$10, 10-DOF Attitude/Barometric Sensor I2C — Parallax Forums
ercoerco Posts: 20,263
edited 2014-08-14 08:25 in Accessories
Actually $9.98 http://www.ebay.com/itm/400486732951
Mine just arrived (7-day ship), time to play. Cheap entertainment at less than a buck per DOF. Hope I don't lose the tiny little thing before I get a chance to release the magic smoke.
1. Nine axis modules (three-axis gyro + three axis acceleration + tri-axial magnetic field +BMP085 ).
2. Using immersion gold plating PCB process.
3. Module chips: L3G4200D+ADXL345+HMC5883L+BMP085.
4. Power supply: 3V-5V.
5. Communication mode: IIC communication protocol (fully compatible with 3-5V systems, including LLC circuit).
6. Board size: 25.8mm*16.8mm.
    edited 2014-08-13 15:52
    You are going to run this on a BS1 with 18 servos on a hexpod, right? :)
    edited 2014-08-13 15:59
    Not a bad deal since Adafruit wants $9.95 for the new barometric sensor by itself, replacing the old $19.95 board.
    edited 2014-08-13 16:11
    Publison wrote: »
    A BS1 is overkill. This will control a BEAM robot with two transistors and a 555 timer. :)
    edited 2014-08-13 17:04
    You almost had me with this one but they want an outrageous $1.98 for shipping?! Come on, it's only coming from China.
    I noticed, as with many cheap sensor boards, they didn't keep the copper pour out from under the HMC5883L chip. According to the HMC5883L datasheet, there shouldn't be any copper under the chip (on either side of the board). I doubt it really matters much. I've used boards with and without copper under the chip and I didn't notice a difference in performance.
    Code for interactive testing, and IMU project in progress:
    https://code.google.com/p/propforth/wiki/IMUdemo
    NOTE: May contain FORTH code. Kalman filter (using integer math) not yet available.
