Nasty batteries
Im going to stay clear of buying anymore cheap batteries. Ive been using the prop gadget gangster with SimpleIDE. Ivge gone through two sets of AA batteries. I used to have top of the line rechargable batteries from a camera house but some thief that broke in took those as well!
I spend 20 min trying to work out why my programs wouldn't run thismorning. I changed to a few different USB ports. Finally i saw the green light on the gadget gangster was just barley going.
I might slip round the corner and buy some duracell batteries. I really mis my enlope batteries and charger ;(
Haven't you heard of power packs? There is also no reason why you can't run a lot of these boards off the USB power, I know that Parallax doesn't do this normally but just jumper across from USB VBUS to +5V, the hubs and the PCs don't care. I have even plugged a Prop board directly into my Xperia Z2 using USBterminal and it powers it just fine too.
I also have a whole box full of USB "chargers" which I picked up for under $2 each at one time and I never have any problems with them either.
BTW, cheap batteries are too nasty and good batteries are just too expensive.
http://www.candlepowerforums.com/vb/showthread.php?8647-Costco-Kirkland-Batteries-vs-Duracell
http://www.consumerreports.org/cro/magazine-archive/december-2009/electronics-computers/aa-batteries/overview/aa-batteries-ov.htm
But Amazon customers say they leak:http://www.amazon.com/Kirkland-Signature-1-5V-Alkaline-Batteries/product-reviews/B0015UVOJU/ref=dpx_acr_txt?showViewpoints=1
edit: bought
So much for the first line of your thread...
Years ago, I bought what was considered the best local brand of salmon eggs to go trout fishing with a friend that always caught bigger fish and more fish. They wouldn't stay on the hook. Then he mentioned that the brand didn't matter if you didn't open the jar and check if they are still firm and fresh.
Live and learn.
edit: it looks the same, same description L298N MOTER STEPPER DRIVER, but they cost less than $4.00 each. not $30++
That's very interesting. What does it have to do with "Nasty batteries"?
rechargables only, but that's the battery manufacturer's fault for not marking disposables.
When you buy fuel you expect to know how much you're getting don't you? Why be less
circumspect with electricity?
But, you reminded me, back in that day opening up AA batteries with their zinc case, blue acid gloop, and carbon rod, was a good way to get carbon brushes for that DIY motor. What ever happened to those batteries?
And what actually does one find inside a modern cell. This calls for an experiment....
...or carbon arc furnace.
