Lesson learned: Debugging random crashes. — Parallax Forums
__red____red__ Posts: 470
edited 2014-08-04 15:16 in General Discussion
Spent 3 or so hours writing a device driver for a new SPI device.
Spent 4 or so hours trying to debug random crashes.
Spent 15 seconds replacing the battery.
Lesson Learned: Always develop on a power-supply.
  • idbruceidbruce Posts: 6,197
    edited 2014-08-04 07:49
    That is a very good tip :)
  • ElectrodudeElectrodude Posts: 1,673
    edited 2014-08-04 11:09
    I once thought I had fried the BS2 on my BOE-Bot but I didn't discover until after I got a BS2PX to replace the BS2 that the BS2 still worked and the batteries were just dead.
    edited 2014-08-04 12:32
    There are no random crashes...
    But sometimes the reason behind them can't be readily found....
    edited 2014-08-04 13:40
    Good grief, I recently spent some hours wondering why my new hand made Propeller on a proto board did not work. It programmed OK according to propeller-load. Everything in the circuit checked out OK, power, ground, reset, etc.
    Turned out the LED I was expecting to flash was dead. WTF? I have never killed a LED, except back in '82 when I stress tested a red LED to death just to see what it's limits were.
    Lesson learned: No matter what you do Murphy is out to get you.
    edited 2014-08-04 14:37
    Heater. wrote: »
    Methinks you overheated the LED during your overzealous soldering, some of these packages are just plastic and the leg moves a bit breaking the internal bond wire. Or maybe it just LED you astray :smile:
    Err, yep and yep.
    I am easily LED astray.
