Datasheet help on a relay
eagletalontim
I have chosen a relay on Digikey and can't seem to figure out which pins are 1, 2, 3, or 4. The datasheet shows the proper polarity for each pin for the longest life of the relay, but I don't see the proper pin placement on the Terminal Assignment diagram.
Datasheet to relay : http://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=V23201-X0000-A001&DocType=DS&DocLang=English
Could someone take a look and see if you can figure it out or if I am missing something?
Thanks for any help!
Thank you for pointing that out. I really need to work on designing patterns on the weekends, not after a 12 hour day at work....
