Where can I get the TRRS cable for the Human Interface board? — Parallax Forums
blittledblittled Posts: 695
edited 2014-08-04 19:02 in Propeller 1
I bought a 4 pole to 3 RCA plug A/V cable from Amazon but when I tried it using the TV graphic demo and connected the yellow, red and white RCA plug I get no picture. I can get a picture on red and white if I pull the plug out a bit. It appears that cable is not wired right for the HIB. Is there a good source for the cable?
  • blittledblittled Posts: 695
    edited 2014-07-30 17:30
    I just checked the cable with my meter and it shows the ground on the outer ring rather than the sleeve so it definitely is the wrong cable.
    edited 2014-08-04 04:59
    Hmmm... No answer. Does this mean there are no cables that work on this board? If so what are people using this board for? I was planning on using the audio and tv outputs so I'll probably have to buy a plug and clip off the one I had on the cable I bought and rewire it so it works.
    edited 2014-08-04 18:40
    Interesting, I lost sight of this thread but came back to it to look for answers, so I was surprised not to see any. I am checking with a colleague who deals with all sorts of cables to see what he can come up with as I have two that need TRRS cables.
    edited 2014-08-04 18:58
    wba, let us know what you find out. I rather get a ready made cable especially since the plugs will run about $7-10 due to shipping costs and that was more than the $5 I spent on my cable.
    I know the documentation explains what the TRRS cable is but most sellers don't give the pin out of cables. Also I talked to a fellow propeller friend and he says the jack on the HIB may be connected wrong.
  • JLockeJLocke Posts: 354
    I bought one of these myself several months ago, but haven't had any luck (yet) in figuring out where I bought it (!)
