Working with top Verilog modules
I own several Terasic FPGA boards that all come with demo projects that have a top level Verilog module that conveniently defines names and pins for all the FPGA board resources. .
So I took the DE2-115 Default project from the DE2-115 CD and added the following lines:
top top(CLOCK_50,
GPIO[27],
{GPIO[29],GPIO[31],GPIO[30], GPIO[28:0]},
LEDG[7:0]);
After copying the propeller design files to the DE2-115 folder, and adding the top.tdf file to the project this compiled ok and is running now
(to be honest: there was another assignment to the LEDG pins that had to be removed first)
I now plan to port the propeller design to some other boards, let you know.
top top(CLOCK_50,
GPIO[27],
LEDG[7:0]);
@pik33 Your method of making a symbol of the propeller is ok, only I am working also at the top level with Verilog. And I want to use the onboard resources (SRAM, SDRAM etc) so I wanted to have all the relevant pin names and definitions without duplicating them.
I am now going to make some revolution with the Propeller. After splitting Port B to in and out and testing this (good!) I want to get rid of top.tdf and the pll. Then split port A too, getting separate ina, outa, dira, inb, outb, dirb.
Bidir ports are rare needed in an FPGA environment. Where needed, I can make them outside a Propeller block, making things simpler.
Then we will have two 32 outputs, outb and dirb and one 32 input inb. Address, data in and data out.
Edit: done.
Edit 2: Now I can try to use my old modules intended to use with nios/qsys with the Propeller
Edit 3: DE2-115 SRAM/SDRAM may be available for LMM programs by loading the cog via inb port
