Datasheet help on a relay — Parallax Forums
eagletalontimeagletalontim Posts: 1,399
edited 2014-08-07 20:06 in General Discussion
I have chosen a relay on Digikey and can't seem to figure out which pins are 1, 2, 3, or 4. The datasheet shows the proper polarity for each pin for the longest life of the relay, but I don't see the proper pin placement on the Terminal Assignment diagram.
Datasheet to relay : http://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=V23201-X0000-A001&DocType=DS&DocLang=English
Could someone take a look and see if you can figure it out or if I am missing something?
Thanks for any help!
  • SapphireSapphire Posts: 497
    edited 2014-08-07 20:02
    Look closely at page 3. There are two pins 4 and two pins 5. They are side-by-side. Pin 1 and pin 2 are smaller and by themselves.
  • eagletalontimeagletalontim Posts: 1,399
    I thought those 1 and 2 pins are mounting points not pins! Have I stayed up too late again? :P
    Thank you for pointing that out. I really need to work on designing patterns on the weekends, not after a 12 hour day at work....
