loop:
LOW motor
IF sensor1 = 1THEN start
GOTOloopstart:
HIGH motor
IF sensor2 = 1THENloopGOTO start
This is your original program. You have given us a picture of the track layout indicating that SENSOR 1 is on the lift hill downslope and SENSOR 2 is the buffer zone marker, opposite from what I conjectured earlier. Per the above quote from your recent post you state that Sensor 1 stops the motor and Sensor 2 starts the motor. But your program clearly states that when Sensor 1 = 1 then the motor is started, and when Sensor 2 = 1 then the motor is stopped.
Given the information you provided this is how I see things running:
1. Somehow the first train is caused to go down the lift hill downslope towards Sensor 1, upon passing the sensor the motor is turned on.
2. Train 2 is pulled up and hopefully makes the crest before train 1 hits sensor 2 and turns off the motor.
3. Train 1 passes Sensor 2 and turns off the motor and proceeds on to the bottom of the lift hill
4. Train 2 passes Sensor 1 and the motor turns on and Train 1 is lifted up the hill.
Is this what you intended?
My mistake.
The original code is correct. Switch sensor 1 and sensor 2 on the picture.
loop:
LOW motor
GOTOloopstart:
HIGH motor
1. is correct.
2. Train 2 is pulled up lift hill only after Train 1 hits Sensor 1.
3. Train 2 lift hill downslope and hits Sensor 2 (Thus Motor OFF).
Okay, based on your truth table here is the code that should work for your application, including adding an LED to P12 via a 220-470 ohm resistor. It will come on when the motor is on and go off when the motor is off. If your condition was based on a single value I would have used a SELECT...CASE statement. The following code isn't the most efficient, but it is structured to help you understand the correlation between my truth table and the logic needed to realize that via code. I hope this helps.
' {$STAMP BS2}' {$PBASIC 2.5}
sensor1 PIN 0
sensor2 PIN 15
motor PIN 8
led pin 12
INPUT sensor1
INPUT sensor2
OUTPUT motor
OUTPUT led
DO
IF sensor1 = 0AND sensor2 = 0 THEN
LOW motor
LOW led
ELSEIF sensor1 = 1AND sensor2 = 0 THEN
LOW motor
LOW led
ELSEIF sensor1 = 0AND sensor2 = 1 THEN
HIGH motor
HIGH led
ELSEIF sensor1 = 1AND sensor2 = 1 THEN
HIGH motor
HIGH led
ENDIF
LOOP
sensor1 PIN 0
sensor2 PIN 15
motor PIN 8
led pin 7
INPUT sensor1
INPUT sensor2
OUTPUT motor
OUTPUT led
DO
IF sensor1 = 0 AND sensor2 = 0 THEN
HIGH motor
HIGH led
ELSEIF sensor1 = 1 AND sensor2 = 0 THEN
HIGH motor
HIGH led
ELSEIF sensor1 = 0 AND sensor2 = 1 THEN
LOW motor
LOW led
ELSEIF sensor1 = 1 AND sensor2 = 1 THEN
HIGH motor
HIGH led
ENDIF
LOOP
Sensor 1 turns motor on.
Sensor 2 turns motor off
I want motor on by default.
So, is this right?
HIGH motor
HIGH led
I want Sensor 1 to take importance over Sensor 2.
So, is this right?
HIGH motor
HIGH led
As for the code. You should probably try the code as I posted it before making any modifications. The ON/OFF states were based on your feedback of the sensor states. If those are accurate it should run as you want. Making changes without understanding the code might cause unpredictable results. If the code doesn't work as it is supposed to then the truth table was not correctly filled out.
sensor1 PIN 0
sensor2 PIN 15
motor PIN 8
led pin 12
INPUT sensor1
INPUT sensor2
OUTPUT motor
OUTPUT led
DO
LOW motor
LOW led
LOW motor
LOW led
HIGH motor
HIGH led
HIGH motor
HIGH led
ENDIF
LOOP
Should LED pin be upper-cased or lower-cased? pin or PIN
I will let you know how the code works. First, I need the cord. So, I ordered it from your website and should be receiving it in the mail hopefully soon.
