Where can I get the TRRS cable for the Human Interface board?
blittled
I bought a 4 pole to 3 RCA plug A/V cable from Amazon but when I tried it using the TV graphic demo and connected the yellow, red and white RCA plug I get no picture. I can get a picture on red and white if I pull the plug out a bit. It appears that cable is not wired right for the HIB. Is there a good source for the cable?
I know the documentation explains what the TRRS cable is but most sellers don't give the pin out of cables. Also I talked to a fellow propeller friend and he says the jack on the HIB may be connected wrong.
