Convert hex string to decimal
Hi, I have been searching all over and can't find the answer. Maybe I am missing something but here goes. I have a serial imput from an xbee. In the string it has the value of the adc channel as a hex string like 02F1 and CR . I can't figure how to convert the hex string to a decimal long variable. I have found the string to dec but I don't think that will work with hex strings will it?
Thanks for any help.
Sometimes we can spend far more time trying to find the solution to a problem rather than solving it. In this case solving is very easy, starting with an initial result of zero, repeat 4 times or until a CR is detected - shift result left 4 bits (hex shift), subtract $30 from the next character and if the result > 9 then subtract 7 and add this to the result - after all this you will have the number.
I think I must be brain dead. I'm still a little confused with the shift method. If I have a string of 02F1 could you show me a code example of what you described? I can't seem to get it into my head.
RESULT = 0
REPEAT WHILE CH <> $0D
RESULT = RESULT <<4 (*16 or shift what we have at this point to the left one nibble (hex char) place )
N = CH-$30 (assuming we read the next character from the buffer)
IF N > 9 THEN N = N-7 ( this converts an ASCII 0-9 to 0..9 or an A-F (>9 after subtract) to $0A..$0F )
RESULT = RESULT + N ( since the right most nibble is zero because it has already been shift left 4 place all we need to do is insert the next nibble with a + )
So assuming we are converting 012F<cr> :
RESULT = 0
RESULT = 0 <<4
"0" - $30 --> 0 and it's not > 9
RESULT = 0+0 = 0
next character
RESULT = 0 << 4 = 0
"1" - $30 --> 1 and it's not > 9
RESULT = 0+1 = 1
next character
RESULT = 1 <<4 = $10
"2" - $30 --> 2 and it's not > 9
RESULT = $10+2 = $12
next character
RESULT = $12 << 4 = $120
"F" - $30 --> $16 and it's > 9 so subtract another 7 ---> $0F
RESULT = $120 + $0F = $12F
next character $0D terminates loop with RESULT = $012F
pub gethex(str) | char repeat while byte[str] == " " str++ repeat char := byte[str++] case char "0".."9": result := (result << 4) + char - "0" "a".."f": result := (result << 4) + char - "a" + 10 "A".."F": result := (result << 4) + char - "A" + 10 other : quitThank you
PUB HToI( strptr ) : int | c {{ * Converts a hexadecimal string to an integer > strptr : pointer to a string with a hexadecimal number in it < Returns the integer, or 0 if no base-16 digits were found. e.g. i := HToI( string( "2A" ) ) ' returns 42 }} repeat while c := lookdown( byte[strptr++] : "a".."f","0".."9","A".."F" ) ' we got something new int <<= 4 int |= (c + 9) & 15This version also handles lower or upper case characters.Jonathan
IMO, it's a shame they made it a private method (as they did "RxCheck").
PRI StrToBase(stringptr, base) : value | chr, index{Converts a zero terminated string representation of a number to a value in the designated base. Ignores all non-digit characters (except negative (-) when base is decimal (10)).} value := index := 0 repeat until ((chr := byte[stringptr][index++]) == 0) chr := -15 + --chr & 011111 + 39*(chr > 56) 'Make "0"-"9","A"-"F","a"-"f" be 0 - 15, others out of range if (chr > -1) and (chr < base) 'Accumulate valid values into result; ignore others value := value * base + chr if (base == 10) and (byte[stringptr] == "-") 'If decimal, address negative sign; ignore otherwise value := - valueIMO, it's a nice bit of code.
