little yellow motors versus servo motors
Cant sleep so time for another strange question. I want to mount a camera or distance sensor with 2d of freedom. I can buy servos for $14.00 or those little yellow motors used in robot kits for $3.50 here is a link http://www.ebay.com.au/itm/371094439398?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
what would you do ?
what would you do ?
If you need precise movement then use Stepper Motors.
How big is the camera?
Here is there work so far.... I was able to see some of their work about a week ago and they were fine tuning the trapezoid algorithm to minimize and eliminate overshoot error.
http://okrobotics.com/the-pan-tilt-zoom-story/ <- And they are using a Propeller :-)
@Genetix, just thinking of the cameras like those sold by Parallax. most stepper motors I found were $16 to $26 so I wonder what quality I get for 5 of them at total cost of $11, all done!
http://www.ebay.com.au/itm/5pcs-Stepper-Motor-DC-28BYJ-48-5V-ULN2003-Driver-Test-Module-Board-for-Arduino-/311014265101?pt=AU_B_I_Electrical_Test_Equipment&hash=item4869e5110d
@Beau, Very cool pan/tilt mechanisms. IMO, some sort of DC motor with encoder is the way to go. I'm still trying to get that sort of stuff figured out.
These look like DC brushed motors so you would need a dual H bridge to drive each one and an encoder or pot+adc for positioning. Probably less cost to use servos when all is said and done, but it depends on the application and precision required.
Based upon the experience level manifest in your other posts, I would recommend starting with an RC servo. They're relatively cheap, and they give you tremendous bang for the buck, in that they handle all of the litlle feedback and PID-control details for you. Obviously, with a geared-down little yellow brushed DC motor, a current-controlled H-bridge, an encoder, and sophiiscated programming, you could achive performance beyond that of a servo, but that's certainly not where I'd start.
I still hope to use the little motors with encoders I was experimenting with here to make some soft of pan tilt mechanism. But using DC motors with encoders as a DIY servo is far from trivial. I agree with Phil (generally a good idea) and think servos would be a much better choice in this case.
Erco, did you see this is for a pan/tilt camera mount? In other words, ARE YOU NUTS?
I picked up 2 Parallax servos from Radio Shack when they were discounted at $1 each. I was thinking of converting them to CR for a robot. Parallax servos are actually made by Futaba.
Duane, I don't know what Erco was on when he posted but he must have misread something.
The pan and tilt mechanism is made for standard servos though. The funny thing about that unit is its the same price from both the US and Australia. $5.95 but the US postage, the least expensive of 4 options was only $3.90...must be by submarine ? The cheapest Australian postage was a bit over $7.00 or maybe nearly $8 I don't remember exactly. But recently on the forum when I nominated aus LittleBird Electronics one poster said they have a lot more listed as In Stock than they actually do So I haven't decided which to purchase but I know that every couple of bucks that I don't worry about , does end up being a lot more in the end.. I can also wait as the more familiar I get with programming motors the better prepared I will be when it comes to putting it together.
I have bought two blue servos that looked exactly like the ones I saw in the picture of the tilt and pan mechanism., $6.00 each.
I just got in the mail two ADC chips from RS components, reasonable price and it was only a couple of days. but you don't want to buy a propeller chip from them. They have no postage charge but the chip alone is $30. True ! They stock a lot of Parallax but all the prices from chips to boe bots are very inflated. You would have to really really need it overnight to buy!
Sorry, my bad. Asleep at the wheel.
Keyboard.
Carry on!
Stick with Servos, Whteoxe.
In fact one person used a servo to operate a toilet because otherwise the handle needed to be held open. He pressed a button and a BS2 would hold the handle open for 10 seconds before closing it again. He even had it record the number of flushes on an LCD that sat on the top of the toilet.
They are tiny little things, if id paid more attention I would have noticed that they were micro servos. Will be interesting to hook them up and see how they perform. I dont expect very much .
By the way, regular servos can be modified for Continuous Rotation.
CR servos go round and round and all you can control is the speed and direction.
I think it was Erco who found servos at Hobby King for $6.
Im srtill waiting on the pan tilt mechanism to see what sevos i have will work with it.
