DAT longs tinto bytes, Would someone smack me?
Oldbitcollector (Jeff)
I've starring at some DAT longs that I need to convert to DAT bytes.
The conversion is on the tip of my fingers, but I can't remember what it should look like.
Could someone write a DAT "BYTES" example of the sample below?
Utimately I'm working on the determination of how this looks as bytes in @tiles, but one step at a time.
Jeff
DAT
tiles
'' name=FONT_0, palette=0
long $000FFF00
long $00F00FF0
long $0FF000FF
long $0FF000FF
long $0FF000FF
long $00FF00F0
long $000FFF00
long $00000000
Jeff
DAT tiles '' name=FONT_0, palette=0 byte $00, $0F, $FF, $00 byte $00, $F0, $0F, $F0 byte $0F, $F0, $00, $FF byte $0F, $F0, $00, $FF byte $0F, $F0, $00, $FF byte $00, $FF, $00, $F0 byte $00, $0F, $FF, $00 byte $00, $00, $00, $00Perhaps it's my conversion routines.. back to the drawing board...
That explains why my characters are suddenly looking reversed
Ok, here's what I'm doing..
I've got a file I'm opening using FSRW which contains LONG style entries. (000FFF00 might be on a line)
I'm reading the first byte into "b", then the second byte into "c"
Then I'm passing them into this lovely routine.. (I'm sure there is a MUCH MORE elegant way to do this, but my brain thinks like this chunk of code.)
pub convert_sd_data(b,c) if b == 48 case c 48: return $00 49: return $01 50: return $02 51: return $03 52: return $04 53: return $05 54: return $06 55: return $07 56: return $08 57: return $09 65: return $0A 66: return $0B 67: return $0C 68: return $0D 69: return $0E 70: return $0F if b == 49 case c 48: return $10 49: return $11 50: return $12 51: return $13 52: return $14 53: return $15 54: return $16 55: return $17 56: return $18 57: return $19 65: return $1A 66: return $1B 67: return $1C 68: return $1D 69: return $1E 70: return $1F if b == 50 case c 48: return $20 49: return $21 50: return $22 51: return $23 52: return $24 53: return $25 54: return $26 55: return $27 56: return $28 57: return $29 65: return $2A 66: return $2B 67: return $2C 68: return $2D 69: return $2E 70: return $2F if b == 51 case c 48: return $30 49: return $31 50: return $32 51: return $33 52: return $34 53: return $35 54: return $36 55: return $37 56: return $38 57: return $39 65: return $3A 66: return $3B 67: return $3C 68: return $3D 69: return $3E 70: return $3F if b == 52 case c 48: return $40 49: return $41 50: return $42 51: return $43 52: return $44 53: return $45 54: return $46 55: return $47 56: return $48 57: return $49 65: return $4A 66: return $4B 67: return $4C 68: return $4D 69: return $4E 70: return $4F if b == 53 case c 48: return $50 49: return $51 50: return $52 51: return $53 52: return $54 53: return $55 54: return $56 55: return $57 56: return $58 57: return $59 65: return $5A 66: return $5B 67: return $5C 68: return $5D 69: return $5E 70: return $5F if b == 54 case c 48: return $60 49: return $61 50: return $62 51: return $63 52: return $64 53: return $65 54: return $66 55: return $67 56: return $68 57: return $69 65: return $6A 66: return $6B 67: return $6C 68: return $6D 69: return $6E 70: return $6F if b == 55 case c 48: return $70 49: return $71 50: return $72 51: return $73 52: return $74 53: return $75 54: return $76 55: return $77 56: return $78 57: return $79 65: return $7A 66: return $7B 67: return $7C 68: return $7D 69: return $7E 70: return $7F if b == 56 case c 48: return $80 49: return $81 50: return $82 51: return $83 52: return $84 53: return $85 54: return $86 55: return $87 56: return $88 57: return $89 65: return $8A 66: return $8B 67: return $8C 68: return $8D 69: return $8E 70: return $8F if b == 57 case c 48: return $90 49: return $91 50: return $92 51: return $93 52: return $94 53: return $95 54: return $96 55: return $97 56: return $98 57: return $99 65: return $9A 66: return $9B 67: return $9C 68: return $9D 69: return $9E 70: return $9F if b == 65 case c 48: return $A0 49: return $A1 50: return $A2 51: return $A3 52: return $A4 53: return $A5 54: return $A6 55: return $A7 56: return $A8 57: return $A9 65: return $AA 66: return $AB 67: return $AC 68: return $AD 69: return $AE 70: return $AF if b == 66 case c 48: return $B0 49: return $B1 50: return $B2 51: return $B3 52: return $B4 53: return $B5 54: return $B6 55: return $B7 56: return $B8 57: return $B9 65: return $BA 66: return $BB 67: return $BC 68: return $BD 69: return $BE 70: return $BF if b == 67 case c 48: return $C0 49: return $C1 50: return $C2 51: return $C3 52: return $C4 53: return $C5 54: return $C6 55: return $C7 56: return $C8 57: return $C9 65: return $CA 66: return $CB 67: return $CC 68: return $CD 69: return $CE 70: return $CF if b == 68 case c 48: return $D0 49: return $D1 50: return $D2 51: return $D3 52: return $D4 53: return $D5 54: return $D6 55: return $D7 56: return $D8 57: return $D9 65: return $DA 66: return $DB 67: return $DC 68: return $DD 69: return $DE 70: return $DF if b == 69 case c 48: return $E0 49: return $E1 50: return $E2 51: return $E3 52: return $E4 53: return $E5 54: return $E6 55: return $E7 56: return $E8 57: return $E9 65: return $EA 66: return $EB 67: return $EC 68: return $ED 69: return $EE 70: return $EF if b == 70 case c 48: return $F0 49: return $F1 50: return $F2 51: return $F3 52: return $F4 53: return $F5 54: return $F6 55: return $F7 56: return $F8 57: return $F9 65: return $FA 66: return $FB 67: return $FC 68: return $FD 69: return $FE 70: return $FFPST has a neat little "StrToBase" object which does this nicely.
I've got mine ultra complex routine working now thanks to you and Phil, but I'll also grab that StrToBase and see if we can do this conversion a little more intelligently than throw rocks at it.
Jeff
Here's my much shorter version.. I'll probably replace it with some decent math after I've had some sleep.
pub convert_sd_data(b,c) | calc case b 48: calc :=$00 49: calc :=$10 50: calc :=$20 51: calc :=$30 52: calc :=$40 53: calc :=$50 54: calc :=$60 55: calc :=$70 56: calc :=$80 57: calc :=$90 65: calc :=$A0 66: calc :=$B0 67: calc :=$C0 68: calc :=$D0 69: calc :=$E0 70: calc :=$F0 case c 48: return $00+calc 49: return $01+calc 50: return $02+calc 51: return $03+calc 52: return $04+calc 53: return $05+calc 54: return $06+calc 55: return $07+calc 56: return $08+calc 57: return $09+calc 65: return $0A+calc 66: return $0B+calc 67: return $0C+calc 68: return $0D+calc 69: return $0E+calc 70: return $0F+calcJust a hint. You can use:
case b 48..57: calc := b - 48The same thing written differently:
case b "0".."9": calc := b - "0"Do the same sort of thing with "A".."F".
Using this sort of arrangement you could shorten your case lists down to two groups each.
I know there are many versions of this sort of conversion floating around on the forum.
I was just going to start playing with that challenge after some coffee this morning. I've only downed half a cup and your message makes perfect sense.
Thanks again!
