Cheap Bluetooth modules
Hugh
I've just acquired one of these bluetooth modules via eBay. I wondered if anyone else had played with these?
It binds with the PC and, if TX is connected to RX, echoes back in the Serial Terminal. No joy when connected to the Prop
(SimpleSerial, FullDuplexSerial (and all modes) tried; 5K pull-up and pull-down resistor also tried).
Buy cheap - buy twice!
![IMG_2510[1].jpg](https://forums.parallax.com/uploads/attachments/54682/104798.jpg)
http://propellerpowered.com/forum/index.php?topic=386.msg2100#msg2100
http://propellerpowered.com/shop/?page_id=1748
Bluetooth Helper..
Jeff
Yes, it did need 5V Bill, Thank you!... :thumb:
Yes, that did help, Jeff. Thank you! :thumb:
All sorted!
(I searched for Bluetooth modules, etc., before I posted but didn't come across Bill'sthread - I do wonder about the Search sometimes...)
You are welcome :-)
CRST1:
The module needs to be powered by 5V
You can connect the Prop's TX to the modules RX
You must put a resistor between the Prop's RX and the modules TX, or you will fry the pin
