New 'Bot in the House
Well almost in the house that is. Wand'ring around eBay this week, I came across this fellow...
http://www.ebay.com/itm/Parallax-Basic-Stamp-Toddler-Robot-/171349894637?_ilink=&_trkparms=gh1g%3DI171349894637.N9.S2.M-195.R2.TR6&_trksid=p2047675.l2557&nma=true&si=TtKnF%2BcAfUXyG7ecHUB0KotOXbI%3D&orig_cvip=true&rt=nc
Should be a nice fit with the other guys.
Amanda
Amanda
Tod?
Way to score, Amanda!
Major win. That's a first-generation Toddler before he got off-shored to China for production. Let me flip into my "Antique Roadshow" mode for a minute.
The first generation Toddlers had CNC-machined legs with Allodyne coating. Parallax paid an astounding $17 per leg (a Toddler has four of them, of course) but they were really pretty robot legs. Then, the Toddler went to China and the legs became aluminum sand-cast. While they were equally functional (and very low-cost), they were nowhere near as beautiful as the first generation Toddler legs. Strangely, Parallax brought the Toddler manufacturing back to the USA and again made the CNC-machined legs in the last third of Toddler's life.
You own a first-generation Toddler. Congratulations!
Be sure to loosen the collars that hold the legs on the Toddler's body and turn them around. At present the hip joint is facing outward on all four legs.
You'll see my name is on the book, if was provided. I'm still trying to figure out how we wrote that code. The various pointers still make my head spin.
Let me know if you need any spare parts, too!
Sincerely,
Of course a set of 1st generation ones would be even nicer. But I suppose if you have any, they should be held on to for worthy rebuilds. In my case, I have sanded down the blue finish and repainted everything gloss black.
And, I have swapped out the BS2 board with a Propeller Proto Board. Not exactly standard kit. I also have an SX48 board that is fitted to the Toddler. These boards work with some very careful drilling of a couple of additional holes in exactly the right locations.
Paint on aluminum is horrible. Have a company strip off the old anodize and do it again. I would suggest type III, hard anodize, which is extremely durable.
Just remember the big mistake I made. Be sure to specify the color you want otherwise your parts may come back some strange color.
Congrats, Amanda. I did see that one but didn't bid. Now Ken says it's a special Gen 1 and I'm kicking myself for using a smidgen of restraint! Ah well, as long as Todd (if I may so presume) is going to a good home, that's the important thing.
You've seen my robot room video, now how about showing us your still-growing bot collection?
As you, I had no idea. I really wanted to buy that toddler (in parts I think) a while back, but I couldn't afford it. Thought I spent a little bit more than was prudent on this one, but not =that= bad.
The name... probably, will start with a "T", but I haven't decided yet! :-)
When "T" arrives, I'll post a pic.
Amanda
I must be ill. Suddenly I'm posting about all the things I'm NOT buying. Must go lay down. http://forums.parallax.com/showthread.php/156023-8.75-Sensor-Sampler?p=1273086&viewfull=1#post1273086
Welcome to the Gold Toddler Owners Group!
I bought mine new-in-box a couple of years ago from Canada, it was their last one.
I am proud to own something that erco does not have, (yet).
http://forums.parallax.com/showthread.php/149087-Very-old-Milinst-Stambug?highlight=Toddler
(Post #32)
Jim
Thanks erco!
Heh... the name "Tod" did come to mind, but that's awfully obvious. The character from South Park was a consideration... "TIMMIAH!" ;-) Also... all my 'bots seem to have guy's names... perhaps a female name is needed and with the experience I have with my current bipeds the name of the actress from Hitchcock's "The Birds" seemed a natural... "Tippi".
The collection isn't that large. The first two Ted 'bots wore out the Tamiya tracks and went back into the parts bin. I could never get Wilbur to work properly and he sits in pieces in a bookcase. I had a blue Scribbler, but recently sent it to the boys of a friend in Australia ('Twas a huge hit!!!) The remaining ones...
Wilson, the two wheel, Xbee controlled critter.
Next there is Percival the Penguin, Clyde the Clear 'Bot, Ted #3, Stanley the S2 and Scooter the 4 DOF biped.
Here, Wally the 6DOF biped, a robotic arm I'm tinkering with (currently not named, but "Claude" comes to mind) and my BoeBot "Bob" currently set up to be remotely controlled via an Xbee.
That's the clan right now. I'll post a couple of good pictures of the Toddler when it arrives.
Hey Andy! Those tracks are from Lynxmotion.
http://www.robotshop.com/en/lynxmotion-track-trk-01.html
Anyhow...
Looks like a few bits worked loose during his journey and I need to check if the batteries caused any damage (shipping it with the batteries installed???).
Ken,
Thank you for the information and your kind offer!
I reversed the legs per your advice... wasn't as complicated as I first thought (piece of cake!).
There was nothing missing mechanically on Tippi, save a couple of 4-40 screws attaching the logic board. Easily replaced from the hardware bin.
Not surprisingly, none of the add-on electrical/electronic bits and pieces made the trip. Again, I think I have (or can find) all of these in the dark recesses of my bedro.... I mean Laboratory. :-)
Just one question tho'... one of the 5-pin headers for the IR LED/sensors wasn't soldered correctly to the board and it bends back and forth disturbingly. Would it damage anything to lay the tip of my soldering iron across all 5 pins on the underside of the board till the solder softens enough to seat the header. I surely don't want to damage a classic like this!!!!!!
Thanks again!
Amanda
PS.,, Y'all rule!
Ken, what changes were made to later versions of the Toddler board? Anything significant?
I'm guessing the previous owner didn't assemble the board... I could be wrong tho'. Anyhow, just asking the best way I can fix it. ;-)
I'd like to see that! :-)
