Lesson learned: Debugging random crashes.
Spent 3 or so hours writing a device driver for a new SPI device.
Spent 4 or so hours trying to debug random crashes.
Spent 15 seconds replacing the battery.
Lesson Learned: Always develop on a power-supply.
But sometimes the reason behind them can't be readily found....
Turned out the LED I was expecting to flash was dead. WTF? I have never killed a LED, except back in '82 when I stress tested a red LED to death just to see what it's limits were.
Lesson learned: No matter what you do Murphy is out to get you.
Methinks you overheated the LED during your overzealous soldering, some of these packages are just plastic and the leg moves a bit breaking the internal bond wire. Or maybe it just LED you astray
I am easily LED astray.
