Convert hex string to decimal — Parallax Forums
CRST1CRST1 Posts: 106
edited 2014-06-30 10:29 in Propeller 1
Hi, I have been searching all over and can't find the answer. Maybe I am missing something but here goes. I have a serial imput from an xbee. In the string it has the value of the adc channel as a hex string like 02F1 and CR . I can't figure how to convert the hex string to a decimal long variable. I have found the string to dec but I don't think that will work with hex strings will it?
Thanks for any help.
    edited 2014-06-30 05:02
    Check the Numbers object, specifically the FromStr method.
    edited 2014-06-30 05:10
    CRST1 wrote: »
    Sometimes we can spend far more time trying to find the solution to a problem rather than solving it. In this case solving is very easy, starting with an initial result of zero, repeat 4 times or until a CR is detected - shift result left 4 bits (hex shift), subtract $30 from the next character and if the result > 9 then subtract 7 and add this to the result - after all this you will have the number.
  • CRST1CRST1 Posts: 106
    edited 2014-06-30 05:29
    Thank you, I will try the shift method. The information in the numbers object is confusing to me. It doesn't show anything about hex string just dec string so I wasn't sure if it would.
    edited 2014-06-30 05:44
    Peter,
    I think I must be brain dead. I'm still a little confused with the shift method. If I have a string of 02F1 could you show me a code example of what you described? I can't seem to get it into my head.
    edited 2014-06-30 05:50
    Ok, I might have it. Was the shift just to get rid of the first 0? So the 2 would be equal to $32 and subtract $30 you end up with 2, correct? But in this case it would be 2 * 256 correct?
    edited 2014-06-30 06:03
    CRST1 wrote: »
    RESULT = 0
    REPEAT WHILE CH <> $0D
    RESULT = RESULT <<4 (*16 or shift what we have at this point to the left one nibble (hex char) place )
    N = CH-$30 (assuming we read the next character from the buffer)
    IF N > 9 THEN N = N-7 ( this converts an ASCII 0-9 to 0..9 or an A-F (>9 after subtract) to $0A..$0F )
    RESULT = RESULT + N ( since the right most nibble is zero because it has already been shift left 4 place all we need to do is insert the next nibble with a + )
    So assuming we are converting 012F<cr> :
    RESULT = 0
    RESULT = 0 <<4
    "0" - $30 --> 0 and it's not > 9
    RESULT = 0+0 = 0
    next character
    RESULT = 0 << 4 = 0
    "1" - $30 --> 1 and it's not > 9
    RESULT = 0+1 = 1
    next character
    RESULT = 1 <<4 = $10
    "2" - $30 --> 2 and it's not > 9
    RESULT = $10+2 = $12
    next character
    RESULT = $12 << 4 = $120
    "F" - $30 --> $16 and it's > 9 so subtract another 7 ---> $0F
    RESULT = $120 + $0F = $12F
    next character $0D terminates loop with RESULT = $012F
    edited 2014-06-30 06:06
    pub gethex(str) | char
      repeat while byte[str] == " "
        str++
      repeat
        char := byte[str++]
        case char
          "0".."9": result := (result << 4) + char - "0"
          "a".."f": result := (result << 4) + char - "a" + 10
          "A".."F": result := (result << 4) + char - "A" + 10
          other   : quit
    edited 2014-06-30 06:19
    OK, thank you very much. With the help I think I got my head wraped around it now. I do have it working now that I can see it.
    Thank you
  • lonesocklonesock Posts: 917
    edited 2014-06-30 10:17
    I like the 'lookdown' method for this:
    PUB HToI( strptr ) : int | c
      * Converts a hexadecimal string to an integer
      > strptr : pointer to a string with a hexadecimal number in it
      < Returns the integer, or 0 if no base-16 digits were found.
      e.g. i := HToI( string( "2A" ) )  ' returns 42
      repeat while c := lookdown( byte[strptr++] : "a".."f","0".."9","A".."F" )
        ' we got something new
        int <<= 4
        int |= (c + 9) & 15
    This version also handles lower or upper case characters.
    Jonathan
    The "StrToBase" method in Parallax Serial Terminal.spin will do this for any base. You could just add it to whichever serial driver you're using.
    IMO, it's a shame they made it a private method (as they did "RxCheck").
    PRI StrToBase(stringptr, base) : value | chr, index{Converts a zero terminated string representation of a number to a value in the designated base.
    Ignores all non-digit characters (except negative (-) when base is decimal (10)).}
      value := index := 0
      repeat until ((chr := byte[stringptr][index++]) == 0)
        chr := -15 + --chr & 011111 + 39*(chr > 56)                              'Make "0"-"9","A"-"F","a"-"f" be 0 - 15, others out of range
        if (chr > -1) and (chr < base)                                              'Accumulate valid values into result; ignore others
          value := value * base + chr
      if (base == 10) and (byte[stringptr] == "-")                                  'If decimal, address negative sign; ignore otherwise
        value := - value
    IMO, it's a nice bit of code.
