Power surge with 74HC595 — Parallax Forums
alnajjar1alnajjar1 Posts: 110
edited 2014-06-26 17:52 in BASIC Stamp
Hello,
I am using a BS2 and 74HC595 in a chain to turn on 64 LEDs. It works beautifully but the only problem is that upon power up, all LEDs come on for a fraction of a second of a second. I send a "0" to all the 595s in the first line of the code but still have the initial All-on at start up. How can I avoid that?
Many thanks in advance
Al
  • bruceebrucee Posts: 245
    edited 2014-06-26 15:35
    Connect up OE and control it from the BS2. Drive it low only after you have loaded the shift register.
    Even then if it is floating you may get a flash on power up, and to avoid that connect a pullup resistor to it, 10K or 100K would be OK.
  • alnajjar1alnajjar1 Posts: 110
    edited 2014-06-26 15:54
    Thanks. To make sure I understand, you are suggesting connecting the OE line to a BS2 pin and pull it low to enable the chip after registers are loaded and the 10k pull up is to make sure OE is not floating, correct? I am attaching a schematic with your suggestion to make sure I am on the right track.
    Since I have 8 of these 595s in a chain (as you see in the schematic), do I need to do the same for every IC or only the first in the chain?
    Many thanks again,
    956 x 611 - 72K
    edited 2014-06-26 17:06
    You can drive all the OEs together, much as you are driving the CLK and LATCH signals. You don't need the 330 ohm resistor.
    Sounds great, thanks.
