Using the BeMicroSDK to run Propeller1
Hi,
I already own an BeMicroSDK (and 3 other FPGA-boards) that seem to suit this project fine. It actually got the same FPGA as the Nano-board so it should work just fine.
I also already wired up card to the 80-pin connector on it to be able to interface my own ArcadeExtender card.
This gives the connectors to:
- 12-bit VGA
- Simple "SpaceInvaders" Stereo Sound
- PS/2 connector
- Atari/amiga Joystick
- MIDI-in
- SD-Card
So for now I just need to unpack these board.
Some questions: I just built the project wtih Quartus 13.0.1 and got: 67% logic usage and about 103Mhz of top-level Freq-max
- Why isn't any of the Multipliers (0/132) used? Doesn't Propeller use MUL?
- All Cogs seem to be able to run at least 230Mhz, could they be used as that? internal higher clock?
- 12-bit VGA
- PS/2 connector
- MIDI-in
- SD-Card
Try increase clock until it stop working
If you have any USB to FTDI cables/chips you are fine. The prop plug is just an FTDI chip. Same type of thing that is used by the Arduino/etc. All you need to do is connect GND, DTR, RX, and TX.
I had a quick look last night at what else is available for that connector. There are some analog devices SDP boards and adapter too.
The end-part (my ArcadeExtender) can be seen here..
ArcadeExtender
And the picture is taken from my crazy project to show the famous TestCard picture..
http://wedmark.se
I've bough the 80-pin connector board that had a prototype area.
