Project Board
What happened to it? What is getting revised? Hopefully a better 3.3V regulator circuit cause I've lost 2 of these boards to that. I'll try a couple of the activity boards for now. Haven't tried those yet.
Marcus
Marcus
Do you have a link to that problem?
I'm not aware of that.
Publison,
Here is one example of someone else having the same issue I've now had with (2) of these boards: http://forums.parallax.com/showthread.php/156378-I-ve-killed-a-Project-Board.
Both times it happened I removed every component from the prototyping area. And I checked that there were no shorts between 3.3V and gnd. If the board is powered by the 3.3V rail from an external regulated source it powers up normally. Also, the FTDI chip functions on it's own just fine. I feel that the 3.3V regulation employed on the Project Board is more sensitive than that of it's predecessors.
Marcus
From the Product Page:
This product is currently under revision. We expect to to stock the board again in the future.
For this reason, I prefer to use 6V 1A power packs. I do measure the voltages just to check.
For the VGA issue and workarounds, I guess Dave means this thread: http://forums.parallax.com/showthread.php/146944-Propeller-Project-Board-USB-VGA-issues?highlight=moskog
I`ve used a lot of this boards and really likes the layout with all pins accessible through the 40-pin header.
Hope Tech Support clarifies soon.
There are two changes. First, two diodes were specified for much less current. Next, there was a VGA signal trace too close to the clock trace, causing VGA display issues. Using the VGA circuit was interfering with the Propeller's clock circuitry.
It's going to take a total of six months to get the design done and back into inventory.
I am certain we should have these by early January.
Thanks again for let us know. Looking forward to the new revision of the cards.
Wait a minute. The whole point is that the Propeller generates the VGA signals itself and drives whatever pins VGA requires directly.
http://www.parallax.com/product/32212
IMHO, this is one of the best Introduction to the Propeller boards I'd ever encountered..
Yes, these are great. Only issue is having to have the prop plug which I loose/break too often
-Marcus
Hope for a fix for the VGA-bug anyway on the new revision. That would be nice. I love these boards to give projects a permanent home. USB connection is great so you have not to worrie about where your PropPlug is... It always hides somwhere
OK, thats great, I need a few of them soon for my weather station project where VGA will be used, so you can expect an order as soon as the modified ones are available.
Yeah!
