Questions on the P1 Verilog code to anyone...
I can see where the cogs are being generated. Its being done in dig.v file in the generate section with the for (i=0; i<8; i++)
What I cannot see is how this generate section actually causes the cogxxx.v filesto be included multiple times.
Seem that by setting cog cog_( .nres (nres), etc, the appropriate pieces are "pulled" in from the cog.v (and its children) file(s) for each loop.
Is this correct or could someone explain where/how this is done please?
Now, if I wanted to only generate the VGA section for cog 0, how would I do that?
I know when the cogs are itterated, I have a value of itteration in i.
Can I use that within cog.v to optionally include the line 'include "cog_vid.v" or should I optionally include the // vid section?
If so, what is the format, otherwise how do I do that?
Since i is also defined within the cog.v file, how do I use i from the dig.v file?
Thanks in advance.
Thanks in advance.
You can instantiate cog_vid as many times as you want without needing to include the source multiple times. You might also want to look up verilog parameters because you could use that to customize each instance.
See HDLCON 2002 for one that covers parameters. There might be some good examples in there. Oftentimes they are used to specify things like a bus width or FIFO depth, but you should be able to use them to specify things like how many cog_vids to instantiate.
Also if you're doing many instantiations of various things with a lot of wiring maybe take a look at verilog emacs mode. (http://www.veripool.org/wiki/verilog-mode) A lot of engineers like to use that for wiring up designs.
I think this example from the links given in #4 is what you want
I think this optionally externally over-rides a default value given to a Param within regblk
In dig.v there is the code which instantiates 8x cogs
In cog.v there is this section which instantiates a vid section for each cog instantiated.
But, I only want to instantiate a vid section for cog 0, so i want something like this...
Anyway, I am doing this to save gates on the FPGA. I wouldn't expect this to be in a final P1.5.
BTW I had just done some testing and each VGA uses on Cyclone IV EP4CE22..
~394 LEs
~163 Combinatorial
~152 Registers
0 Memory
BTW2 The EP4CE22 has 66Kx9bits of memory. Remember the 9th bit is unusable (unless going to 36bit which I think is way too complex for P1.5).
Gogs each use 2KB = 16KB, so that leaves 50KB for Hub Ram. IIRC 50KB didn't work.
Can you not use the method shown in post #5 ?
That has a default inner setting, over ruled by a passed value, which is what you want ?
The existing parameter statement is cog.v will generate a warning as they should be localparams change them if you wish.
Sorry, but I don't understand post #5 at all.
Willy,
Thankyou. That seems more like I am after so will give that a try.
I managed to set the outputs when i disabled the vga completely and this worked.
I am working with your solution but so far no success last night when i retired, although i am making progress.
Each time it fails quartus locks up partially and i have to close it. When i reopen, some v files are lost and i have to recopy all files back again.
Where i am up to is quartus complains about dig.v line 92 which is the line following the cogid declaration. It seems quartus is not seeing the cogid statement as a separate statement to the following statement.
I will post this section and the error in the morning (its 5:40am here).
Thanks for your help.
I believe that is what i have (on my xoom tablet in bed, haha).
But, is the indentation of the line following the cogid statement required? I dont think i have this.
BTW Does COGID need to be in caps? Another possibility.
BTW, this is an excellent idea for easily reducing used LEs!
That was my reason - to save logic in the smaller fpgas. We are going to need more space for new code.
This works but the commented section doesn't. To me they look the same??? Can you see a typo? Anyway, doesn't matter, its working thanks.
With 48B RAM, no ROM (so it will notwork at present) and VGA only available for cog 0, it saves ~1,500 LEs. There is more that could be saved as currently all cogs generate the resulting wires.
With all VGA removed, it saves ~3,150 LEs (13,029 vs 16,178)
Here are the cog.v changes (3 lines following the module... line)... and...
They differ on this line
[ cog_( .nres (nres), ] <> [ cog cog_( .nres (nres),]
It's just like you'd expect, but with the # replaced with verilog char ` (see `include)
`define dKeyWord
`ifdef dKeyWord
`else
`endif
See if you can handle it with parameters. defines are useful - we use them more for global things. e.g. FPGA versus ASIC. If you try to use them for heterogeneous cogs then you may run into some difficulties.
For reference, my code has all Hub RAM 48KB & Chips Reset fix for DIRA.
8 cogs with VGA:
14,683 LEs
13,359 Combinational
5,445 Registers
8 cogs but only 1 VGA (cog 0):
13,022 LEs
12,217 Combinational
4,381 Registers
8 cogs, and NO VGA:
13,022 LEs
12,051 Combinational
4,229 Registers
I did find that simplifying the statements around the vid generation for only cog 0 reduced the logic, depending on the arrangement.
For example, the two blocks below gave quite different results!!!
This significantly reduced the LEs used
And simpler again, but used the same as above cog-dig.zip
Can you give an original for reference (if the first one is not original ?) and the target device and reported MHz and reported % spare resource, for these builds.
With so many targets, and MHz values floating about, it can be good to know which is what.
Knowing how much is spare, gives an indication of what else could be included.
36b could be practically used for things like extending D,S fields, with little core code change.
It would give Binary super-set opcodes.
On the topic of FPGA RAM, I notice the Cyclone V has 10b quanta on BRAM, not 9, for 10K blocks, which means you could tile the memory 4 x 40 to have 5 columns, each 32b wide (but the height needs to be binary for simplicity?)
On a Cyclone V that means you could do 4 x 40, but read as 5x32, for 160k, freeing up 32 10K blocks, which could deliver COGs with an average of 1536 Longs.(and still have opcode bits spare in the 40b wide).
A mix of 2048 and 1024 would be one way to map that, or make them all 1536
Packs well into a Cyclone V, but is rather less FPGA portable, as I'm not sure who else has 10b wide memory ?.
