Parallax Schmartboard Solder Question
NWCCTV
I am getting ready to solder up my Schmartboard and have a question. The instructions say to use Lead Free solder. However, I only have lead solder at the moment and want to know if it is OK to use that. I really do not want to run down the road to the Shack during rush hour if I do not have to. I will order some lead free this weekend so I can get with the times!!!!
I wouldn't worry about it. In my EE days leaded solder was all there was. When soldering careful not to inhale the fumes and be sure to wash your hands well before handling food. Here at home I have lead solder and lead free solder and find that the solder with lead is easier to work with but I don't see intentionally buying any more solder with lead.
Leaded is OK. It melts a a lower temperature. Easier to solder.
I did my Schmartboard with Kester 63/37 solder.
Now where can I get leaded Gas?
Honestly I suspect that it will work as long as the iron is hot, the tip is clean, and you use extra flux.
Tip temp needs be a little hotter, but it flowed just fine. I think I set mine to 675F.
And lots of flux.
EDIT: I have suction on my soldering station that does a pretty good job of pulling in the fumes. Also, my back door is wide open!!!
Personally I've long felt that the reason not to breath the fumes given off when soldering was the flux and having that harden in my lungs would probably be bad!
You'll still need to add your own solder.
I generally have my iron set to 720 degrees but keep the contact time short with the Prop pins. I know from experience the Prop can be damaged if the hot iron is left on a pin too long.
Have you soldered these sorts of chips before? I've gotten used to soldering surface mount Props but the first few I did were a challenge.
While that may be true for some brands of solder, it is not a blanket truth. The no-clean solders that I use have the same flux core for both alloys. At work, we use the same no-clean flux and the same water soluble flux for wavesoldering Tin Lead and Lead Free boards.
The most typical lead free solder, SAC305, is liquidus at 217 C and is normally hand-soldered with 700 degree tips. When I soldered a Prop Schmartboard a couple years ago, I added a bit of liquid flux and it worked fine. Lacking liquid flux, I would do as others suggested, and add some fresh solder that as a no-clean flux core. Rosin core is fine, but there are many newer types that have much better performance like Kester 275.
The tip really has to get down into that channel. It's supposed to be "easier" with those, I guess, but having made the best of the "hard way" for so long, these moved me to intemperate language.
Perhaps the best candidates for schmartboarding are those who know nothing else?
