can't find PMB248gps or LISY300gyroscope modules
Working my way through Programming and Customizing the Multicore Propeller Microcontroller Book. I'm on chapter 4 which has examples using these two modules. Can I substitute PMB-688 SIRF module, and L3G4200D. I'm a beginner and hope to learn as much as I can from this book. I found some references in the forum to Omnitron's ParallexDirect.com but they don't have either. Not on Amazon or ebay. Will I be able to do the viewport exercises with the new modules and anything in subsequent chapters like dancebot?
thanks Patrick
thanks Patrick
Not sure about the LISY300/4200gyroscope since I cannot locate the data sheet for the LISY300. Probably are compatible.
And you can find code in the OBEX to run just about anything Parallax sells. It isn't to difficult to integrate into the Chapter 5 stuff.
You don't want to miss out on making a robot move with a Tilt controller, and Mapping out an area with a PING(((. :thumb::thumb:
-Tommy
Someone's hoarding, but for once it's not me.
thanks for the help