The program works. But, I would like the motor to turn off after sensor 2 is hit and wait for the motor to turn back on when sensor 1 is hit. As it is now, motor only turns off when sensor 2 is hit. Goes right back on after train leaves sensor 2 and does not wait for train to reach sensor 1 before motor is right back on.
sensor1 PIN 0
sensor2 PIN 15
motor PIN 8
led PIN 7
INPUT sensor1
INPUT sensor2
OUTPUT motor
OUTPUT led
DO
HIGH motor
HIGH led
HIGH motor
HIGH led
LOW motor
LOW led
HIGH motor
HIGH led
ENDIF
LOOP
That logic diagram has all possible states for the sensors and motors. You would have to update that to adjust the program logically. I used that to write the program rather than try to guess based on descriptions of motors versus trains versus sensors. Can you update that table?
at the risk of sounding old-school, you know what would really help, even over a diagram of the track and sensors? A truth table that shows the states of the sensors and the status of the motors for all states. With that most of us could write a new program in just a few minutes.
just just replace the question marks with what the motor status (on/off) should be in relation to these sensor conditions and a single loop program could be written in a just a few lines to handle this.
Hi Chris,
The motor turns off when sensor2 is hit. But,it does not remain off after IR beam is no long disrupted. Why? HOW do I fix this?
It looks like you've changed the code so it no longer matches the logic table. The following code matches your new criteria.
sensor1 PIN 0
sensor2 PIN 15
motor PIN 8
led PIN 12
INPUT sensor1
INPUT sensor2
OUTPUT motor
OUTPUT led
DO
high motor
high led
high motor
high led
low motor
low led
low motor
low led
ENDIF
LOOP
sensor1 PIN 0
sensor2 PIN 15
motor PIN 8
led PIN 12
INPUT sensor1
INPUT sensor2
OUTPUT motor
OUTPUT led
DO
high motor
high led
high motor
high led
low motor
low led
low motor
low led
ENDIF
LOOP
But the issue arises because the motor stays on, stops only when sensor2 is interrupted, then stays on indefinitely. I need (after sensor2 is interrupted) motor to stay off for at least 30 seconds (time to get to sensor1 to initiate motor again). Motor does not stay off after sensor2 is interrupted. How do I make it stay off?
Unless I missed something this 30-second thing was not mentioned previously and your original code did not account for it either. That requirement now complicates the process because now you need a time reference in seconds to handle that and you don't have that. I can't help wonder if the logic table is wrong for what you want/need?
The 30 second time is just approximate. The time for the code is not necessary.
I would like for train1 to hit sensor2 and turn motor off.
Then,
I would like train1 to hit sensor 1 and turn motor on.
From the logic table, only on or off for the sensor when IR is hit.
I want the motor off after sensor2 is hit. Please stay off.
Then,
I want motor on after sensor1 is hit. Please stay on.
I'm sorry. I am having trouble understanding what you're trying to do. Each solution I come up with seems to generate new criteria making it so I cannot ever meet the goal.
I look at things logically, but the control logic seems to keep changing. By default the table should work if the states are properly defined. Based on your answers the code does what you requested of the motor for each set of states of the pins. So I can only assume the answers to the table are wrong or I am misinterpreting your request.
The problem is that your requirement defies logic in a sense. Your original code did that, I believe. But you wanted it to be on default, but given the sensor states you require that isn't possible. Again, I may be missing something with all the changes, however can't have it both ways. It can't be "ON" by default if the code says that it should be "OFF" when a sensor says so. I will have to look back through everything to see if I missed something.
