sony ACX705AKM LCD
I came across this SONY LCD - ACX705AKM for $20.00 in Electronic Goldmine.
Can I use this with the Prop if so-DO I need any extra hardware to connect it to the prop.I have a Parallax Proto Board with
a VGA /keyboard/mouse ports.
If I can use the sony - LCD - I would appreciate some guidance.
Siri
Siri
That is far beyond my skills.
Siri
solder the pins which are closer together than the ones on the Prop on the Proto Board, and it
looks like I'd be soldering hair-guage magnet wire to it if I could anyway.
Otherwise, I think it would probably work with a VGA driver... but without the DAC resistors.
You can tap into it with VGA, and drive it at full resolution which is 640x480.
They are going one ebay right now for arround $20 if you catch them.
Of course, it will cost you another $10 to ship, but $30 for a full VGA screen is pretty good.
Here is a link to an AVR based project.
http://www.dutchtronix.com/AVCX-LCD-Controller.htm
http://www.goldmine-elec-products.com/prodinfo.asp?number=G13752
