$10, 10-DOF Attitude/Barometric Sensor I2C
Actually $9.98 http://www.ebay.com/itm/400486732951
Mine just arrived (7-day ship), time to play. Cheap entertainment at less than a buck per DOF. Hope I don't lose the tiny little thing before I get a chance to release the magic smoke.
1. Nine axis modules (three-axis gyro + three axis acceleration + tri-axial magnetic field +BMP085 ).
2. Using immersion gold plating PCB process.
3. Module chips: L3G4200D+ADXL345+HMC5883L+BMP085.
4. Power supply: 3V-5V.
5. Communication mode: IIC communication protocol (fully compatible with 3-5V systems, including LLC circuit).
6. Board size: 25.8mm*16.8mm.
You are going to run this on a BS1 with 18 servos on a hexpod, right?
A BS1 is overkill. This will control a BEAM robot with two transistors and a 555 timer.
I noticed, as with many cheap sensor boards, they didn't keep the copper pour out from under the HMC5883L chip. According to the HMC5883L datasheet, there shouldn't be any copper under the chip (on either side of the board). I doubt it really matters much. I've used boards with and without copper under the chip and I didn't notice a difference in performance.
Code for interactive testing, and IMU project in progress:
https://code.google.com/p/propforth/wiki/IMUdemo
NOTE: May contain FORTH code. Kalman filter (using integer math) not yet available.
