Using the BeMicroSDK to run Propeller1 — Parallax Forums
overclockedoverclocked Posts: 80
edited 2014-08-08 15:14 in Propeller 1
I already own an BeMicroSDK (and 3 other FPGA-boards) that seem to suit this project fine. It actually got the same FPGA as the Nano-board so it should work just fine.
I also already wired up card to the 80-pin connector on it to be able to interface my own ArcadeExtender card.
This gives the connectors to:
- 12-bit VGA
- Simple "SpaceInvaders" Stereo Sound
- PS/2 connector
- Atari/amiga Joystick
- MIDI-in
- SD-Card
So for now I just need to unpack these board.
Some questions: I just built the project wtih Quartus 13.0.1 and got: 67% logic usage and about 103Mhz of top-level Freq-max
- Why isn't any of the Multipliers (0/132) used? Doesn't Propeller use MUL?
- All Cogs seem to be able to run at least 230Mhz, could they be used as that? internal higher clock?
  • pik33pik33 Posts: 2,416
    edited 2014-08-08 11:21
    Prop doesn't use mul.
    Try increase clock until it stop working :)
  • overclockedoverclocked Posts: 80
    edited 2014-08-08 11:32
    Yea and big question. On a platform without comport and no prop.prog. what is the easiest way to use the normal toolchain for the prop?
  • KyeKye Posts: 2,200
    edited 2014-08-08 11:54
    There're MUL and MULS opcodes that were never implemented in the propeller instruction set. You could implement them to give yourself multiply and multiply signed support. However, none of the tool-chains will use those instruction. To put the instructions in your code you'll have to declare them as data.
    If you have any USB to FTDI cables/chips you are fine. The prop plug is just an FTDI chip. Same type of thing that is used by the Arduino/etc. All you need to do is connect GND, DTR, RX, and TX.
  • TubularTubular Posts: 4,768
    edited 2014-08-08 14:07
    Your board sounds very interesting. It'll go a lot of the way between bridging what we have on a DE0 vs all the connectors on a DE2. Hopefully it'll "just work" (most likely)
    I had a quick look last night at what else is available for that connector. There are some analog devices SDP boards and adapter too.
    Yea I'll find it and at least give you a peek at what it looks like when everything is connected.
    The end-part (my ArcadeExtender) can be seen here..
    ArcadeExtender
    And the picture is taken from my crazy project to show the famous TestCard picture..
    http://wedmark.se
    I
    've bough the 80-pin connector board that had a prototype area.
