!
That is a 2005 version Stamp PDB. It programs quite nicely via USB. I wonder why Parallax took it off in later revisions.
Josh, I have to wonder about the 12V, 600mA wall wart. I'd have to guess that it was defective, or something else is going that spoiled the power supply.
