FT800 (EVE) versus SSD1921?
Trying to decide which way to go for a new development board...
They both have some interesting features... EVE looks fairly simple and low cost and also includes resistive touchscreen controller.
SSD1921 has a camera interface though. I'm leaning this way because of that feature...
But, EVE is new and SSD1921 is old...
I think pairing one of these chips on the same board as a Propeller and including a 3.5" touchscreen could sell OK...
Any thoughts on this?
There are also Board + Bezel kits for Eve, which are appealing.
Perhaps FTDI will offer the Bezels as separate items ?
They also make it trivial to create an on-screen keyboard.
It's also a lot easier to source...
One kinda unique thing about EVE is that it doesn't have a screen buffer. Instead, you make a list of things you want to have drawn and it does it, line by line, just in time.
This makes it unlikely to be interchangeable.
Switched from ExpressPCB to Eagle for this one, because it's a layout nightmare.
Just ordered the test PCBs, should have them this weekend.
Even with Eagle, it'll be a miracle if it works, first try:
If it does work though, I think it will be capable of HD video capture to SD with onscreen preview, which will be pretty neat.
I think I'll also try a version with EVE. EVE doesn't have a video processor or SD interface. But, appears to make usage easy.
Also, it includes touchscreen interface and some audio processing...
What price is the SSD1921 ?
I see ADi have just announced more BlackFin DSPs, from 128k/100MHz to 1024k/400MHz $3.99,~$8.23
in 12x12 QFN88 in 14 price steps. - and also in 184 BGA with DDR2, LPDDR, up to$9.63/1k
These have HS USB, SD hw, QuadSPI and CAN bus.
http://www.analog.com/en/processors-dsp/blackfin/adsp-bf700/products/06_12_14_New_Generation_of_High_Performance/press.html
http://www.analog.com/en/processors-dsp/blackfin/products/index.html
Says this of the PPI
["The processor provides a parallel peripheral interface (PPI) that
supports data widths up to 18 bits. The PPI supports direct connection
to TFT LCD panels, parallel analog-to-digital and
digital-to-analog converters, video encoders and decoders,
image sensor modules and other general-purpose peripherals."]
- and there is a 500K ROM mentioned - wonder what comes in there ?
1024k sounds appealing
The SSD1928 is much easier to get and more popular, but can't drive the 3.5" TFT displays that I have a lot of...
There's no question that there are more sophisticated solutions out there. I've got a camera for my Raspberry PI now.
But, what I'm looking at here is the simplest solution that is as open as possible.
You don't really program the SSD1921, you just write and read from registers.
That BlackFin thing would probably take me a year to understand. Also, the software for it is $1000 per seat I noticed.
Having a Propeller board that can take 2 MP photos and save as .jpg on SD card could be handy for some things...
I'm thinking about a motion tripped security system.
Or, time lapse photography..
Or, maybe a robot with a camera that can sent images over wifi...
BTW: In terms of simple+low cost, the FT800 looks pretty nice too (but no camera port).
Also, looks like they'll have a capactive touch FT801 for sale soon...
Yes, it is a comprehensive looking device.
I think they have a bundle offer of this, still not cheap, but $299 is ok for commercial targets.
Begin developing today with the ADSP-BF707 EZ-KIT-Lite complete with an ICE-1000 emulator & CrossCore® Embedded Studio for $299.
I see the BF70x does mention 18 bits on the Parallel Peripheral Interface, but you may be right about the SW being a separate priced item, making it quite expensive.
Pity, as hopefully ADi would provide enough sample code to generate LCD video over PPI, which would reduce the learning time significantly.
I asked Analog Devices if their claims of you can start the evaluation immediately in the EZ-KIT Lite meant the SW was included in some workable form....
Their reply was
["CrossCore Embedded Studio (CCES) comes with a free Evaluation license built in which, once activated, will allow you full access to the tools for a 90 day period. Once the Evaluation has finished, and if you decide to proceed with working with the BF707, you can purchase a Full license. "]
So, that does make it $299 plus $1000 to work with this part.
I was getting ready to spring for the $299 dev kit - thanks for posting about this.
It would have been very hard with ExpressPCB, so I'm glad to have spent the time to learn Eagle...
Just ordered a revised version with some additions... Made the board smaller and added "wings" to either side.
One side will have an analog joystick and the other a 7-function tactile switch with nav, jog and select.
I guess I'm thinking that the wings could be cut off if not needed.
Here's what it looks like:
I've also just started an EVE (FT800) version of the same thing. EVE has a lot of benefits, but no camera interface.
