Support Issue
idbruce
Last Thursday, approximately at noon, I sent the following email to support@parallax.com:
My past experiences with Parallax support has always been pleasant and hasty, but it is now noontime Monday and I am beginning to wonder about the validity of the email address, because I thought it was a pretty simple question.
Bruce
Hello Parallax
I have a situation in which I want to modify a PropPlug PCB, to enable the USB plug to extend through a thin sheet metal panel (rear cover of an enclosurure). I would like to cut the PropPlug PCB back from the USB plug end until the the first USB plug mounting pad.
The question is, are there any circuit traces in between the USB plug end of the PropPlug PCB and the first mounting pad of the USB plug?
If it helps, I have both Rev.A and Rev.B PropPlugs.
Any effort you may put forth into answering this vital question for me, will be greatly appreciated.
Bruce Drummond
Bruce
This is something else. How would Apple reply to an email asking about cutting an iPhone PCB in half?
It maybe a simple question but. First someone has to find someone who designed the PropPlug or knows about it. That someone has to find the CAD files for it and see what is there. That someone then has to email you back. That's an hours work. Or dozens of times the profit on a PropPlug. I suspect these someones have far better things to be doing.
I bet someone on the forums knows
If I had to guess, I would think that you are way off.
I would guess that the schematics and board layouts for all Parallax products, past and previous, could be located by simply inserting the item number and performing a computer search.
In the mean time take a Dremel to it and see what happens.
I don't thinks so.
As for the comment:
That does not account for keeping a customer happy and maintaining good support. There are many other items that I have purchased and will purchase in the future, that I have not and will not require support for. A reply email is the least that is expected for good customer service, whether or not an answer is provided.
I know you want to know what you want know and probably don't want an alternative, but...couldn't you just extend the header end instead?
The serial signals are going to be far more forgiving of being lengthened than the USB signals.
C.W.
I really don't want to extend four pins out of an enclosure, which would make them susceptible to shorts and damage.
Thanks for replying.
First off, let me state that I am not upset, and I realize that stuff happens to humans. I just did not want to keep emailing if the email link was broken, and I did not want to call for support, because I think email and forum support is easier to maintain.
-MattG
What is your problem?
It's not a problem. I just wanted to save you from any future possibility of frustration first. I just spoke with David Carrier who designed this board and he should be replying soon with some information.
Oh, and guys, please let's not bicker in the forums. Thanks! :blank: That was for everyone.
I do not know for sure about that particular board but it appears the USB plug is surface mounted with no circuitry closer to the edge than the rear mounting tabs.
I took the original E-mail from you on Thursday, and was researching your question. Yes, I should have perhaps immediately replied, but I did not.
One would think that this would be a simple matter to resolve, and why I didn't reply immediately, since all I would need to do would be to review the Gerber files. There in lies the problem. In some cases the files are kept on the corporate drive, and in other cases they are not accessible. The latter of the two was the case here, and so I have been delayed on getting an answer back to you. Currently, I still don't have an answer as the person who designed the board is currently assigned on another project that he can not be detoured from.
My apologies for any delay or inconvenience.
I found some raw USB2SER PCBs and attached some pictures. The only layout difference from the Prop Plug is that one FT232R pin is connected to the 5v supply instead of the 3.3v supply. It doesn't affect any traces near the USB connector. You also don't have to wory about the traces between the four large rextangular pads that where the frame of the USB connector mounts, they are not electrically necessary.
David Carrier
Parallax Inc.
Thank you Beau for the explanation, no worries! I just wondered if anyone saw it
Thanks again Chris!
Parallax is still the BEST in my book.
A possible option that would 1) not require the risk and time to modify the propplug and 2) give you the mounting hardware for a panel mount USB connection. The product description is here:
Good quality super speed usb b type female to mini usb extension cable with panel mount screws
Mini USB male to female extension cable
Cable length: about 0.3m / 30cm
Panel Mount USB Cable – Mini USB Male to B Female
Product page is here:
http://www.moddiy.com/products/Mini-USB-to-USB-Type%252dB-Extension-Cable-with-Panel-Mounts-(Black).html?gclid=CjwKEAjw9LKeBRDurOugs43jnlgSJACUXqHx-dd_zpjnB-gxWjM-d_C7ZrqW0JyfkFiEkGzzBqmrThoCRsLw_wcB
A picture of the item is here:
http://www.moddiy.com/product_images/t/375/Mini_USB_to_USB_Type-B_Extension_Cable_with_Panel_Mounts_%28Black%29__06269_zoom.jpg
I can't vouch for that particular company, but it seems like there should be other solutions similar to this in case modding the plug isn't feasible for whatever reason. Food for thought at least.
Vern
In fact I AM going for it already.
(Using a similar cable to 'export' the USB connector on the SmoothieBoard controller on my ShapeOko CnC-Mill)
If they had gone back further with the mounting flanges, it would be a potential solution for the price, but then you are bound by the length. I plan to make my own 4 pin cable to length, not too much or too little, but just right. However, thanks for posting information about it, because I will certainly bookmark it.
Now, if the Parallax email server doesn't automatically send out a confirmation to messages sent to support at parallax.com, it probably should. But even then, I imagine a question like yours will require the attention of not just a front-line support tech, but a senior developer. Let's be honest here, and realize those kinds of questions can take another day or two.
My original post was not intended to be a complaint, just a concern.
That would be a good idea
I have now trimmed a PropPlug Rev. A. back to the first USB plug mounting tab. A simple test of "Identify Hardware" with the Propeller Tool, provides a result of "Propeller chip version 1 found on COM3".
It appears that all is good. Many thanks guys. I will provide a photo of the end result, when I get the PropPlug attached to a mounting bracket.
Since yesterday, I have been pondering various mounting solutions. Whatever direction I turned, the molded plastic that sat on top of the PropPlug, became an obstacle. After getting tired of trying to work around this obstacle, I decided to try and remove it. To my amazement, it was basically just a raised decal of some sort and was easily removed. I have always thought that the molded plastic was somehow permanently bonded to the PCB to prevent removal and now I wish I had tried that a long time ago.
With the excess PCB material and decal removed, mounting the PropPlug to a mounting bracket should be a breeze. It is simply a matter of taking a piece of plastic, cutting a channel in it for the PCB to rest in, while also centering the USB plug, securing the PCB to the plastic with two small screws, and drilling two holes for the panel mount.
That was my initial thought, until I made a big glob of hot glue. When fully hardened, the glue is still highly flexible. Although I may still use glue as extra added insurance to prevent movement. As for the epoxy, well that is just too unforgiving for all the mistakes I make