It looks like the problem might be that in the DO LOOP all sensor conditions are being evaluated constantly, and not waiting in a particular state until a train has crossed a sensor. That's why in the modified program the motor shuts off only while Sensor #2 is interrupted, but as soon as the train passes the sensor the first part of the Do Loop is satisfied and the motor turns back on. I think what Kyle is looking for is that when train 1 passes sensor 2 (on the downhill) the motor is to shut off and remain off until the train eventually passes over sensor 1, which turns the motor back on. At that point train 2 is lifted and allowed to roll down to repeat train 1 procedure. It is train 1 passing sensor 1 that allows train 2 to proceed safely.
I tend to think that the original program, as modified in Post 6 should work just fine, since it does wait for the changes. And it also addresses the original issue and starts the motor when power is first applied.
Yes, you and Chris are correct.
I have tried to swtich the two commands from Post 6.
However, PBasic says that "loop:" needs a DO preceeding.
LOOP is a reserved word in PBASIC Syntax 2.5 so you must either revert back to 2.0 which you were using before or change the word loop to something else.
Hal,
That would be the case if you didn't account for both states of the sensor, but the logic table accounts for all states for both sensors. So unless there are exceptions, the on/off state should be accounted for in each case. You mentioned the code in post 6, which if I recall reverses the subroutines from the original code. However the moment a sensor is activated the code would do exactly as it did before the swap. It also ignores a sensor while in each loop. One loop ignores sensor1 while the other ignores sensor2. Because of this you can't be dependant on sensor2 for anything once you're in the second loop.
My mistake.
Sorry.
1. is correct.
Repeats over and over again.
Thank you.
I just need to buy a part to connect the homework board to the computer.
I need to buy a female DB9 Serial connector.
Can I buy from your website?
I am using a HomeWork Board - Serial
' {$STAMP BS2}
' {$PBASIC 2.5}
sensor1 PIN 0
sensor2 PIN 15
motor PIN 8
led pin 7
INPUT sensor1
INPUT sensor2
OUTPUT motor
OUTPUT led
DO
HIGH motor
HIGH led
HIGH motor
HIGH led
LOW motor
LOW led
HIGH motor
HIGH led
ENDIF
LOOP
So, is this right?
HIGH motor
HIGH led
So, is this right?
HIGH motor
HIGH led
- Kyle
' {$STAMP BS2}
' {$PBASIC 2.5}
sensor1 PIN 0
sensor2 PIN 15
motor PIN 8
led PIN 7
INPUT sensor1
INPUT sensor2
OUTPUT motor
OUTPUT led
DO
HIGH motor
HIGH led
HIGH motor
HIGH led
LOW motor
LOW led
HIGH motor
HIGH led
ENDIF
LOOP
motor
on
on
off
off
motor
on
on
off
off
Hi Chris,
' {$STAMP BS2} ' {$PBASIC 2.5} sensor1 PIN 0 sensor2 PIN 15 motor PIN 8 led PIN 12 INPUT sensor1 INPUT sensor2 OUTPUT motor OUTPUT led DO IF sensor1 = 0 AND sensor2 = 0 THEN high motor high led ELSEIF sensor1 = 1 AND sensor2 = 0 THEN high motor high led ELSEIF sensor1 = 0 AND sensor2 = 1 THEN low motor low led ELSEIF sensor1 = 1 AND sensor2 = 1 THEN low motor low led ENDIF LOOP
Then,
Then,
Then,
I want motor off after sensor2 is hit.
Then,
Repeat.
Can anyone else clarify?
sensor2 is hit and motor stays off until sensor1 is hit.
How do I modify the code?
' {$STAMP BS2}
' {$PBASIC 2.5}
sensor1 PIN 0
sensor2 PIN 15
motor PIN 8
led pin 7
INPUT sensor1
INPUT sensor2
OUTPUT motor
OUTPUT led
start:
HIGH motor
IF sensor2 = 1 THEN loop
GOTO start
loop:
LOW motor
IF sensor1 = 1 THEN start
GOTO loop
END
Hal,
With those conditions Hal's code should work. And that assumes you do wish to ignore the other sensor in each case as described above.
